Pinch roller stuck in "up" position, eject button won't open door
One of the pinch rollers on my tape deck is stuck in the "up" position. The door will also not open once it's closed, unless I pry it open while holding down the eject button. Both of these problems are with the left-hand recording deck, and emerged at the same time: all I did was insert a tape and hit rewind, then it made some strange noises. I tried hitting the stop button and then the eject but nothing happened, so I pressed the power button to turn off the machine. I had to pry the door open to get the tape out, and since then I haven't been able to get it to work. The machine was working perfectly 5 mins before. It's a Yamaha KX-W282. And the eject button is a mechanical eject, I've opened the thing up and looked inside and I don't see any broken belts and all the wheels seem to turn fine, and I also can't see any obvious problem with the eject mechanism. But the right-hand pinch roller in the record deck is visibly stuck in the "up" position.
  • Audio Player... Master
  • 1,258 Answers
The very first mistake is to pry a door open. That damages them. You are never to do that. The correct way to get a tape out is to open the unit up and find out why the tape is stuck and then take action to release the door in the normal way- usually it is a loose belt or defective cam motor. As to the Pinch roller there are slide plates and even some pinch rollers had lubrication on them so that may have dried leaving you with a stuck part. The normal order of business is the find out what is stuck and then take action to clean and lubricate the mechanism to return to normal function. The problem with some Pinch Rollers is that there may be a particular spot it needs to be set at. This is true if it has a guide fitted to it. Then you will need either a jig or mirror tape to be able to set it correct again. I can not give any further advice without seeing the unit but this should get you started.
Posted on Dec 06, 2012
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: JVC KD-85 Cassette Deck Stops in Seconds in play, REW., & FF
Hineovision1
The deck will need new belts and idler drives cleaned and serviced, and perhaps some idler tyres replaced. You can get a belt kit from these guys. replacing them is not such a difficult job if you have some mechanical aptitude. Just take it slowly, and focus on getting the transport out of the unit.
I am more than happy to answer any other questions you may have aboutit, please get back to me here, or use the ASK function to go straightto me :) If you are still unsure, have problems, or we need to look atthe situation more deeply, then before you give a rating for thisadvice, hit the ASK buttonThanks for using FixYa, If you consider the advice I have given you assound, a FixYa rating is a great reward for my efforts to help you.Cheers.
regards
robotek
Posted on Jul 08, 2008
mrgreenz
  • 962 Answers
SOURCE: Play function won't disengage on Technics dual cassette deck
Remove the cover to see if any belts under the cassette player is cut. Or to see if there are any obstructions.Remove the front cover.which will remove the tape housing of the cassette player. you can check for any broken plastic compoments that might be keeping the housing from opening.Or any belts that may have been cut.
Posted on Dec 27, 2008
  • 73 Answers
SOURCE: The capstan drive roller on my tape deck fell
You need to locate the supplier of pinch rollers that will fit your tape deck. If that fails, you have a useless piece of gear. If the unit is of decent quality, you should be able to locate a supplier. You didn't include the make or model, so good luck.
Posted on Oct 07, 2010
Ad-f410 change pinch roller
Why do you want to change the Pinch Roller? Most of the time they just need a good cleaning and other things in the deck like back tension checked. Pinch Rollers are only changed if they are cracked and I have seen few cracked Pinch Roller in 40 years.
May 02, 2014 | Audio Players & Recorders
My reel to reel will not play.
You need a new capstan belt or the capstan shaft is glazed as well as you have a hard shiny Pinch Roller. Each of these items need to have friction to work.
Nov 19, 2013 | Teac Audio Players & Recorders
Will not reverse play on deck 2-just goes very fast on this
This condition, regardless of which way the tape is moving, is caused by the failure of a rubber pinch-roller to trap the tape between capstan and the passive roller.The speed is then caused by the part of the drive driven by a small belt and a clutch that should only keep a small amount of tension on the tape in ensure clean rewinding of the tape after it has passed the head.
Lubricant in part of the transport's moving parts or a dried-out rubber roller may be causing this.If you want to try to clean the pinch roller, don't use alcohol since this can further harden the robber.Use a clean fiber-free cloth or paper towel wetted with a LITTLE naphtha and turn the roller on the wetted area. If you get some dark smudging, the treatment is working.
Nov 23, 2011 | Sony TC-WE475 Single Cassette Deck
I don't have the manual. I placed a tape in the deck and cannot remove it. Help!!! It has happened before, and suddenly I will be able to remove it, and then it will happen again. I'm not...
pry on the tape deck cover with a thin knife and see if it opens...what happen is that your tape deck eat up the tape with the spindle this is due to the fact that the head and the spindle and the pinch roller is dirty.to clean these parts trick the deck as if it has in a tape.do this by when you open the cover push down the lever at the bottom of the tape rest in the tape deck when you have remove your tape. at the same time press play it will start to spin take a cotton swab dip into alcohol press it on the pinch roller until it is clean also apply it to the head. after cleaning you are good to go your tape will stop stuck until the head and pinch roller gets dirty again. good luck.
