Question about Alera Technologies Cruiser (270118) DVD±RW Dual Layer Burner
Can you help me remove a PT Cruiser battery with out any sisable signs of nuts/bolt? it slides but will not lift out of the car.
    Scholar:
  • 91 Answers
Thee is a mounting stud down by the bottom of the battery that holds a plastic retainer, a flat bar about two inches long. You have to reach down in with a 6 inch or more extension on a rachet to undo the bolt which I belive is a 13mm on these, but I cant remember for sure.
Posted on Mar 15, 2009
2.4 turbo pt cruiser timing belt replace
This is how I did it (twice) :
I disconnected the 4 downpipe bolts, then put two jacks: one under the oil pan and the other under the ******.....then removed the airbox and unbolt the two ****** mount bolts....then I lowered the ****** side as much as I could and lifted the oil pan side as much as I could, without damaging anything. With that you'll get plenty of room to remove that cast iron bracket.
Hotmail Support ' Hotmail Tech Support
Oct 02, 2012 | 2006 Chrysler PT Cruiser GT
How do I replace the battery on my 2004 pt cruiser?
Steps to replace the battery
Air Cleaner Removal
1. Loosen the air intake hose clamp (with a flathead screwdriver), which holds the intake tube to the air box lid.
2. Once the hose clamp is loosened, pop open the two spring-loaded clamps on the left and front side of the air box. The clamps help secure the lid to the air box. On the back of the air box lid there are 4 plastic slots, which match up with 4 corresponding tabs on the air box. In order to unhinge the lid from the air box, slide the lid away from you about an inch and gently lift the lid up. Ensure that the lid is free from the air box hinge; then carefully disconnect the air intake hose from the lid at the hose clamp and remove the lid from the engine compartment.
3. Lift the air filter out of the air box. 4. Disconnect the PCV hose from the lower air box.
5. The lower air box is removed by just tugging straight up on it. It will pop out as it's held in place by two rubber pins that wedge into the indentations in the plastic air box.
Battery Removal
6. Disconnect the battery terminals - negative 1st, the positive. 7. Remove the anchor bolt at the base of the battery using a 1/2" socket. 8. Lift battery out (with a battery carrier strap). Save the thermal blanket wrap to slip on the new battery.
Cleanup and Installation
9. Clean the terminals by dipping in a cup filled with baking soda and warm water. Use a battery terminal cleaning tool, wire brush to remove the corrosion or a tiny screw driver to scrape with. Rinse with water and clean up the tray with a towel.
10. Install the thermal blanket on new battery. Note the position of the notches on the blanket when replacing it. Lift into car and slide the battery as much as possible towards fender. Reinstall retaining bolt.
11. Install felt washers ($1) to prevent corrosion on the terminals
12. Reinstall terminals (positive 1st, then negative). Apply some grease or Vaseline to the tops of the terminals.
13. Reinstall air cleaner box. Carefully line it up and push down Make sure to seat it completely when you reinstall it.
14. Reinstall filter; cover. Make sure clips are on tight.
Thank you for using fixya and good luck
http://www.ptcruiserlinks.com/forum/pt-cruiser-videos/19853-video-how-replace-battery.html
Aug 05, 2010 | 2004 Chrysler PT Cruiser
Need procedure to remove and replace the battery in a 2006 PT Cruiser
BATTERY
GASOLINE ENGINE
REMOVAL
WARNING:
  • TO PROTECT THE HANDS FROM BATTERY ACID, A SUITABLE PAIR OF HEAVY DUTY RUBBER GLOVES SHOULD BE WORN WHEN REMOVING OR SERVICING A BATTERY. SAFETY GLASSES ALSO SHOULD BE WORN.
  • REMOVE METALLIC JEWELRY TO AVOID INJURY BY ACCIDENTAL ARCING OF BATTERY CURRENT
  1. Make sure ignition switch is in OFF position and all accessories are OFF.
  2. Open hood.
  3. Remove the air cleaner housing.
  4. Disconnect and isolate the battery negative cable then the positive cable.
  5. Loosen bolt (4) and retainer (1) that holds the battery down to the tray.
  6. Lift battery out of battery tray and remove from vehicle.
  7. Remove thermal guard (if equipped) from battery.
CAUTION: Vehicles equipped with the turbocharged engine use a unique battery hold down. If the replacement battery is not identical, in size to the original, it may be necessary to use non-corrosive spacers on top of the hold down retainer to properly secure the battery in the battery tray.
