Why won't my powered subwoofer turn on? It's not
    Problem Solver:
  • 19 Answers
Have you check if the plug is good on it?
Posted on Dec 03, 2012
5 Suggested Answers
SOURCE: PAradigm ps-1000 subwoofer
It turns out its most likely one of the resistors on the PCB on the amplifier plate.
My uncle has had the same problem and managed to replace the resistor and its working as normal now.
Posted on Nov 02, 2008
tech240
  • 169 Answers
SOURCE: subwoofer installation
no jack =no sub audio signal so you would have to get some kind of summing filter. this would sum (mix) the two signals together and extract the sub audio from both channels in order to drive the powered sub woofer you have. could be expensive dont know.
Posted on Apr 25, 2008
mikeslab
  • 87 Answers
SOURCE: klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Posted on Apr 26, 2009
  • 140 Answers
SOURCE: powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Posted on Jan 15, 2010
Subwoofer wont play!!
first clean your board.ok.....same problem......?remove chargin connector
Jun 14, 2013 | Audio Players & Recorders
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
Hp G56-129wm won't boot. Powers up but doesn't show any screens, and then dies!
2 Suggestions:-
1) Did you tried to connect External Monitor? Tell me the status
2) Remove all Power Adapters and battery. Push the Power Button for 15seconds. Again Connected the battery and Power Adapter. Check if its working or not. If not then Must be Motherboard Problem.
Jul 24, 2012 | HEWLETT-PACKARD G56-129WM Laptop PC
Model wt46809 won't turn on
If the green light which is power comes on and does not go off you do not have shutdown---what happens via menu? (see on screen display?) there are possible reasons but if possible try the self check this set has--and do a visual look inside for any signs of Glycol.
Jun 07, 2012 | Mitsubishi Televison & Video
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My i pod touch is blank, i've followed the relevant stepr to restore it. after which an error code was given on i-tunes, i followed the steps given for the error but my i pod is still doing...
Try this:
Hold down the middle button (home button), the power button, and the volume DOWN button (make SURE that it's not the up one. It won't do anything, but it won't fix your iPod. Only the Down button will.).
Hold all of these down until the Apple sign shows up. Once the Apple sign shows up, it SHOULD work.
I hope this helps!
Jun 15, 2011 | Apple iPod touch
Car was working fine then i went out again it started then cut off and now won't start everything's fine only thing went wrong power windows stopped and power windows stopped working also before...
Sounds like possible fusible link is blown or lose?
Fusible links are different then regular fuses found in fuse box and are located under the hood near the battery ..
Did you just install the system ? or has system already been installed for a while and this problem just occurred ?
May 15, 2011 | Car Audio & Video
SPL 10BV - no output after a long session with volume control seat 5 (12 o'clock). Has it got a fuse?
Most powered devices have a fuse. Does it work after being turned down in volume? or is it completely dead with no signs of power? or does it show some indicator light but no sound? Check for blown fuse and then for blown speaker coil.
Mar 03, 2010 | Velodyne SPL-1000 Subwoofer
492 people viewed this question
 Grubhead
Grubhead
