Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
4 red blink on Sony KF-50WE620
Need to know on witch board is situated my trouble and what parts are to be check. Then know what's the process to follow for been sure to check every details. Best Regards Fred
    Top Expert:
  • Sony Master
  • 14,553 Answers
The problem (4 blink error code) on this set is rather generic---it will point to several areas none that are specific----you may be expecting too much as this is typical----again the error code only points to general issues like change this board and then that board and may not even fix the problem.
You might actually be better having a tech or a shop look at the set, sorry if this answer is not what you wanted but it is the way this set is made.
Posted on Dec 03, 2012
5 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Sony KF-50WE620 - 5 Flashes
5 blinks code shows problem with Lamp Drive circuit (ballast supply) and / or Lamp itself.
How old is this TV and have you replaced lamp before?
Posted on May 31, 2009
  • 59 Answers
SOURCE: KF-50WE620 Green light blinks (no image) lamp light blinks red
Your owner's manual for the television will contain a troubleshooting section that will describe the blinking codes for the various lights, and what they mean.
However, in your case, it probably means the light is burned out.
The bulb on my TV tends to burn out about every 16 months (I watch TV for many hours per day, so your experience may be different). If your TV is still under warranty, I would suggest you contact the store where it was purchased, or contact the manufacturer.
Posted on Jun 20, 2009
dduncan774
  • 760 Answers
SOURCE: I HAVE THE SONY GRAND
A 6 blink error code on this model is letting you know that your G1 board is not putting out your +17 volt supply. You can inspect that circuit if you are experianced, or just swap out the board.
Posted on Apr 01, 2011
Testimonial: "THAT IS JUST WHAT THE REPAIR COMPANY I CALLED SAID ....I JUST FOUND ONE ONLINE FOR ABOUT $150"
Kensolutions
  • 455 Answers
SOURCE: model# kf-50we620 no sound,no picture, red light
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Jul 08, 2011
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
I HAVE THE SONY GRAND WEGA MODEL# KF-50WE620 WHEN I HIT THE POWER BUTTON IT BLINKS GREEN 6 TIMES THEN RED 6 TIMES AND WILL CONTINUE TO BLINK RED 6 TIMES OVER AND OVER
Apr 01, 2011 | Sony Grand WEGA KF-50WE620 Television
I have the Sony KF-50WE620 projection tv, its 2004 model and suddenly doesn't work anymore. When I turn the tv on, the light steadily blinks green and there is a strange shattering/windchimey sound that...
it could be the lamp but it might also be what is called the color wheel.. have you checked the lamp .,, have you removed and physically looked at the lamp. also does the light blink after shutdown.
Oct 13, 2010 | Sony Grand WEGA KF-50WE620 Television
My Sony Kf-50we620 TV seems to have lost its brightness. is this something that can be fixed?
Needs a new lamp or an optical block rebuild. May aslo have dust on the parts inside making the picture darker than normal
Feb 01, 2010 | Sony Grand WEGA KF-50WE620 Television
Blinking red light indicating "Lamp"
hello !
The video section has a problem and has to be changed  this circuit board has control of the  all system ie lcd,sound, switches  so if faulty the standby light will blink or not show at all .
I don't think there is anything wrong with the power supply .
good luck dude
Oct 16, 2009 | Sony Grand WEGA KF-50WE620 Television
Jun 20, 2009 | Sony Grand WEGA KF50WE620 Television
May 31, 2009 | Sony Grand WEGA KF-50WE620 Television
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
KF-50WE620
Clarification Request by welcomejee, posted on Oct 26, 2008I couldn't understand what exactly you looking for?
What kind of diagram you need?
Please let me know with bit detail.
Oct 26, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
18 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
