Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint FDW60 Flashing lights 3 and 5
My dishwasher tripped out my electrics, on resetting the fusebox the washer was flashing light 3 which I found out was flood sensor, so I drained the water from inside the machine, now when I start the machine the drain pump runs for about a minute then it fills with some cold water through the filter for about a minute, then lights 3 and 5 flash (which acording to the manual is filter blocked) and it all drains again. I have checked the filter, and it's fine. Any other ideas?
  • fdaniel571 Jan 11, 2009
    Hi, thanks for your response, I don't think water could have got into the controls, but I do think it may have shorted something out in the bottom, but not sure if it would blow the control board or the pump or the heater or what!!!
  • darlo2k Feb 25, 2009
    I have same problem, did u find solution that worked?
  • 3 Answers
Same thing happened to me.
The electrics tripped and once going again, 3 ECO was flashing.  This fault was caused by the polystyrene float rising when water fills the botton tray.  Tipping the machine onto its side empties the water unto your floor and clears the fault.  But if there is a leak, the tray will refill, usually in a few minutes, and Flashing ECO appears again.  If you remove the bottom trap - held on with six screws, you will see the float.
The fault was traced to one of the three pipes that run up the left side of the machine to a plastic box.  One had worked loose and was flooding the whole of the electrics area.  This will splash water on the mains suppressor whichs sits directly below it and will trip a RCD in your fuse box.  A jubilee clip fixed the problem.
Now, the machine runs for about 30 seconds, stops, drains and 3 and 5 flash - same fault.  It is possible the connectors are wet and short circuiting.  I suppose if they dry out over a day or so, then this will cure the problem.  I suspect that this fault is triggered by a sensor or switch somewhere - does anybody know?
Posted on Feb 16, 2009
  • 979 Answers
Is it possible that water has gotten inside the controls that could have caused the flashing lights? Kind of like spilling water on a calculator, everything seems to go haywire.
Posted on Jan 11, 2009
  • Bill Dickerson
    Bill Dickerson Jan 14, 2009
    Hey good luck in fixing this. I would be interested how you finally get it fixed. You are like me in that we want to try everything before we actually spend money or at least properly diagnose it so that a repairman can get right to work and hopefully charge less.
40 and 50 degree lights are flashing on my free standing fdw60 hotpoint dish washer
Apr 15, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius FDW60 tripping electrics
I had the same problem. found out that the RCD was faulty & needed replaced. now o.k.
Sep 14, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius fdw60 tripping problem
I would agree with you. Everything you say here certainly points to a faulty heating element. The original is fitted with two factory fitted clips so you may need to go to your local garage and get two jubilee clips as they don't usually come with the new element.
Jun 01, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher not working - FDW60
unplug it for an hour this normally fixes this problem on my machine
Jul 28, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Fdw60 dishwasher
Hold the start key down and it should re-set . Please Rate This ! Thanx!!
Apr 08, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
737 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
