Question about Whirlpool Ovens
Code FSE 1 on Whirlpool Self-cleaning Electric Range
Problem code FSE-1
2 Suggested Answers
  • 5 Answers
SOURCE: whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Posted on Oct 26, 2009
F0E0 error code in Whirlpool self cleaning oven......what does it mean?
Analog to digital failure.
Disconnect panel for 30 seconds
If error re-appears...then replace control
Hope this helps...
Jul 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My oven has an error E1 F5. It was working fine until I tried to use the self cleaner. Now the oven and self cleaner will not work . Only beeps when I try to cut it on.
Hey I found your manual and error codes on-line and was surprised that Whirlpool did not have it hard to reach. Click Here=> Whirlpool 30 in Self-Cleaning Freestanding Electric Range Error Codes
Have questions please ask and rate this solution, Thanks Sea Breeze sea_breeze_128.jpg
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
Mar 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning stops after about 1 hr with error code F5E5
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Nov 18, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool self cleaning oven problem
Hi
Thanks for using FixYa. This error means that you’ll need to check the door latch/switch and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
Apr 11, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The oven won't lock shut for cleaning
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
107 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
