Question about Sony Grand Wega 50 in. Diagonal Class Full HD SXRD Rear Projection
Hdmi 6 and 7 do not work
Plugged in hdmi from video game to tv and when done plugged back the hdmi from cable box to tv and no longer works. just shows video 7 on upper corner of screen with no picture but has audio
    Top Expert:
  • Sony Master
  • 14,553 Answers
HDMI does not like connections made with units powered and or on.
Try removing power from the units connected and the set for a while, reconnect them and then connect power to see what happens.
Most Sony sets have a reset but try the suggestion above first.
Posted on Dec 03, 2012
3 Suggested Answers
  • 4234 Answers
SOURCE: While changing channels the picture went dark on
The video inputs are controlled by switching ICs inside the set. It is possible that one or more of the ICs is defective. Also, some sets buffer the inputs. The buffers could be defective as well. This problem will take a little investigation inide the set with a scope to see where the signal is lost. It is repairable and should not be too expensive.
Dan
Posted on Aug 20, 2009
SOURCE: Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Posted on Sep 26, 2009
Having issues setting up the PS4 can't find the hdmi slot same size as the hdmi wire that comes with the console. Hdmi wire and tv shown in pic
  • Connect the included HDMI cable to your TV and the PS4's HDMI Out port Connect your console to your cable or satellite box Unplug the existing HDMI cable connecting your cable or satellite box to the TV and plug it into the PS4's HDMI In port Plug the PS4 into a power source Power on the PS4 Plug the controller into the PS4 using the included Micro USB cable Press the PS button on the controller to pair it with your PS4
Jan 10, 2017 | The Video Game Consoles & Games
My ps3 will not put out any audio or video
Have you changed your settings from hdmi back to normal you should try both hdmi and scart or av on your tv, if this doesn't work then you need someone with a ps3 that works (you need your ps3 and a spare tv) and you can copy what theres does but you need to be very precise or look on you tube to see how to restore your ps3 back to the factory settings. I hope this helps mines done the same and it worked for me.
Apr 04, 2012 | Sony PlayStation Video Game Consoles &...
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
Sep 14, 2009 | Sharp Televison & Video
Aug 04, 2009 | Sony KDS-R50XBR1 50" HDTV
PS3 no longer communicating with TV
The problem is with your PS3 itself.
If it's still under warranty, take it back.
May 30, 2009 | Sony Playstation 3 (PS3) Console
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
Can't get video via HDMI
Go to here
will tell you how setting Video output
Nov 12, 2008 | Sony Playstation 3 (PS3) Console
Having trouble playing my Ps3 on a non HD tv after already using it on a HD tv
Hey bro try going down to circuit city, best buy and get the HDMI cord that converts to a Component cable on the opposite end. You can do this as long as the back of the non H/D tv has the Component Inputs on the back of the TV. If that does not work get the HDMI cable that converts on the opposite end to a S Video signal and connect that end to the S Video input on the back of your tv. I have seen these cables at circuit city in the playstation section. Again on one end of the cable it has your HDMI input to connect to your ps3 and on the opposite end of the cable it has the S video plug to run to the back of your tv and plug it into the S Video input. Same thing can be said for the HDMI on one end of the cable and the Component cables on the opposite end to run to the back of your tv. This will work if you find those cables. Good Luck.
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Grand Wega 50 in. Diagonal Class Full HD SXRD Rear Projection Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
