Question about NAD Audio Players & Recorders
I have nad 910 preamp processor.one of the sorround sound channel is not working
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: nad s200
It is most probably a dirty speaker protection relay. gently tap the relay(the one that engages shortly after turning the amp on) when the fault is occurring and see audio returns. This should ascertain the problem. Replace it if it is a sealed type, or if it has a "lid" you can get off, burnish the contacts with a white business card, and give it a spray with contact cleaner/lubricant. Good luck and a "fixYa" rating would be great for my profile :)
Posted on Feb 06, 2008
robotek
  • 1512 Answers
SOURCE: Gain on one channel stuck at max
Hi there
Check for a dry solder joint on one end of the vol control(earthy end). This will be causing your problem. The pot itself may actually be faulty to. You can always get stuff like that, just got to identify it. Check soldering to the pot first.
best regards
Graeme
Posted on Mar 24, 2008
SOURCE: PreAmp to Amp problem
Sorted it. You have to put the plugs back in the PreampOUt/Main in or it cuts out the pre-amp.
Posted on Nov 19, 2008
  • 85 Answers
SOURCE: Pop in left channel
Check your cabling,sounds like earth break
Posted on Jan 19, 2009
I get no sound from my nad t175 preamp connected to a nad t973 (7 ch.) regardless of the media - rca, hdmi, et al. The fuse in the amp is fine, all the lights are working. Regarding the t175 i can see...
Possible that the amplifier has tripped and so gone to a protection mode. Remove power for few hours, press down all panel switches to drain off voltage from the processor. Also check for any short on the speakers before it is powered on.
Mar 13, 2012 | Audio Players & Recorders
NAD C350, everything works after i replaced many blown parts except it has no sound output from any channel, just need some ideas on what to check for faults. thanks
With no background on the original problem and no details regarding what parts were replaced how can anyone answer the question?
What exactly does it mean if 'everything works' but it has 'no sound output'? As a two channel amp that would be its ONLY function.
The root cause for 'no sound' could be something as simple as a misplaced control (Tape Monitor?) or missing pre-out/main in links. It's in the manual.
Register and download it for free at retrevo.com
http://www.retrevo.com/support/NAD-C350-Amps-manual/id/8043dj589/t/2/
Jun 01, 2011 | NAD C350 2-Channel Amplifier
Nov 18, 2008 | NAD C320 2-Channel Amplifier
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
The right channel on my NAD intergrated amplifier C320Bee no longer works.
if you did test for your cable and speaker and you find it fine-your problem will be in output stage of your amp and needs aid of service center.
Jun 11, 2008 | NAD C320 2-Channel Amplifier
NAD T760
You should connect the RCA connectors from your turntable into the phono input of the preamp. Also, make sure you have the grounding wire from the TT connected to the grounding on the preamp (if you do not have a grounding point, then just connect it to one of the screws on the preamp). Then connect the output from the preamp to either the Tape or the CD points on the T760. On the front panel press tape monitor and you're done.
Check and let me know how it goes. My set up's working fine except for clarity, which still needs to be perfected. I'm using a normal step-up phono stage.
Regs/ Avinash
Mar 29, 2008 | NAD T760
Panasonic SA- AK 133 Music system sorround system not working
this is something a tech expert on electronics can handle. even replacing parts has to be attended by a pro-technician. something is wrong with your DSP processor or system components. it could be the switch only or it could be the processor.
Mar 29, 2008 | Audio Players & Recorders
Pop in left channel
Hi i don´t speak a good Englis but i think what you have a problem whit a filter in the preamplifier, just in the final amplification block, open it end check for any spill o exploded filter
Dec 03, 2006 | NAD T163 Amplifier
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
