Question about Maytag Centennial MTW5800TW Top Load Washer
Maytag centenial washer noisy during wash cycle ( sounds like banging noise )quiet during spin cycle
Noisy during wash cycle (sounds like banging ) quiet during spin cycle
SOURCE: Noise
I have a PAV2300 and I recently experienced a grinding noise. Turned out to be the pump pully has a sleve between the pully and the bearing that has slid out of position. I took the pump out and using a small bladed screwdriver, wedged it between the selve and the base of the pump and working my way around it several times, managed to press it back into place. On the PAV2300 the pump is in the back of the unit. Looking at the picture the sleve is between that pully and the black base. Hope this helps. Good luck :)
Posted on Feb 28, 2007
duby1990
  • 367 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
SOURCE: Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Posted on Dec 31, 2008
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
Maytag quiet series 100 noise during washing
Roaring noise must also come during the spin cycle I suppose...it seems your bearing and or drive belt/gear is causing you this noise. To fix this, you would need to completely disassemble the washer and inspect the bearing and or drive box that activates the turning motion. It is a large job.
Dec 02, 2013 | Maytag Washing Machines
Thunping or banging noise during wash cycle may tag MVWC300VWo quiet during spin
You will need to pull the basket and check the drive block.
Here is a video to show you how to get to the drive block.
Dec 03, 2012 | Maytag Washing Machines
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
OK during wash and rinse cycle but suddenly became very noisy during high speed spin cycle
If noise occurs only during spinning cycle, then the 2 bearings and seal need to be replaced.
May 23, 2010 | Maytag Neptune Washer
Maytag Neptune front load washer model MAH3000AW, load during spin cycle
YOU MEAN LOUD DURING SPIN CYCLE? IF THAT SO, WHAT KIND OF NOISE? BANGING NOISE MEANS YOU HAVE UNBALANCED LOAD OR ONE OF THE SUSPENSION IS BAD OR FELL OFF. GRINDING NOISE MEANS YOU HAVE A BAD TUB BEARING, TO REPLACE THAT, YOU HAVE TO REPLACE THE WHOLE REAR TUB ASSEMBLY, VERY COSTLY. MEANS YOU PROBABLY BE BUYING A NEW WASHER.
BOYNISMO@YAHOO.COM OR 714-334-1998
Jan 14, 2010 | Maytag Washing Machines
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Maytag Neptune model # mah6500aww: makes banging noise and causes machine to move
A loud banging sound in the pipes is usually caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The banging happens as the water hits the valve that prevents it from going any further. If the kinetic energy is great enough, it can actually cause a pipe to burst or explode at the end. If a valve is closed near the beginning or in the middle of a system, the water keeps flowing after that point, and it can actually create a vacuum. This vacuum can cause a pipe to implode if the stress is too great. Roaring type noises may be coming from a spin bearing. This bearing probably had the grease washed from it because of a tub seal leak.
Squeaking sounds in a new washer are usually caused by the new parts getting broken in, and will usually go away after several washes.
The sounds of water gurgling, slurping, or sloshing during a spin cycle are usually caused by the drain pump pushing the water out of the washer tub.
Too much water pressure can cause a whistling or squealing sound. Adjust the hot and cold intake water valves to relieve this sound.
Metallic clinking sounds during spin or agitation may be the result of drive train components meshing during speed changes or after a pause.
Swishing or swooshing type of sounds may be caused by water and suds trapped between the tub and basket during a spin cycle, and will usually clear up as the water is drained from the washer
Jul 29, 2008 | Maytag MAH6500 Neptune Front Loading...
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Maytag Centennial MTW5800TW Top Load Washer Logo
320 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
