Question about Intertherm Heating & Cooling
Packaged Air Conditioner?
I'm looking for a Packaged Air Conditioner. I've read to underestimate the BTUs with these things, is that true? I'm trying to cool a very hot 16x7' room. e.g. the house can be 80* and this room will reach 90* (south facing room) Any user experience would help, thanks
  • 32,281 Answers
This WEB site will assist you in calculating the size of the AC unit.
http://www.airmerchants.com/whatsize.html
Posted on Dec 03, 2012
3 Suggested Answers
xclubcar98x
  • 111 Answers
SOURCE: I have an LG portable
How is the temperature of the air coming out of the unit?
Posted on Jun 09, 2011
  • 4736 Answers
SOURCE: We've turned on and set
Kinz, there are several things to troubleshoot,
1. Check the air intake filter for dirt or clogs.
2. While you have the front off to remove the filter, look at the cooling coils to see if they have frosted over. If so, turn the unit OFF,Unplug it and allow it to thaw completely. Once it has thawed, clean the coils, by wiping them with a damp rag of luke warm water. Dry them as best you can and what you can't reach, allow to air dry. Then spray a light coating of WD40 on them. Also check the cooling fins. If they are dusty, use a vacuum cleaner that has a hose and brush attachment to clean them. Reassemble all the parts, plug the unit back in, turn the Master ON/OFF Switch to ON and set your thermostat to the temp you want to maintain. Give it about 30 minutes to run, before checking it again. Hopefully, this solved the problem.
If not, worse case scenario is, one of the condenser circuits has failed and needs to be replaced. Or the compressor is low on R14 refrigerant gas and needs to be recharged. Either one should be checked and repaired by an authorized service technician, because it requires the proper equipment to service and repair those two things.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on Jun 10, 2011
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
    Here is a tip about troubleshooting your air conditioner...
    There are many things that can cause your air conditioner not to cool...
    AirConditioner Trouble - Review the Possibilities
    heatman101
    Jul 24, 2011 | Danby DAC5020 Air Conditioner
    Everytime i plug in the ac the relay switch trips
    That is because there is a wire shorted in the unit or the compressor is locked up and has gone bad...
    The most likely thing is that the compressor is bad... it will cost more to replace it then the unit is worth...
    Air ConditionerTrouble - Review the Possibilities
    heatman101
    Jun 21, 2011 | Fedders A7Q08F2B Q Chassis Room Air...
    How many btu's does this unit have (kenmore -70299 )
    look on side of cabinet for small metal plaque- has name,model,serial# ,btus,energy rating
    May 30, 2011 | Kenmore 70299 Air Conditioner
    Im just trying to find out how many btus my air conditioner is
    It says it in the model number 12000 btus or one ton enough to cool 700 to maybe a thousand feet.
    Jul 08, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
    What is tht tonage if i have a model#wpka 031jaz weatherking air conditioner
    2 1/2 T the 31 in the model # is 31,ooo btus divide by 12,000 btus in a ton
    Aug 06, 2009 | Weather King 10AJA3601AH Air Conditioner
    How can we caculate the energy needed by an air conditioner?
    It depends on the (EER) Energy Efficiency Ratio,which is capacity divided by watts.
    Example 35000 btus / 2500 watts = 14 EER
    If you know the capacity,btus and EER you can calculate the watts, capacity / EER
    Example 35000 btus / 14 EER = 2500 watts.
    EER is determine by testing the air conditioner at Department of Energy Guidelines, which are
    80° drybulb 67° wetbulb indoor and 95° and 82° drybulb outdoor.
    May 14, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
    Heating & Cooling Logo
    49 people viewed this question
    Top Intertherm Heating & Cooling Experts
    Donni Steen
    Dennis Boxerman
    Dan Webster
    Dan Webster
    Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
