Question about Dishwashers
Ok new garbarater is in but it's flowing up hill I did not do it to get it to this point but have it to fix :( what do I need to do to finish fix this so I have my sinks and garbarater back ???
    President:
  • 2,976 Answers
There are 2 ways to fix it. You can either change the tailpiece to a longer one and readjust the trap or, you can turn the elbows at the disposal to bring them op to above level. You will have to turn the disposal in the sink to get this to line up.
Posted on Dec 19, 2012
My Ford Transit Diesel 2007 (camper van)intermitantly loses power and the Engine Malfunction light comes on. If I stop, turn off the engine and restart it a few minutes later everything goes like a ch
When the engine is under load it uses more fuel then normal .First replace the fuel filter then check the fuel pressure and flow. the pressure and flow are checked with gauges. For a rough check remove the return pipe from the fuel rail, if fuel is flowing there the fuel system should be ok providing the pressure valve is not stuck open. if there is no flow there the pump may be at fault.
Nov 13, 2014 | Cars & Trucks
How do I fix a gradual drive power loss?
Check for fuel flow at the carby ,fuel line might be blocked.
Aug 26, 2014 | Garden
1997 chevy 3500 5.7l loses power on inclines
Do you have a check engine light on? Have you done an engine control module fault code test (OBD2 control system), is fuel pressure OK under a load? Has the fuel injector spider manifold (inside the throttle bore) assembly been replaced, that is a known problem.
Jul 14, 2017 | Chevrolet Chevy Cars & Trucks
I have an 86 Oldsmobile delta 88 and it has no power it slows down really fast when u start to go up a hill how can i fix that
Check your inline fuel filter. If the filter is half full of gunk, some fuel flows but when you start up a hill, there is a call for more fuel from your pump and this additional flow causes the gunk to become packed against your outlet stopping all of the fuel flow.Changing the fuel filter solves this.
Apr 04, 2011 | 1986 Oldsmobile Delta 88
Installed new fuel pump, new electronic lift pump, 2 new fuel filters, new glow plugs, and a few new fuel lines. Truck starts and runs ok till it warms up then when putting it in a pull like going up steep...
The next step is fuel flow measurement. your description sounds like fuel starvation...this test focuses on volume over time.
Probably, you would have good flow, that would taper off and no longer be enough, after a short time...
Sep 18, 2009 | Ford F-350 Cars & Trucks
Loss of power/Engine Sputters going up hill
change your fuel filter it may have imputities in the fuel causing the fuel flow problems
Jun 21, 2009 | 2004 Kia Sedona
Just finish putting a new water pump and gasket on 01 pontiac sunfire ...now it is air locked and over heating .. how can i fix it
Remove the temp switch and keep putting water in until air comes out and water is running at a good flow.Always remember you should bleed the system from the highest point on the engine
Jun 07, 2009 | 2001 Pontiac Sunfire
No power, idling rough
Replace the catalytic converter and EGR valve
Jun 03, 2009 | 1991 Subaru Legacy
Dishwashers Logo
Top Dishwashers Experts
