Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ge profile brita 18 bm black purchased in jan/06
Can hear circulating in the fridge. it quits after about 6 months, freezer is at the bottom. the shelf in the fridge closest to the freezer is the coldest and as u move up the fridge shelves get warmer, the top is warm and everything quits working. I had a repair man out, he took the bottom shelf off, it was full of ice. We poured boiling water and used a hair dryer to defrost it. Then it worked less than a year later same thing has happened so I cleaned it out and unplugged for 3 days I didn't take the bottom plate off in the fridge because I don't know how so have now plugged in to see if it will work. Please help Im on a disability pension
Thanks so much
Having the same problem. apparently this is just a horrible fridge... unfortunately no solution for ya
Posted on Dec 28, 2010
GE Profile Brita Fridge. Have setting down as low as possible and crisper foods continue to freeze. How can I fix that?
You need an internal digital thermometer to see if 1 is the coldest or the hottest. If you turn it to 6 and the temperature remains the same, the thermostat is faulty.
If 1 is the warmest and it continues to freeze crisper foods like lettuce, you need a new thermostat. Your ideal temperature is between 3 and 4' Centigrade at the coldest part, usually above the bottom shelf.
Aug 23, 2016 | GE Refrigerators
I have a GE Profile Brita Fridge. My fridge is working fine but my freezer doesn't work. What can I do about fixing it?
Does it have frost in the back off the freezer? Do you heard the fan running in the freezer?
Mar 25, 2016 | GE Refrigerators
Check for failed evaporator (cooling coil) fan motor, located in the freezer or a failed component in the automatic defrost system.
Sep 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Brita profile
yes replace the seal, this type of spotting that forms as rust color occurs on "ferritic" stainless steel. Simply put there exists iron in the alloy and the surface needs to be pacified. Use DeBruce Polish to correct the problem. Non-toxic and odor-less containing NO ACID, this TRUE MULTI-SURFACE CLEANER is the best product for stainless steel AND glass/ceramic cook tops. Go to, you will be glad you did!
Aug 26, 2013 | GE GDS18LBR Bottom Freezer Refrigerator
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
I have a GE Profile side by side and the ice tastes bad
Yes this is very common and I know exactly what you mean - it's disgusting ! As you know air circulates and re-circulates between your freezer and fridge section and with time odors get mixed up and get imprinted on water and ice - Throw your ice rack, buy a new one and use filtered water instead like from a brita, and once a week renew it, throw them out and refill them, constantly recycling them every week to two weeks, keeping it fresh.
Oct 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
GE Profile - fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Artica Profile side by side freezer will not cool below 2 degrees
Remove the rear panel at the bottom of refrig which covers the compressor and coils . The coils should be cleaned about every 4-6 months . Place a length of 2x4 laid flat behind the fridge , to push the fridge against , as this also gives enough room for air circulation .
Jul 27, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
470 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
