Question about Watches
Turn alarm off stauer hybrid watch - Watches
5 Suggested Answers
  • 2501 Answers
SOURCE: I want to send my atomic stauer watch for repair.
Go to "Stauer.com" and at the bottom of the page you will find "customer service".
Click on this and your customer support details will appear.
Posted on Mar 20, 2010
escapement
  • 2334 Answers
SOURCE: Removing Links from the Stauer Atomic Watch band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please .
Posted on Apr 08, 2010
cmcduncand
  • 714 Answers
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Posted on May 14, 2010
small6363
  • 18392 Answers
SOURCE: How do I remove a link from the Stauer Colossus Hybrid Chronograph
Go to this link for instructions.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Posted on Oct 24, 2012
Hour, minute and second hands don't work, why?
Yes, there are two batteries in the 19093 (Compendium Hybrid). The first battery (CR2025) is visible as soon as you remove the back cover plate. The CR2025 controls the digital half of the watch and the back light. The second battery is underneath the circuit board that the CR2025 is connected to. There are 6 small screws that will need to be removed to lift the circuit board and gain access to the second battery. The second battery is an SR626SW.
Aug 22, 2014 | Watches
Removing a link from the wrist band of the Stauer Colossus watch is a task that requires some mechanical talent. The links are held together with pins. These pins need to be pushed out. I strongly recommend the purchase of a "Watch Band Link Pin Remover" (got mine on eBay for $7). Prepared with this tool, the steps are as follows.
a) Separate the wrist band at the position where the strap and latch are held together. Careful! This pin is spring loaded.
b) The links that can be removed are marked with an arrow on the interior side. The pin should be removed in the direction indicated by the arrow.
c) With the previously mentioned tool you will be able to perform the hardest part, namely push out the pin by 3/16". In the image below note how the pushed out pin goes into the groove of the tool.
d) Use a small screwdriver or a punch with diameter of less than 0.07" (or 1.8 mm) in order to push out the pin completely (see second picture).
The push pin of the tool can be reversed which is helpful for re-assembly. I recommend smoothing the one end of the pin with a small file or sandpaper. This way the pin enters easily into the hole of the lower section. Else you run the danger of bending the link if the pin is not correctly positioned and you apply too much force.
Oct 24, 2012 | Watches
Stauer watch will not work after battery change.
I have no ideal how old your watch is nor where you had the battery changed. Ideally I would take back to whom changed the battery to see if it was a good battery. If your watch is older it may be time for an adjustment.
Contace Stauer for further assistance at link following:
http://www.stauer.com/customer_service.asp
Good luck.
Aug 21, 2010 | Bulova Watch
How do you reset the time after changing the battery in a stauer 11475 atomic watch??
Take a look at http://www.stauer.com/pdf/17468.pdf
I see that this watch gets it's time signal from Boulder, Colorado so it will only work properly in North America. Perhaps they also do models for the European market - if so I would expect them to work in the same fashion so the manual should still be relevant.
Jul 29, 2010 | Casio Wave Ceptor WVA430A-1AV Wrist Watch
I want to send my atomic stauer watch for repair. Could not set watch when newly received. Where do I send Stauer watch for repair?
GOTO:
r/ David
May 12, 2010 | Fossil Watch
Apr 08, 2010 | Swiss Stauer Deep Dive Watch
Mar 20, 2010 | Bulova Watch
How to set the time on a stauer atomic watch
i have a stauer 33 watch i can not get the pin to come out so i can set the date and time it is like it is stuck or am i not doing it wright. thanks for your help
Oct 21, 2009 | Bulova Watch
My stauer atomic signal watch won't set correct time
Aug 08, 2009 | Bulova Watch
Watches Logo
145 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