Sep 23, 2011 | RCA RS2610 CD Shelf System
Thaks for helping. My tape deck door has suddenly stopped working. the tape is inside and when i turn on the wpower there is a clicking sound. it is a TEAC AD-500 CD player/reverse cassete deck
Without physically looking at the cassette deck myself, I cannot be 100% sure the tape is wrapped around the pinch roller and capstan. The capstan is the chrome rod which the rubber pinch roller pushes to regulate the speed of the tape moving across the head. However it is approximately a 90% chance the take up reel for the tape stopped working from a bad tape or a loose belt which drives the tape take up reel. The clicking sounds like it could be the auto reverse solenoid because it thinks the tape has reached the end of play. The fun part is to remove the tape which you may have to disassemble the front panel if you cannot gain access to the tape from the top or bottom. You will need to cut the tape and remove it from the capstan and pinch roller to open the cassette door. Sometimes you can remove the capstan to free the tape. Once you have cleaned all the tape out of the unit make sure the belt for the take-up is good. If it is glazed, cracked, loose or broken order a belt. Clean all the pulleys and capstan and replace the belt. Your unit should be functional after the above procedure.
Jul 14, 2011 | Teac R-H300 Dual Cassette Deck
The capstan drive roller on my tape deck fell apart. Spindle is .0975" dia. Pinch roller is .862" dia. All other belts and rollers seem OK. Where can I find a replacement capstan roller? Thanks.
Oct 06, 2010 | Audio Players & Recorders
I have a Sony TC 630 Reel to Reel Stereo Tapecorder..Pinch Wheel is sticking and will only move when forced and brushes as well...Any help ?
Sounds to me like your Sony has a common problem among vintage reel tape decks..dried /frozen grease/ and or a lack of lubrication. carefully apply a tiny bit of fine lube oil, like 3in1, on the swing mechanism that carries the pinch roller...(you may have to remove the front metal deck face to fully access the swinging pinch roller mechanism) ) . do NOT get any oil on the rubber pinch roller..(best to make sure after by scrubbing the pinch roller surface with a cotton swab lightly dipped in non chemical household cleaner, like 409, or awesome orange i get at the dollar store. Then use the dry end of the swab to ensure the pinch roller is dry. .The pressure pads should swing upward and press the tape against the heads when in play/record mode..if they do not swing up, they are binding/ or out of adjustment....they are spring loaded so when the reel deck is in the stop position the spring loaded pressure pads are held down...play/record mode releases them to freely swing up and press on the tape against the heads.
May 11, 2010 | Audio Players & Recorders
Playback Sony Professional Walkman
Sounds like the pinch roller isn't engaging. The pinch roller is a black rubber wheel that presses against a silver post (capstan) the tape is held between them. With the door open and no tape press play. The roller and capstan should touch. If it recently ate a tape there could be some tape on the capstan that also will cause it to run fast.
Feb 03, 2010 | Sony Audio Players & Recorders
I purchased a Nakamichi 480 tape deck from a seller on eBay. All the push buttons work OK except for the EJECT button. It will not allow the compartment to open where you insert a tape. The eBay seller...
Hi there
It is probable that the head assembly or pinch roller assemblies are not returning to their correct rest position. The arms that carry the pinch roller assemblies develop dried grease problems in the bearing/post they are mounted to that prevent their timely return and fouling the casette shell preventing eject. Check them by seeing if they are clearing the cassette shell, and are "sprung into the home position with out binding.
I have repaired scores of these decks over the years, and am happy to talk to you more about the problem. Thanks for using FixYa.
regards robotek
Jul 02, 2009 | Nakamichi Audio Players & Recorders
Won't play or record.
This will be a bit difficult because I can't see the unit, but here are a few ideas.
1) Did the arms that pull the tape around the head go all the way around the heads? If not, I would look at the loading motor belt. It may be slipping and not fully loading the tape.
2) Is the tape being pressed up against the pinch roller on the right hand side of the deck? If not, there is a pivot arm that is supposed to pull the tape up to the pinch roller. This arm often gets stuck in the "loaded" position and therefore does not pull the tape up to the pinch roller.
Please update this with what you see and I'll provide more details on how to address the problem.
Dan
Mar 19, 2008 | Sony SLV-R1000 S-VHS VCR
283 people viewed this question
 Grubhead
Grubhead
