LG WD-1438RD. Water is not entering detergent drawer at all. IE error shows up and we've cleaned the inlet filter, opened tap fully, all taps in house are running wAter. We live in town and are in town water. Water is entering the drum but not the detergent drawer. Please help
  • 210 Answers
SOURCE: LG WM-2277HW Water overflowing from soap drawer (compartment)
The water dispenser compartment is connected to a hose. Disconnect the hose where it attaches to the tub. You will find a gray mushroom valve, remove this completely or you can just cut back the rubber that covers the stem halve way. What is happening is the valve is getting stuck in the up postion, and causing the water to poor out the front. You should also be running a hot wash every so often to clean out the unit.
Posted on May 30, 2008
  • 5 Answers
SOURCE: cloged inlet filter
You can also buy new filters to replace the old inlet filters from Home Depot. They are not LG brand they are "generic" filters but they do work. LG does not supply these filters the only way to get them from LG is to purchase the entire inlet valve (keep in mind you have 2 hot and cold) to obtain these filters. You can call the parts dept 888-393-6484 and get the part numbers for these valves and a distributors phone number so you can purchase the valves from them. Hope this helps.
Posted on Jun 06, 2008
rpbuice
  • 161 Answers
SOURCE: Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Posted on Jan 08, 2009
SOURCE: Haier XQB55-10 : water leakage from inlet hose jointer
Inside the connector is a flat washer and a mesh filter. one side of the mesh filter has a strip/bar across it, this filter goes into the base of the connector with the strip/bar upwards, make sure it is seated in the connector properly.
Then fit the flat washer ensuring that it is clean/undamaged and lying flat at the base of the connector, the mesh filter strip/bar has at either end a small lip, the washer goes underneath the two lips, if it is placed on top of these lips it leaks!
99% positive on this, if not buy another hose!
Posted on Mar 16, 2009
frederiquema
  • 76 Answers
SOURCE: The machine keeps indicating a closed water tap!
chek ur whater temp on ur sicle and then if dont work just turn the taps fuul power
Posted on Nov 19, 2009
Lg washing machine ie fault
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters
Dec 03, 2016 | LG Washing Machines
ERROR CODE 1e
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate
You may try the following link, too http://www.lg.com/us/support/answers/front-control-top-load-washers2013/control-panel
Sep 19, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My fuzzy logic LG washing machine, is no longer spinning or washing the clothes its showing error
Check another faucet in the house to make sure your household water pressure is adequate.
Reference:
May 19, 2015 | LG Washing Machines
IE error on wd1484adp
LG's 'IE' stands for '(water) Inlet Error'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB
Jun 15, 2012 | LG Wd-1484adp 8/4kg White Direct Drive...
I keep getting a code IE, tried all cycles but none works
Hi Alice from retired Englishman in SW France,
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 25, 2011 | LG Washing Machines
What does "PE" error message
LG's 'PE' refers to '(water) Pressure Error'
John C
Jul 18, 2011 | LG WD-16115FD Front Load Washer
Power went out during a cycle and when I got home the IE was flashing. The washer will not complete a cycle now. Gets to 15 minutes and stays
LG's 'IE' decodes as 'Inlet (water) Error'
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
John C
Jun 20, 2011 | LG WM2233H Front Load Stacked Washer /...
The machine is indicating an IE fault
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly wm_inlet_filter_removal(1).jpg
Mar 02, 2011 | LG WD-1280FHD Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
IE Err
In my LG Manual, They IE error is water inlet trouble.
Possible causes
  • Water supply is not adequate in area
  • water supply taps are not completely open
  • water inlet hose are kinked
  • the filter of the inlet hose are clogged
Solutions
  • Check another tap in the house
  • Fully open tap
  • Straigten hose
  • check the filter of the inlet hose
Not sure if this helps, it's what is says in my book.
Good luck.
May 27, 2008 | LG WM1815CS Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
