PHILIPS IMAGEO - BRAND NEW - CAN NOT TURN THEM ON AFTER CHARGING
I HAVE THIS PRODUCT FOR YEARS. GOT A NEW SET OF THREE CANDLES. CHARGED THEM AS USUAL BUT NONE OF THE THREE NEW CANDLES CAN BE TURNED ON. THE CLICK OF THE SWITCH WHEN TILTING CAN BE HAERD JUST LIKE THE OLD ONES. BUT THATS IT. TRIED TO USE THE "OLD" CHARGER STAND - SAME THING. WHAT GIVES?
SOURCE: PHILIPS GOGEAR 6GB
The same thing happened to me. I contacted Philips and they sent me this solution, which worked for me. Question My GoGear has no power/no display even connected to the power supply with the AC adapter. What should I do? Answer Do a soft reset by pressing and holding the Power On/OFF button and the volume + key for a couple of seconds. Then connect your GoGear to a power outlet with the AC Adapter to charge the player again for around 30 minutes. Try turning the unit back on and see if the display appears. If the display is able to come on again, keep the player connected for another 3-4 hours until it is fully charged before use, else contact our Customer Care Center for assistance.
Posted on Sep 14, 2006
mneilsen2084
  • 342 Answers
SOURCE: Ipod wont turn on. ive tried everything! none worked! HELP!
You will want to attempt to force the iPod into disc mode before restoring. This should solve your issue.
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Please let me know if this did not resolve your issue. :)
Posted on Jun 24, 2009
  • 21 Answers
SOURCE: It won't turn on and it's fully charged.
it might be locked
Posted on Jul 14, 2009
SOURCE: 3rd generation ipod won't turn on!!!
Hi Guys,
I pressed the center and menu button for about 3 minutes and the unit came right back on.
thanks for the help
Posted on Aug 27, 2009
pabloloco
  • 2335 Answers
SOURCE: Coby 610-2g won't turn on or charge
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player should have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Posted on May 08, 2010
I have the Amertac Westek/Amerelle 75206 LED Rechargeable Candle Kit, 6-Pack2 of the candles don't flicker their just on why is this when I was told their suppose to flicker?
Swap the candles around in the charger. The two in question may not be charging properly or their rechargeable batteries may be defective. Chargers of this type tend to be sensitive to incorrect installation of the candles. I have also found that the candles do not hold a charge very long.
Jun 28, 2014 | Westek Amertac 75206 LED Rechargeable...
Lost Candles manual. What "On" position for timer
"your" candlelamps? Can you give me a brand / model name. I know many brands only switch off with the timer
Mar 08, 2014 | Candle Lamp Home
How long do new mp3 players need to charge up the brand name is eclipse 2810c
Keep the MP3 player plugged in until it makes an alert or starts up. It usually is 1-2 hours but I would check the manual! :)
Jul 30, 2012 | Philips Audio Players & Recorders
After charge cannot turn on button
Hi jtleonard74,
There appears to be a problem with the battery. The built-in batteries are tailor-made for the charging system in this shaver. These batteries must be soldered to the circuit board by a qualified technician, who can install Philips Norelco razor rechargeable batteries.
Before doing so, check the unit with a different outlet to ensure the usual outlet is not causing the issue. I recommend contacting a Consumer Care agent who can look further into your issue. The product comes with a 2-year Warranty, so you may be within that period. If not, the agent will be able to provide you with the names of authorized Philips Norelco repair technicians in your area.
For more information on this product, the Support Site is available @ http://ow.ly/5Rec7.
Consumer Care can be reached @ 1-800-243-3050.
Hope this helps! If so, let me know by rating this solution so that I may help others more effectively.
Jul 30, 2011 | Philips Norelco 8175XL Electric Shaver
How long should i charge my LG KS360 brand new?? should i have it on or off as well?? It is playing up already and its brand new :(
Lithium Ion Batteries are more forgiving then the old Nickel Hydride batteries. They do not have memory cells but "charge cycles" usually about 300-400 or so (enough for 1 charge a day for 1 year hence the 1 year warranty on a battery) ... On/off, 24hrs or 12hrs doesn't make a a noticeable difference.
What you do want to do is NOT make it a habit of texting/phone while it's on the charger. That is the kiss of death on a battery.
Throw it on the charger before bed and let it rest. Also, make sure your display settings aren't set to destroy the battery (100% brightness, backlight set to more then 30 seconds/"always on" etc.)
it should be fine. Don't expect the battery to last days. Most batteries last *A* day in exchange for no memory cell =)
Good Luck
Jan 18, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
I have the same problem
Philips provides warranty for its products...rather than trying to repair it yourself,use your warranty.
Sep 09, 2009 | Philips GOGEAR SA6045 MP3 Player
Wont charge/hold a charge
That definitely is a battery issue. The battery is either Low Soc or it is a failed battery. Most batteries on PDA's usually fail within a year because of the immense amount of use the phone has and the majority of the time the batteries are smaller in a PDA. Take your battery to a service center if one is in your area or call your carrier and inquire about the warranty on batteries (usually 1-year).
Dec 26, 2008 | T-Mobile Dash Smartphone
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
177 people viewed this question
 Grubhead
Grubhead
