Question about JVC TH-C50 System
Our DVD/Receiver won't turn on and its not a power cord/pluggin in issue...
Not that it matters I guess, but we have a JVC Th-C50 and it... just won't turn on now ... Not sure what's up, worked fine last night -- red light was on standby, no big, came home from work and it wont turn on. we've tried plugging it into different plugs, we've tried separating the subwoofer and plugging that in ... also nothing. The whole unit seems just dead... and not sure what else to do. We're looking into getting another system probably tomorrow - but my husband wants to try and fix this one... any tips on what it could be? I read one comment on amazon about this unit -- a guy said he had the same problem with it. We think the subwoofer is fine -- but the main unit dvd/receiver doesn't seem to be getting any power. Anyways.... any help/tips you can give is much appreciated.... thank you!
  • 16 more comments
  • Anonymous Nov 20, 2007
    yes i do have same problem
  • cin3dee Nov 24, 2007
    I too have the same issue on this system. Mine is only 7 months old. Nothing but trouble with this junker! If anyone knows where to find the fuse , please post asap. Thanks
  • bohdawg Dec 04, 2007
    Working fine in the morning and then get home and it won't turn on. Anyone figure out the issue yet on this? Or what your fix was?
  • snubber Jan 03, 2008
    junk sold at visions th-c50 wont turn on 15 monthes old
  • Laura Griffith Jan 25, 2008
    actually, *months later* we have a solution to all this
    Yes, the fuse burns out. Seems to happen whenever its unplugged and then replugged in, or theres even the tiniest of power spikes....
    great quality huh?
    Go to ur local radio shack -- pack of new fuses is only a few bucks and u can pop off the cover and install the new fuse right below where the power cord comes into the dvd player.
    Its a quick fix and lasts until ur next power problem -- but seems to be a manufacturer problem.
    Note -- the fuse currently in there is white...u cant see if its burntout. replace it anyways, with a newer fuse that has a transparant case so u can tell later if its burnt out.
  • MrRon57 Mar 06, 2008
    The other night the right front speaker went out then a few day later no sound at all. the video still works but no sound, The subwoofer (which drives all speakers) is dead. The fan doesn't blow, the power LED won't light. I've checked 3 fuses in the subwoofer, all good. What now>
  • culp1961 May 04, 2008
    We have one too that blows the fuse almost immediately. We think it has to do with the motor for the dvd player. Thats were the problem started. We opened it up and couldnt find anything obvious.
    Any ideas?
    Bill
  • jon42 Jul 28, 2008
    Thanks, for the info, I checked the fuse in the receiver and replaced it. That was definitely the problem. I was ready to throw it away, it's been that way for months, and repair shops charge you more to fix it, than what its worth. It's working fine
  • helpmyjvc Aug 26, 2008
    Having the same problem. I went out and bought new fuses but once I put them in, plug in unit, the fuses blow immediately. Unit is only 14 months old. I will chuck it before I take it to an authorized dealer. Can anyone offer another suggestion. Always been a jvc fan but this problem is souring me. Thanks everyone!
  • sueabbiss Oct 17, 2008
    We have the same problem. We replaced the fuse, and when we turned the system on, the fuse blew. We got the slow blow kind. What else can we try? We only use our unit to control the volume. We have probably used the DVD player 3 times and the VCR twice. Sounds really strange that it would just stop working.
  • curry07 Nov 28, 2008
    I have a thc40. since new got the run around on repairing or replacing the unit. I checked the fuse w/a meter it checked fine. any other suggestions as to what my problem may be?(no standby light,no power,but have power to both sides of fuse.
  • Anonymous Dec 24, 2008
    I had the same problem, after moving. I replaced that fuse and it works fine now.
  • Anonymous Jan 16, 2009
    my receiver lights up blue then goes back off changed fuse but it still happens
  • madtownJump Jan 25, 2009
    I also have no power, but the fuse checks out fine. I have a rental DVD stuck inside the unit that I cannot get out and don't particularly want to completely ruin the DVD/Home Theatre center to get it out, but what are my options?
  • jms_glsby Feb 10, 2009
    The unit was working fine then just shut down. Every now and then the stand by light will come on then go off. Seems not to be getting power, tried other plugs and the same thing happens. I will try replacing the fuse and see if that does it.
  • Anonymous Feb 25, 2009
    the fuse its 1000 ok but stand by line come off and not working dvd
  • bses Jul 27, 2012
    RadioShack 4 bucks
  • bses Jul 27, 2012
    RadioShack 4 bucks
I had the same power problem with my th-c50. In fact, this is a common problem with this model Home Theater In a Box (HTIB). The issue truly is the fuse. All you have to do is take the cover off and replace the fuse. There are approximately 8 screws total to take the cover off and you can do it with a standard phillips screwdriver. Once the cover is off, the fuse you need to change is underneath and slightly to the right of the power input (if the box in on your lap with the front facing away from you). The stock fuse is a ceramic, white fuse and if you aren't familiar with fuses, it looks like a very small cylinder. The model number is T1AH250V. These numbers mean that it is a 1 amp, 250 volt ceramic fuse, 5 x 20 mm in size. The fuse is held together by four metal posts. Bend the posts back to take the fuse out. Go to Radio Shack or your local hardware store and get a replacement fuse with the specs above. The problem that I had is that none of my local hardware stores had a ceramic fuse with these specs, only glass. I bought the glass fuse anyway (T1AL250V) and it works beautifully. Be sure to buy a "slow blow" fuse instead of a "fast acting" as they are more durable. Insert the fuse into the slot, tighten the clamps, put the cover back on and your done! It doesn't take too long. Hope this helps.
