Question about Cameras
Good day. just removed my memory card from my camera and when i inserted in my card reader, all of my files were merged to 1 file, the USBC file. how do i retrieve my pictures?
Phone memory card
  • 890 Answers
Let try using the Free Memory Card Recovery software and check if that helps. Also try inserting the memory card in the Camera and connect it to the Computer and check the operation.
http://memory.brothersoft.com/memory-card-recovery-software.html
Posted on Dec 03, 2012
4 Suggested Answers
  • 155 Answers
SOURCE: "incompatible jpeg image" message
Unfortunately Windows in particular can mess with the contents of the card just by reading it - it creates a thumbnails file on the card without asking etc etc.
It shouldn't mess with the actual pictures unless you have rotated them or perhaps removed the card without safely removing the hardware first.
Try reformatting the card on the camera and you should be good to go from there.
Posted on Feb 08, 2009
SOURCE: memory card not initialized
Card not Initialized
Posted on Apr 16, 2009
  • 102366 Answers
SOURCE: Took pictures on camera without inserting card, no cord
Yes, there is.
Insert the card into the camera. Make sure the storage location is set to internal memory.
Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option, then press OK.
Note: this process is actually a copy, not a move. The originals will still be in internal memory. After you transfer the pics to your computer, you can then delete them normally.
To change the storage location, press the Menu button. Press up/down to highlight Image Storage, then press OK. Select Internal Memory and press OK.
Posted on Jun 17, 2010
Testimonial: "Exactly what i needed to know. Thanks!"
Mu computer is windows 7 professional
Marie, If your computer is not equipped with a SD/Micro SD card Reader you will have to purchase one to simplify looking at it and copying it on computer. You can also use appropriate cable possibly to hook your camera up to computer.
Step 1/ Insert a USB card reader into an available USB port on your PC.
Step 2/ Insert the micro SD card into the card reader. Some card readers will only accept standard SD cards. If that's the case, insert your micro SD card into an SD card adapter and insert the adapter into the card reader.
Step 3/ Click "Open Folder to View Files" in the Auto Play window to launch Windows Explorer in the appropriate drive letter. Alternatively, press "Windows-E" and click the card reader's drive letter.
Step 4/ Drag and drop files to or from the micro SD card's drive letter to copy files. Alternatively, right-click and drag files and then select "Move Here" to move the files without keeping the files in the original location.
Step 5/ Select a file, press "Delete" and select "Yes" to delete files from the micro SD Card.
Step 6/ Right-click the micro SD card's drive letter and select "Eject." Once ejected, you may safely remove the card.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Transfer Pictures From MicroSD Card to PC
How to use card reader
Card Readers Adapters
Memory Card Readers
Aug 20, 2016 | Cameras
Memory is full and I want to clear the memory
Do you mean your memory card? If so,your best bet is to get a usb dongle that can accept multiple types of cards and then use that to access it. You can also scroll through your pics on your camera and delete them as well.
Feb 16, 2015 | Cameras
Pdr m700
Hi Lorinda,
There are a few different reasons why your camera may not be reading the memory card.
Troubleshooting such problems can be a little tricky, especially if no error message appears on your camera's screen.
The cause and solution may include one of the following:
    ·The card may not be the right type for the camera: First make sure the memory card you are using is compatible with your camera. For example, a SDHC memory card often will not work with older memory card readers. Even though SD memory cards are similar in size and shape to SDHC cards, they use different software for managing the card's data, meaning older readers sometimes cannot recognize the SDHC cards. Sometimes you can solve this issue by updating the memory card reader's firmware to give it the ability to deal with SDHC cards. Check the Web site of the manufacturer for your memory card reader to see if new firmware is available. It is also a good idea to check with your camera's manufacturer (on it's website) to see if an updated version of your camera's firmware is available.
    ·The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
    ·The card or a file on the card may be corrupt. Photo file corruption can occur when the battery power is too low when writing a photo file to the card, or when the memory card is removed while the camera is writing a photo file to the card. One way to check if it is the card or your camera is to try moving the memory card to a computer, then try accessing the photo file directly from the computer to see if the file actually is corrupted, or if your camera is just unable to read a particular file.
    You can also double check this issue by using another memory card in your camera and see if it works as it should. If the memory card is unreadable on any device, the next step is to reformat the memory card. Look through your camera's on-screen menus to find a "format memory card" command. However, keep in mind that formatting the card will erase all photo files stored on it. Some cameras just work better with a memory card when that memory card is formatted inside the camera. If you do reformat the card, make sure to let the process finish itself before removing the card. Removing a card during formatting may damage the card.
May 01, 2014 | Toshiba PDR-3300 Digital Camera
Can i update camera firmware through a printer dock?
Kodak does not suggest a firmware upgrade through a printer dock. Instead, they recommend using an SD card (memory card).
First:
  1. Click Download, then save the firmware file to your computer desktop.
  2. Double-click the *.exe file. When the WinZip Self-Extractor screen appears, select a folder or accept the default location, then click Unzip. The firmware file unzips to the specified folder.
