I m using casio DS-2L calculator,,my problem is when i m dividing my answer such as 3/2 answer appear 2 on calculator screen. no decimal is there...plz help to fix this problem
  • 3 Answers
My ds dosnt tern on and i bouht a new battery
Posted on Dec 29, 2012
SOURCE: The calculator won't convert fractions into decimals
Are you using a ti-89? If so, check your mode settings and change Exact to Approximate.
Posted on Feb 09, 2009
  • 4 Answers
SOURCE: Any way to make decimal answers the default? (casio fx-83ES)
you want a line output
Shift > Mode > 2:LineIO or on the graphics one its sometimes 10:LineO etc.
look for something with line in it
Steve :P
Posted on Aug 28, 2009
wilsonp195
  • 3 Answers
SOURCE: I am using FX-83GT calculator when I divide a few
Try using the S<>D(above the orange DEL button) button after you've obtained your result..
Posted on Aug 22, 2010
  • 102366 Answers
SOURCE: how can i change this
To convert a single value, press the S<>D key. To have all answers come out in decimals, press 2nd MODE 2 to select LineIO.
Posted on Aug 23, 2010
  • 102366 Answers
SOURCE: i have a fx-300ES casio
Press SHIFT MODE 2 to select LineIO mode. Now all results will come out in decimal form.
Posted on Aug 31, 2010
I keep getting a fraction for my answer when dividing on my casio fx 115 calculator how do i set it to get a decimal
To convert a single result from symbolic to decimal, press the S--D key. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Apr 05, 2011 | Casio FX-115ES Scientific Calculator
I have Casio fx-83ES. I'm using it in Mode 2 - LineIO, so answers are always displayed as decimal. However if i enter the sum 3.33 divided by 1000, the answer is displayed as 3.33x10^3 whereas really i...
You can configure it as you wish. Press [SHIFT][MODE] to access the (SETUP) configuration screen, then select [8:Norm].
You will be prompted to choose Norm1 or Norm2. To help you find out which is more appropriate to meet your concerns, I am inserting a screen capture from the manual.
Apr 05, 2010 | Casio fx-300ES Calculator
When I divided a problem EX. 3/2 the calculator will not answer in decimal
You are not dividing problems, you are dividing number. This said, there is a simple way to ensure that the results of divisions are displayed in decimal form: It consists in putting a decimal mark (decimal point) at the end one integer (whole number)
ex:
3/2. gives 1.5
3./2 gives 1.5
3./2. gives 1.5
You can also configure your calculator to display all numerical results in decimal format. To do that press [MODE][F2]. Use the down arrow to select the ligne Exact/Approx, then use the right arrow to unfold the menu options 1:Auto
2:Exact
3:Approximate
Select 3:Approximate and press [ENTER]
Hope it helps.
Nov 15, 2009 | Texas Instruments TI-89 Calculator
Say for instant i wanted to do a promblem 75 divided by 100 = 3/4 i want change answer that is a fraction to a decimal i can the answer clear
75/100 [=] gives 3/4. Press [S<->D] key to convert to decimal 0.75
0.75 [=] gives 0.75 Press [S<->D] key to convert to fraction 3/4
It can convert radicals into decimal and decimals into radicals.
Hope it helps.
Sep 28, 2009 | Casio fx-300ES Calculator
When I try to divide numbers that would leave a remainder like 1 divided by 6 which should give me an answer like 0.16666666666 instead all it says for an answer is 1/6. it does say in the manual to input...
To convert from fractions to decimals, and from decimals to fractions use the [S<-->D] key. If you want your decimal results to have a fixed number of decimal places press [SHIFT][SETUP][6:Fix]. Screen shows Fix 0~9. Enter the number of decimal places exemple 3.
Dans ce cas 1/6 is displayes ase 0.167.
Hope it helps.
Sep 23, 2009 | Casio FX-115ES Scientific Calculator
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
From fraction to decimal form
yo whatz good playa.. just click Shift, mode, then click 2.
Oct 01, 2008 | Casio FX-115ES Scientific Calculator
Division
it took me a while to figure it out too but i found out how. Put in, for example, 3 divided by 2. You get 3/2. Then press the button right above DEL. (it says S<=>D) and it will convert the fraction to a decimal. To change the number of decimal places shown, push SHIFT then SETUP then 6 then a number from 1-9 and that is how many decimal places will be shown.
Aug 29, 2008 | Casio FX-115ES Scientific Calculator
46 people viewed this question
jasbo
jasbo