Posted on Mar 11, 2008
    Problem Solver:
  • 5 Answers
You can order the fuse from JVC part # QMFZ059-1R0-E $8 after shipping.
Posted on Aug 05, 2009
    Problem Solver:
  • 5 Answers
I have a TH-C30. I had the same problem where the unit just stopped working - no standby light and no recognition of power at all. After checking this forum and another, I opened the unit, found the ceramic fuse where the power comes in and went to Radio Shack. They have a T1AL250V fuse pack that is a 1 amp, 250 volt, 5 X 20 mm SLOW BLOW glass fuse which is a better fuse for this common problem. Their RS number is 270-1063 and a pack of 4 costs about $3. Put new fuse in and the problem was solved.
The repair took minutes - 3 screws on the back and two screws on each side. Lift the cover from the back (it is slip-hinged on the front) and replace the ceramic fuse. It slips out with a little help and the new one snaps in place.
Posted on Aug 17, 2008
  • 3 Answers
One thing you can try, that will probably fix this bug for good: Install a "slow-blow" fuse instead of the standard one. The "slow-blow" fuses are made with a little piece of fabric, (of some sort, probably asbestos), stuck into the center of a coil of wire that makes up the fuse. the purpose being; the fabric prevents the fuse from overheating 'instantly', instead, it takes it a couple of seconds to blow at the time of an "over-draw" or "in-rush" of current. therefore the fuse won't be as susceptable to blowing out from a mere voltage spike. Just be sure to get a slow-blow fuse that's of the same, (or within 10 - 20%), value of the original fast-blow fuse, (e.g. fast-blow fuse = 10A @ 250VAC, then slow-blow fuse should = 10A - 12A @ 250VAC). I hope this helps!
Don
Posted on Feb 13, 2008
I have the TH-C50 and my unit would not start. I did what others advised (above) and installed the new fuse and now it's working perfectly.
Posted on May 16, 2009
I removed the cover from the receiver and check the fuse with a meter. It check fine. Reassembeled the unit, plugged it in, powered the unit and ALL IS FINE. I don't know if the fuse had worked itself loose (don't really think so) or just lucky.
  • 203 Answers
You could pull the cover off and check the fuse (Make sure it is unplugged first). If it has no indicators on it is likely in the input side of the power supply (Fuse, transformer).
Posted on Jun 08, 2007
Panasonic TV TH-L37S25A no power no red light, when plugged in and turned on at wall.
I'm guessing your power board went out and will need replacing. If you have the model number correct your going to have a hard time finding that board, I looked and couldn't find one anywhere, couldn't find that model listed
Feb 09, 2018 | Panasonic Televison & Video
How do you connect a jvc th-c50 hometheater to you tv?
By comparing the unnamed TV's manual and capabilities to those of the TH-C60.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-C50J-Home-Theater-Systems-manual/id/318ci575/t/2/
Jul 06, 2011 | JVC TH-C50 System
Cannot get sound. green cable is not connected. three cables connected together-- red and blue cables connected to aux in left and right. do not see where green cable should be connected. we just...
The actual color the head on a given cable is irrelevant as long as it connects an output to its compatible input.
Jacks on the electronics follow a common color code and are labeled for the color-blind.
Analog audio jacks are usually red (right) and white (left).
Composite video is usually yellow.
Red, green and blue are traditionally for Component Video. In other words, NOT SOUND.
A disconnected cable is usually a good reason for a signal to fail. But one should not guess where they go.
Get the basics set up first.
Mar 27, 2011 | JVC TH-C50 System
I cant download the manual for the JVC TH-C50
http://books.jvc.com/booklist.asp?Model=TH-C50
Aug 25, 2010 | JVC TH-C50 System
My jvc Th-c50 dvd player keeps blowing fuses. so i was wondering if there is a another fuse that i need to replace? My sub also goes mute after a awhile. could this problem be related??
Not sure about all of that but i was having problems with the fuse too. but i was t rying to replace the original ceramic fuse with a glass one and it wasnt working. so i called JVC and spent some time with them on the phone and finally found the part number for the ceramic fuse QMFZ059-1R0-E they are $8 after shipping if you want to try that. hope it works for you.
Jun 29, 2009 | JVC TH-C50 System
Jvc th-c50 home theater standby light blinks but won't turn on
you need to have service manual copy to check amplifier output section as it seems defective. There are few websites that offers service manuals download for small fee.
Jun 11, 2009 | JVC TH-C50 System
Jvc th-c50 won't turn on-already changed the fuse even though the old one had very low resistance when tested w/my multimeter.if unplugged for several minutes the stand by light will flash once when...
i was having a simalar problem and was trying to replace the ceramic fuse with a glass one and it wasnt working. i have found the part number for jvc if you want to try and order the ceramic fuse from them and try that. QMFZ059-1R0-E its $8 after shipping.
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
JVC TH-C50 System Logo
3,604 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
