Question about Car Audio & Video
My Kenwood powered subwoofer will not turn on ("power up.") Is there a fuse I could check? Is there any way to diagnose this problem?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
There might be a fuse, But if you can,t find one, There is no way you can repair it your self .It will have to be taken in to a shop to be repaired,
Posted on Dec 03, 2012
Kenwood install dodge ram now subwoofer not working
does the stereo have sub settings they could have it turned off. did you connect the remote wire to the amp(its used for turning on the amp or for powering a power antenna usual a blue wire coming from the head unit). also check the fuse on the amp. hope this helps.
Nov 29, 2014 | Kenwood Audio Players & Recorders
Kenwood powered subwoofer no power
There may be a blown fuse internally
Nov 16, 2012 | Kenwood SW-38HT Subwoofer
Kenwood KDC-MP342U turns on but just keeps saying "reading" when in usb mode. I recently had it go into protect mode and I took the stereo out and checked the wires and re-attached the ones that...
it sounds like the USB connector on the face place of the radio has a cracked solder joint. i suggest taking it to a person that know how to solder small objects. your Kenwood has a one year manufacturer warranty it could be some thing to check in to.
Jun 18, 2011 | Car Audio & Video
My ksc-sw800 kenwood subwoofer doesnt have audio output,i conected the power,+ to posite of battery and GND to negative of battery,..conected audio to input while my i pod is palying audio but no sound...
The P.Con is the terminal that is connected to the (blue with white stripe) cable on the back of your head unit. If there is no (blue with white stripe) cable then there will be a (solid blue colored cable). This connection is used to turn the amplifier on and off when you turn your head unit on or off. The power cable from the battery is to provide power and not to turn it on or off. Think of the P.Con as the ON / OFF of your amplifier. If you are unsure of how everything else should be connected, then send me a list of what you have (models please) and i will help you out. Hope this will help.
dreamsystems
Feb 12, 2011 | Kenwood Car Audio & Video
KDC-4051UG Only comes "ON" with
Your head unit is now connected correctly. That is how it is intended to be installed. Unless it doesn't store the radio stations. In that case the power cables of the head unit (RED&YELLOW) are incorrectly connected, but not a big problem. hope that helps dreamsystems
Feb 06, 2011 | Kenwood Car Audio & Video
I just received this kenwood 100 watt powered sub w/10'' sub from a friend... he says it just won't turn on, i checked the fuses and they seem ok to me just won't turn on like he said... can someone help...
check the transformer has ac around 50 vac. then check the dc power supply at +_ 45 vdc if all that is ok,check the output ic has +- 45 vdc at 2 of the pins,if it does,the output ic is probably no good
Jul 17, 2009 | Kenwood Audio Players & Recorders
Woofer will not turn on. fuse was bad but i replaced it and still no power.
Had the same problem, no power from the sub, no light. Opened the box, fuse was bad, replaced the fuse...pop...blew again. Found out that on the bigger middle board next to the power plug there are two capacitors on either side, the inner one burned and crumbled to pieces. I called Kenwood, they said that I would have to bring it to a Electronic Service Specialist that they will give you a number to in your area...or...Ship it yourself to their East Coast Center in Virginia. I already asked if Kenwood is going to send an RMA or Shipping Label and they will not. You will be responsible for the shipping there, but they will pay for the shipping back. Kenwood's East Coast Center in Virginia's number: 757-340-1702 - Good luck
Dec 14, 2008 | Kenwood SW-38HT Subwoofer
Sw-32ht kenwood subwoofer
Open the case and check the fuses and the speaker to see if it actualy still working and not blown.
Oct 26, 2008 | Kenwood SW36HT Subwoofer
Kenwood Home Theater
Please update your post with any Model Numbers that you can retrieve, especially the subwoofer. Off hand, and with the limited amount of information that you have provided, I would GUESS that your subwoofer is simply overheating, and is being shutdown internally, hence protecting the fuse because no short is detected. If you haven't moved and or vaccuumed/cleaned around or near your system regularly, dust, pollution, pollen...you name it, builds up and can easily prevent electronics from breeathing/venting properly.
Jul 31, 2007 | Kenwood HTB755DV System
Power wire
You should run a new power wire to the battery or fuse box from the Sub. For safety there should be a fuse on the cable at the battery or fusebox end.
Mar 26, 2007 | Kenwood KSC-WA100 Car Subwoofer
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