When replacing battery, the thermal guard MUST be transferred to the new battery (if equipped).
  1. Install battery in vehicle making sure that the thermal guard (if equipped) is present and battery is properly positioned on battery tray.
  2. Install battery hold down hardware (1), (2), (3) and (4) making sure that it is properly positioned on battery. Torque clamp to 12.5 N.m (110 in. lbs.) .
  3. Install battery cables on battery posts. Install battery positive cable first.
  4. Torque clamp nuts to 12.5 N.m (110 in. lbs.) .
  5. Install air cleaner housing.
  6. Close hood.
  7. Verify proper vehicle operation.
Jul 15, 2010 | 2006 Chrysler PT Cruiser
How does one remove the hold down on 2005 pt cruiser car battery. Please help
get a light shine in front of the battery and you will see a 13MM Bolt lossen that bolt and the battery should be free to move
May 03, 2010 | 2004 Chrysler PT Cruiser
2002 pt cruiser belt replacement diagram
Asked under 2001 Category for a 2002 Question.
Click on the following free direct Link. It has the correct Serpentine/Drive Belt Diagrams for your 2002 Chrysler PT Cruiser 2.4L DOHC In-Line 4-Cylinder Engine with the Engine Options (AC/No AC etc.). It also has Instructional and Directional Diagrams inorder to remove and/or replace the Belt(s).
Note: the differences between the Automatic Tensioner and those Tensioners with Adjusting/Locking Bolts/Nuts
http://www.2carpros.com/car_repair_information/year/2002/make/chrysler/model/pt_cruiser/2002_chrysler_pt_cruiser_drive_belt_routing_diagram.htm
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
Mar 28, 2010 | 2001 Chrysler PT Cruiser
Replacing a starter in a PT. Cruiser 2001
Remove battery and battery support you'll be able to undo starter bolt's trough there and slip starter out.
Dec 08, 2009 | 2001 Chrysler PT Cruiser
I need to know how to remove the battery from a 2006 PT cruiser. Havent' driven it in a while and the posts corroded. I need to switch the battery out for a new one, but I cannot seem to find the area...
there should be a plastic protective cover. You can release this by pressing in the tabes on both sides and slide the cover up and off of the battery. then you should find on bolt running through a plastic wedge that clamps the battery down. this will be located at the base of on of the long sides of the battery. you will need a ratchet, 6" or longer extension and a metric socket set. It will mostlikely be 12,13,14,15mm bolt. Hope this info helps.
Aug 17, 2009 | 2006 Chrysler PT Cruiser
2002 PT Cruiser battery removal
If you have a 2.4L LE or BE PT Cruiser, you need to remove the air filter housing by removing the clip. The tricky part is that the battery is held down by a clamp that requires you to remove the main electrical box and base. it looks harder than it is because it is simply two rubber grommets anchored to a metal plate. you can reach your hand underneath and feel for them, then push them upward through the anchor holes to release the base. you will see the clamp that holds the battery in place, just remove the two bolts that are holding it down and replace the battery with a new on and reverse the procedure
To prevent corrosion, generously cover the battery terminals with petroleum jelly. Yes Vaseline®!
You can see a video at;
http://www.youtube.com/watch?v=UPB4Rlik1UE
Jun 10, 2009 | 2004 Chrysler PT Cruiser
Starting problems
get alternator tested loosen pinch bolt on battery tray 13mm
Jan 11, 2009 | Alera Technologies Cruiser (270118)...
Replacing Alternator For 2001 Chrysler PT Cruiser (Manual)
this instruction is general for all vehicles. i am sorry that i do not have particularly for your 2001 chrysler PT cruiser.
first, identify the alternator.
remove the fan belt on the alternator,
label and remove all wires that is attached to it.
remove all bolts that is holding it.
remove the old alternator.
do the reverse on installing it.
tnx 4 using fixya,
drcool
Aug 30, 2008 | 2001 Chrysler PT Cruiser
Alera Technologies Cruiser (270118) DVD±RW Dual Layer Burner Logo
Top Alera Technologies Computers & Internet Experts
solver2010
Tom Chichester
Bill Boyd
Are you an Alera Technologies Computer and Internet Expert? Answer questions, earn points and help others
