Question about Dryers
I would like to put a 220v 20amp heater in my garage i have a fuse box in the garage as it is not attached to house so i need to know how to wire the plug in to my fuse box
  • Dryers Master
  • 32,281 Answers
Mains wiring should be carried out by an qualified electrician. If you do not have mains electrical knowledge or qualifications and you make a mistake it will kill you.
Posted on Dec 03, 2012
919165130 Craftsman Compressor - how to wire for 220V
Check all wring. Remove cove and see if you can turn over by hand.If you can't unit is broken/frozen.it should run on 120. look at the plug if prongs are vertical the unit 120vac. Look on motor wire box if it can be rewired it will be there. I doubt this unit is designed to operate on 120vax. The mots/pump assembly is not available for purchase. there are a few repair parts available. do you want to spend the time and money for rewind.? good luck
Feb 21, 2018 | Craftsman Air Tools & Compressors
12 volt in dash power outlet 2001 dodge dakota
The power outlet uses a 20amp fuse marked D in the box near the battery.
The cig lighter uses a 15amp fuse in the inside fuse box.
May 09, 2013 | Cars & Trucks
How do I run from a 100 amp main panel to a 60 amp subpanel, 125 from my house to the garage
See 60 Amp sub-panel image
Above image shows drawing of 60Amp sub-panel located next to main panel. Drawing shows #6 wire... 125' distance to garage calls for #4 wire. I ran #4 to my barn and have no problems.
Give thought to how many new breakers you want at garage.
See photo of subpanel that holds three 240V breakers
Using drawing as a guide. Replace existing 240Volt breaker with new 60 Amp breaker. Two hot wires connect to new 60 Amp breaker. Neutral connects to neutral busbar.
More space: You can free up space in main breaker box using a tandem breaker. Or by doubling up 2 lightly used 120V circuits onto one breaker. Do not double-up on 240 Breakers
Conduit: You want PVC conduit large enough to fit three #4 wires. Bigger conduit is easier to pull wires ... and maybe later ethernet wire, or alarm wire etc.
Ground wire: You can put a ground rod at garage and run #6 bare copper between sub-panel neutral-busbar and ground rod. Attach ground wire firmly with grounding clamp.
I want you to check with local electrical supply for exact code in your area concerning conduit requirements, grounding, and wire size. Tighten all lugs very tight against wire.
Oct 03, 2010 | Siemens 100 Amp Main Breaker Renovation...
Samsung dryer Mod DV328AEW/XAA electric 220v dryer tumbles but does not heat.I've checked and power is 220v (working) There appears to be no burnt wiring, inside. and heating coils appear to be intact.
HI. Ok, this unit is equipped with four thermostats that monitor the cycling information and the heater box for optimal operations. All of the thermostats should be tested for proper functions. I suspect that the culprit will be the thermostats mounted on the heater box, but test all to isolate.
Here are all the thermostats that are to be tested, below:
1. Thermal fuse - This will be mounted on the side of the heater box(chamber). Test properly to confirm its functions.
2. Cycling Thermostat - This will be mounted on the blower housing.
3. Cycling thermostat(2) - mounted on the blower housing
4. Hi-limit thermostat - Mounted next to the thermal fuse on the heater chamber/box.
Concerning the element:
You cant always tell by looking. This device must be tested to confirm that it is indeed working as designed. It should show some signs of continuity if it is indeed functioning.
Proper testing technique for most thermostats and fuses:
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Jul 30, 2010 | Samsung Dryers
Suspect that a 15amp heater tripped the 15amp breaker. this happened a couple of times. now when the 15amp breaker trips a 20amp breaker also trips. the heater is now unplugged and the 20amp can be reset...
You Know for a 15AMP unit it really should be on it's OWN sub-main, Ordinary House sockets are usually only 10AMP rated. This WILL overload any normal household wiring. You also need to get this unit checked out. to see if you have any "Earth leakage". Also at 115volts and 15Amps that equal a 7.66 OHM load....Be careful.
Feb 03, 2010 | Heating & Cooling
Need to replace 2 wire baseboard thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 13, 2009 | Honeywell (CT62B1015) Baseboard Heater
Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
Dryers Logo
Top Dryers Experts
