Question about JVC GR-D50 Mini DV Digital Camcorder
Condensation operation paused in jvc gr d91u.I have kept it near fireplace to dry it but it woked for few minutes only
  • Anonymous Jan 20, 2009
    i have the same problem with yhis condesaction can someone help me what part of this camcorder do i need to open. thanks
    President:
  • 1,223 Answers
If no picture on screen and u are unable to record it might be a CCD failure due to manufacturing fault in this series kindly see the link below u can get it repaired free of charge or tell me the resion u are in and i will give u direct link for support pls rate me FIXYA or ask more help
http://www.jvc.co.uk/template.php?page=100102
Posted on Mar 20, 2009
  • Shoaib Rais
    Shoaib Rais Mar 20, 2009
    dont worry if ur camera is not in list they will do it free of charge it is the condesation problem in CCD unit and wiring and they are truly responsible for that many are facing this CCD problem in different brands see the link
    http://www.imaging-resource.com/badccds....
    pls dont forget to rate me FIXYA for this info
When trying to record or replay, I'm getting an error message that says "Please wait - Condensation, Operation Paused." I've waited now over a week & still getting the same error...
Put the camcorder in a warm dry place for a few hours, there is moisture inside the unit, that triggers the humidity sensor and shuts the camera off. If after drying the camcorder for a reasonable time it still will not function you will need to get it repaired.
Mar 03, 2011 | JVC GR-D90U Camcorder
How to fix "Condenzation. Operation paused"
The camera will say that when it detects that the moisture level is too high. Make sure that the camera is completely dry. If it is warm and dry with a clean tape installed and still gives the error, then the condensation sensor may be bad. It can be replaced, but you should check with JVC about warrantee.
Dec 01, 2010 | JVC GR-D30U Camcorder
Condensation, operation paused
you can try gently drying it with a hairdryer not too close or too hot but try to get the moisture out that is causing your problem. this could have been caused by coming in from the cold to a warmer room. this should fix it.
May 07, 2010 | JVC Cybercam GR-D90 Mini DV Digital...
Remove power from the camera. I remove the battery as well. In the back of where the tapes go, on the left side is a silver component. It's just behind a metal roller that hangs down from a plastic piece over the head. If you look behind the roller diagonally across where the tape goes, you can see a black square on the right side of the silver component. Clean this (gently!) with a moist cotton swab. The swap should get a bit of black gunk off. I'd recommend cleaning it with a dry swab next to remove any moisture. Wait a minute or so to be sure it's dry. Then re-apply power. You should not see a false condensation message for a long time.
Mar 13, 2010 | JVC GR-X5 Mini DV Digital Camcorder
Jvc gr d50.. "condensation, operation paused"
Set it in a bowl of rice for a couple days or leave it out in the open air till it works again. Do not use a hair dryer or any type of pressurized air source. The rice works for cell phones that take a dip in a water source too.
Eric
Jun 19, 2009 | JVC GR-D50 Mini DV Digital Camcorder
Condensation operation of camcorder paused
Condensation problem is a common on newer camcorders. It is the sensor on the board that detects the condition of humidy. If you have not wet the camera or stored it in the humid area, the sensor or components around sensor is faulty. You can try to dry any humidity using hair dryer at medium setting in about 6 inches away for less than 5 minutes toward inside of tape loading area (make sure loading mech is at opened position). If this does not work, take it to recommended local camcorder repair facility for a diagnostics. Good Luck. CRJ
Feb 28, 2009 | JVC Cybercam GR-D93 Mini DV Digital...
Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Apr 27, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Condensation operation posed
Mar 02, 2008 | JVC GR-D30U Camcorder
Gr-dx97 - condensation, operation paused message on screen
Dec 31, 2007 | JVC GR-DX97 Mini DV Digital Camcorder
Condensation
Here is how I fixed mine once and for all http://www.dognmonkey.com/techs/jvc-sod-condensation.html Hope this helps,Louis
Apr 20, 2006 | JVC Cybercam GR-D70 Mini DV Digital...
JVC GR-D50 Mini DV Digital Camcorder Logo
423 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