  3. Note the location of the *.FW file, then close the WinZip Self-Extractor.
Instructions:
  1. If you have pictures/videos on your camera's internal memory or on the memory card, save them to your computer.
  2. Ensure that your camera batteries are fully charged.
  3. Turn off your camera.
  4. Insert the memory card into your computer or into a card reader attached to your computer.
  5. Verify that the memory card has at least 100 MB free space.
  6. On your computer, select the removable drive associated with the memory card or card reader.
  7. If a System folder does not exist on the memory card, create one. From the removable drive window, select File > New > New Folder, then name the new folder System.
  8. Copy the *.FW file from your computer into the System folder.
  9. Remove the memory card from your computer or card reader, then insert it into your camera.
  10. Turn on your camera, then follow the instructions to begin the firmware upgrade. The upgrade takes approximately two minutes to complete.
  11. When "Upgrade was successful" appears on the LCD, select Delete Upgrade File to delete the firmware file from the memory card.
  12. Turn off your camera, then turn the camera on to activate the new firmware.
Feb 07, 2014 | Kodak EasyShare P880 Digital Camera
Download photos computer
Download photos from any camera is highly unrecommended because that quickly disharges the camera battery. Instead, turn camera off and then open battery door. See picture memory card at camera edge, push in and release to pop up. Then, draw card out of the slot taking care to avoid finger contact with contacts. Close battery door. No insert card into card reader on computer. (Most computers these days have built in reader. USB interface readers can be purchase at low cost.)
If the upload start up dialog does not auto star, then open Computer and double cick open it there. A menu will appear offering wholesalee import you can chose Review Folders in Explorer. Once opened, photos can be handled and stored ot computer like any other file. It is preferable to copy files as opposed to moving them, using camera itself to delete files. Now close Fuji folder and initiate safe removal. When approved, remove memory card and reinsert in camera. Question answered.
Jan 26, 2014 | FUJIFILM FinePix JV100 Digital Camera
SD card got infected by USBC
This program may help.
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
  • Put the memory card into an USB card reader and plug it into the USB port in your computer, then run the Recuva program.
  • Simple to use interface - just click 'Scan' and choose the files you want to recover
  • Easy to use filter for results based on file name/type
  • Simple Windows like interface with List and Tree view
  • Can be run from a USB thumb drive
  • Restores all types of files, office documents, images, video, music, email, anything.
  • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
  • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
  • Restores files from external ZIP drives, Firewire and USB Hard drives
  • It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuva http://download.cnet.com/Recuva/3000-2242_4-10753287.html www.filehippo.com/download_recuva
Mar 11, 2013 | Cameras
I receive a "communication error"
To address the present problem make sure the camera is off before plugging in the cable either to the computer or the camera. Also make sure the batteries are up to charge, low batteries or batteries that fail during file transfer will corrupt the memory card. With batteries up to charge plug the cable into the camera and the other end into a USB port and turn the camera on. Now, I would like to suggest that you invest in a memory card reader these are fairly inexpensive and can be bought as a single reader for the type of memory card you have or as a multiple card reader for pretty well every memory card that's on the market. To use a Card Reader it plugs into a USB port and the memory card is removed from the camera and inserted into the card slot. The computer recognizes this card reader as an external hard drive and files can be transferred to your computer Hard Drive with ease. One thing you must remember with any external device and that is you need to do a safe disconnect or eject make sure the device is shut off and the file information is downloaded before you remove the memory card or the files/card can become corrupt. Okay once the transfer is completed insert the memory card back into the camera and format the memory card. Don't delete the pictures at this point Format the memory card. Every time you download the pictures to the computer Format the memory card.
Jan 14, 2011 | Canon PowerShot SX20 IS Digital Camera
How to remove usbc??? file from a memory card without formatting|?
want to get rid of usbc file from my pendrive...... but how... i had lots of important files in dat file which now shows only one file dat is usbc file... how to get out of this problem
Aug 02, 2010 | Computers & Internet
Have a olympus sp-56 ouz digital camera and I can't figure out how to delete videos taken on the camera. I've already transfered them to my computer and I've deleted all images, but it won't delete the...
Hello, The videos will not be in the same folder where your pictures are. Follow these steps. 1.First, connect your digital camera to your computer. You can do this in two different ways: a.Use a USB cable. Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer. The first time you connect your camera to your computer, the New Hardware Wizard will help you install the software needed to copy pictures and video from your camera. You may need to insert the CD-ROM that was included with your camera into your computer's CD drive or download software from your camera manufacturer's Web site. b.Use memory card reader. A memory card reader is a piece of hardware that plugs into your computer. When you're ready to download video, you can remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk. Picture of a computer with a memory card Tip: It's usually faster to use a memory card reader to copy your pictures or video than to connect your camera to your computer with a cable. If you don't own a memory card reader, you might want to consider purchasing one. They are inexpensive and will save you time. 2.Once you've connected your camera to your computer or inserted your memory card into your memory card reader, Windows XP will detect the connection to your memory card and ask what to do with your videos. Click Open folder to view files, and then click OK. Click Open folder to view files, and then click OK 3.Windows Explorer opens, showing your memory card. Your videos are contained within one of the subfolders of the memory card. Double-click each folder to locate your videos. 4.Once located. copy them to your computer and then select all and delete. Please rate my solution. Good luck, Jegan
Jun 04, 2009 | Olympus Cameras
Cameras Logo
225 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
