Question about Garden
After installing my 44" snow blower on my JD 300X the lift pedal which has a lift assist spring will not reset to so that it works to lift and lower blower. Had installed blower the past two years without problems.
3 Suggested Answers
roadtech7
  • 297 Answers
SOURCE: I have a Arien's ST724
Jorge, You most likley have a Techuseh 7 0r 8 hp engine. The big problem is that it does not have a stator under the flywheel to allow you to charge the battery or run lights. So the cheapest way for you to add electric start is to buy a 120 volt strter that will just bolt on. You will have to use an extension cord to use it though. You can get the starter from any small engine shop. You just need the engine numbers when you are asking for prices and availablity. The instructions are easy to follow.
Hope this helps
Posted on Nov 10, 2010
SOURCE: Bolens model 3012H lawn tractor attachment install instructions
I don't know the answer to this question but I wouldn't mind getting one of those tillers for my tractor. If you ever decide to part with it let me know! j e s s e m e r s o n @ m y m a c m a i l dot com
Posted on Aug 12, 2011
All the gears quit working why?
What type of machine; Hydro or Friction wheel?
If the cable or the spring to the friction wheel broke that would explain all gears not working. Lift machine up so it rests on the auger and take the bottom cover off. As busy as it will look under there, it will make sense how things work after looking at it.
Feb 26, 2016 | Garden
Jd w2121 726 snow blower walk behind
Are you putting the right bolts in? Some bolts are just soft steel and will not take pressure.
Feb 11, 2015 | Garden
How to install. A snow plow and ordering a couple of parts for it
From the part numbers you post I gather it is a John Deere equipment and your local JD dealer will be your best bet getting instructions and parts for that snow plow.
Jan 01, 2015 | Garden
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
Error 44
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Nov 27, 2013 | Precor Exercise & Fitness
Error 44 precor eliptical 546
Corrective Action
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
C956i Precor is displaying Error code 44 ?
Corrective Action
May 30, 2012 | Precor C956i Treadmills with HR /...
How do i lower 65 rear suspension on type 1 beetle
Not too hard, but time consuming. You need standard and socket wrenches,
a length of chain, and a floor jack.
It would be best if you referred to a Bentley manual for the actual
torsion bar procedure. The only tricky part of the process is getting
the spring plate off of its lower stop. It's under a lot of pressure, so
you chain the base of the floor jack to the chassis, then lift the spring
plate enough to pry it out with a big screwdriver. Installation is the
reverse of this.
The torsion bars are splined with 40 splines on one end and 44 on the
other. You can turn the spring plate in 50 minute (5/6 degree)
increments by turning the chassis end one spline in one direction and the
spring plate end one spline in the other direction. You adjust in the
angle you want.
Jan 24, 2010 | Volkswagen Beetle Cars & Trucks
How to connect hydrolic lift to the 214 tractor from a 37a snow blower
Part of the blower when new and first installed was a
1) pivot bar
2) lift link from blower to pivot
3) lift link from pivot to center of the tractor
the pivot was to be installed on a pre-made bracket on the frame just inside the front grille. A hole in the front part of the frame allowed the longer lift link to attach to that bar and go to the center of the tractor. Those two pieces remain on the tractor as permanent, and the lift link from the blower to the pivot bar to be removed or installed as you intend to use the blower. If you have purchased the blower used, the original tractor it was installed on still has those pieces on it. Your local Deere dealer can provide the pieces if needed.
Dec 05, 2009 | John Deere Garden
My printer only prints the left side of my document
First try printing directly from the PC to the printer without using the JD. If the problem persists, then factory reset the print server and reinstall the appropriate print drivers onto it before reconnecting to it.
May 24, 2009 | HP JetDirect 300X Office Connect...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
