Question about Cooktops
Wiring Wrong hello. we had a new counter top put in. we are using the same GE 4 burner counter top electric stove 1960/1970 hard wired. We forgot to tape the wiring so we could hook it back up the same way that it was. When we hooked it up the burners would not glow red as before when cranked up. They heat up but not quick at all. There are three wires coming from the circut box. 2 thick reds. 1 thick black. The control box under the top of the stove has 2 thick red. 1 small red and 1 small gray . I had the black to the gray, a thick red to the thin red and just capped off the other red. I know it's wired wrong so what would you suggest I try. Thank you
    Sergeant:
    Champion:
  • 262 Answers
REDS ARE THE 2 HOT 11O VOLTS EACH AND BLACK IS THE COMMON FROM THE CIRCUIT BOX .THE RED ON THE STOVE SHOULD BE 1 HOT AND THE GRAY MAY BE THE COMMON BUT YOU ARE MISSING A HOT LOOK FOR YOUR WIRING DIAGRAM ON THE STOVE AND IT WILL SHOW YOU THE COLOR CODES FOR WIRING IF YOU CANT FIND IT SEND ME THE MODEL NUMBER AND I WILL SEE IF I CAN GET IT FOR YA.......BILL
Posted on Jan 11, 2009
Why does my oven does not work but top burners are good
Not sure but newer stoves have 4 wires 2 110 and 1 ground and 1 neutral. Older stoves had 2 110 and only 1 ground. The oven sometimes used the ground a sa neutral for little motors, displays, etc. make sure that the third wire on your plug has a good ground and see if that helps
Jul 16, 2014 | GE Stove / Oven / RanCooktop Assembly -...
Why are lights not working under the ceramic JennAir stove top?
You have probably accidentally disconnected some wiring whilst moving it need to re explore
Apr 27, 2014 | Jenn-Air JED8430 Electric Cooktop
One of the burners does not work. Is it possible
yes,heating elemnt and the control can be chgd.to chg those pull the unit out and let it sit on the counter.remove all the screws around the stove just below the glass top.once the screws are out u can pull the top up and have access to all the components.make sure to turn the ckt breaker off b4 opening.u dont have to disconnesct the power cord from the wall if it is hard wired.
Aug 09, 2009 | GE Profile JP930 Electric Cooktop
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Counter top stove burner won't light
Hi, You asked a very generic question but I will try to give you a good answer. If the pilot is good and you can light the burner with a match, (this checks everything else) then the most common problem would be the burner holes in front of the pilot are clogged. When cool, remove the burner and inspect the holes, any debris needs to be removed, a bent paper clip works really well. Compressed air helps as well. If there is a tube to the pilot make sure it is exactly where it belongs and that it is clean. If the match didn't light the burner or the flames is not all blue like the rest, there is something else wrong and you need to get back to us with a make and model to better help you. Make sure the burner gets seated back on the orifice correctly and best of Luck to you!
Feb 05, 2009 | GE Profile JP930 Electric Cooktop
Electric stove top
Follow the wire, It should go to a junction box within 4 feet. It may be behind a cabinet. Remove the box cover and unscrew the wire nuts. It usually uses armored wire and this is clamped to the box. Release the clamp . Turn off breaker or remove the 2 fuses first.
Jun 08, 2008 | Cooktops
Ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
May 01, 2008 | GE Profile JP930 Electric Cooktop
GE JCP 930 Cooktop Wiring
These fuses are under counter? It should be wired to breaker box. Check specs in manual but i suspect a 30 or 40 amp breaker.
Nov 17, 2007 | Maytag MEC5430 Electric Cooktop
Cooktops Logo
310 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Are you a Cooktop Expert? Answer questions, earn points and help others
