Question about Vehicle Parts & Accessories
Unlock radio code for Acura 1.7 EL year 2001
My Acura Model 1.7EL Year 2001 battery died out and the stereo went on that anti theft lock thing. i need the code. can anyone help please??
ACURA Model 1.7EL Year 2001.
Serila # U2100L1399
Turn the radio off then hold numbers 1 and 6 down and hold at the same time.Then while still holding them down turn the radio on and a four digit number will apear followed by another four digit number.When you have both numbers call the dealer and tell him the numbers and they will give you the code.I did it today to mine.
Posted on Mar 05, 2011
My car is Acura el 2001 1.7 it no work radio so I need help the code for radio setup that . it have aerie U 2100 L 4544. please help me ,thank you so much
Posted on Oct 27, 2012
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Where is the reset button located in a 2003 Honda Odyssey for the anti theft?
If the remote was programmed before loss of power, push and hold the unlock button until the alarm stops. If not try locking and unlocking the drivers side door with the the key. This has reset the alarm on my 2001 Odyssey.
You will also need the unlock code to reactivate your stereo after long term power loss. It is on a card with the manual given to the owner of new vehicles. A smart dealer will put it on a sticker in the glove box. Otherwise you have to remove the radio and give a Honda dealer the radio serial number to get the unlock code. Don't try it randomly; 10 incorrect tries locks the stereo.
Mar 07, 2015 | 2003 Honda Odyssey
My eclipse stereo is in lockdown-anti theft mode & can't unlock
contact the dealer of your car, give the vin no:of your car to them, and they will be able to give you the radio code
Oct 21, 2009 | Car Audio & Video
The battery died on my 2001 eclipse, now the radio only says ''off''?
This is the anti-theft device on your factory radio. When the battery died, the radio thought it had been removed from your car and went into anti-theft mode. When you turned the car back on, the radio should have read "CODE" on the display, at which point you need to enter the factory anti-theft code. After 3 failed attempts at entering the code, it will simply read "OFF" and the radio is locked.
At this point:
- find your factory anti-theft code - it should be in your owner's manual, or you can contact a dealer to retrieve it
- turn the key to the ACC position (radio and accessories on, but engine is off)
- turn on the radio so the display reads "OFF"
- let the car sit for 1 hour
- radio will turn off automatically and reset
- turn the radio on again, and it should read "CODE"
- enter the factory anti-theft code
Make sure you have the code before starting the procedure. To enter the code, use the radio preset buttons. For example, if your code is "4321", hit Preset #1 button four times, Preset #2 three times, Preset #3 two times, and Preset #4 one time. Then hit the "Tape" or "CD" button. Radio should now be unlocked.
Sep 13, 2009 | 2001 Mitsubishi Eclipse
Reset pin code on raido
tuen radio off...hold #1 and #6 on preset buttons...tuen radio back on an alphanumeric number will display theere should be 8 digits and 2 numbers...you will need to call acura and give them these numbers and they should give you a lock code to enter hope this helps
May 31, 2009 | 1999 Acura CL
Acura car stereo lock codes my stereo needs a code is a Acura 3.0CL now it says err-3 can some one help
err-3 means you have entered incorrect anti-theft radio code more that three times.If you do not have radio code you can most of the time find the code card tucked away in the owners manual pouch.(looks like a bussiness card)If you are unable to find card you would have to pull radio from dash and retrive stereo serial number,which is on bottom side of radio.once you have s/n you can take s/n to any acura dealership(has to be a dealer)and they can get radio code for that stereo through Honda Corp.once you have correct radio code you will need to first unplug radio,or disconnect battery to reset radio memory,then type in radio code.again if entered incorrectly 3x ,radio would need to be reset again too clear error codes.good luck!
Mar 30, 2009 | 1998 Acura CL
Security code for my 1999 acura TL stereo system
look on the fusebox, glove compartment for a number
Feb 04, 2009 | 1999 Acura TL
2003 Acura CL Type S Radio Code
I have a 2001 Acura 3.2 CL
Turn your radio off
Press the #1 Preset button and #6 Preset button at the same time and while doing this with your other hand turn your radio on and your will get a stereo code. Call the dealer and see if they will give you the unlock code for the stereo code otherwise go to stereo-code.com and pay $ 28.00 to get it quick
Nov 19, 2008 | 2001 Acura 3.2CL
Vehicle Parts & Accessories Logo
2,627 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
