Question about Mitsubishi WD-57833 57" HDTV
My mitsubishi wd-57733 tv keeps blowing lamps
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
  • 3 Answers
SOURCE: Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Posted on May 07, 2009
SOURCE: Mitsubishi WD-52631 HD TV lamp problems
So far I have had no good luck with Mitsubishi. I have had them send me two bulbs and had the tv repaired in the two years I have owned it. My last tv lasted 14 years with NO issue and didn't cost me $1400!! I have been told there is an air flow problem and power supply problems which both lead to low lamp life. I think that if Mitsubishi wants to avoid a class action lawsuit they need to start giving away free lamps for this model. Also, this is not localized to just the 52" tvs. My wifes ex has the 62" and it has the same issues.
Posted on Oct 23, 2009
phil_frye
  • 295 Answers
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Posted on Nov 20, 2009
Testimonial: "very helpful. this was my first thought! thank you!"
SOURCE: WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
How do i fix a code 18 in my mitsubishi tv wd-57733?
Try with the remote the soft reset: Menu, 1,2,3, Enter.
Dec 08, 2012 | Mitsubishi WD-57733 57" HDTV
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Apr 30, 2012 | Mitsubishi WD-57733 57" HDTV
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
How to remove and install tv lamp for model wd 57733
See page 62 of this manual. Read the section titled "Lamp cartridge replacement". It has detailed info with pictures.
http://www.retrevo.com/support/Mitsubishi-WD-57733-TVs-manual/id/3124bh436/t/2/
Feb 06, 2011 | Mitsubishi WD-57733 57" HDTV
Lamp light is yellow. Replaced bulb still not working1
CHECK AND MAKE SURE THAT THE LAMP DOOR IS SECURE ON THE BACK OF THE TV.
Dec 16, 2010 | Mitsubishi WD-57733 57" HDTV
Mitsubishi Wd-57733 TV 57"
lamp is out call mits and order a new one do not use any other lamp but OEM
Apr 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-57833 57" HDTV Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
