Question about LG CHOCOLATE VX8500 Cellular Phone
Buzzing when i charge
When I hooked up my phone to the charger there is a constant buzzing noise and it won't take a charge. Its not the charger cause I hooked it up to a different one and it did the same thing.
  • 58 Answers
Do you have insurance? If so, take it to Verizon and see if you can get a new phone.
Posted on Jan 12, 2009
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
Asus charger won't charge
Stop using that charger. I sounds like you have a break in the wire and when you hold it in the right position, the two pieces touch and current flows. Unfortunately the heat is probably being caused by arcing and is a potential fire hazard.
Apr 06, 2017 | ASUS Original 19v 3.42a Ac Adapter Charger...
Samsung corby not charging GT s3850
Are you very sure it is the right charger? I have hooked my phone up to charge before, not realizing that the charger I had used was for something else. Many of the chargers these days look very similar, sometimes exactly the same. However the output on the other charger is quite often not right. This will cause your phone to not be charged.
Sep 08, 2012 | Samsung S3650 Corby / S3650 Genio Touch...
My ER6n wont start the starter motor does not fire it just makes a buzzing noise,any ideas
Charge your battery over night on a proper battery charger (not an optimate or similar) and them it should be fine. If the battery won't charge, it's time for a new one.
All the best
Jul 02, 2011 | 2008 kawasaki ER6n
Loud buzz in one phone when other is in Mother charging base.
I Had the same problem.
I found out what it was. The buzzing sound came from the AC/DC charger. I changed it and everything is working fine now !
Try with a AC/CD adaptater putting it on the right voltage and check if it's working without this buzzing sound.
Have a good day !
Sandy S.
Apr 27, 2010 | Uniden Cordless Phone
Have a hoverround mpv 4,do you charge with the controller on or off,when on i get a buzzing noise loud im thinking you charge when the controller is off need help thank you
Typically you will charge with the controller off, but it is not critical. The buzzing noise may be the fan on the charger, which is normal. Make sure the silver handle of the charger is fully inserted into the controller. If the light on the charger is on, you have kept the charger connected for 8-12 hours and still the batteries will not charge, there may be a problem with the batteries being bad and they need to be replaced.
Jan 15, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Buzzing Noise When trying to charge
it means your battery is too discharged to charge. when you plug the phone in, it doesn't use the AC power right away, it uses the battery to jump start it until the red lights come on the front, then it will switch to the AC power. try this. turn on the phone with out it plugged in and as soon as those front lights come on, plug the charger in. if the battery is not too discharged i.e. it didn't power down while you were talking to it, it should work. I went through three batteries until i figured it out
May 31, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Can't Charge!!
Try another charger. I broke the plastic that locked into the phone on my car charger and had problems charging. The phone is very finicky about the contacts. Had to replace charger.
May 28, 2007 | Sony Ericsson T610
AC Adapter Buzz Noise
The jornada 548 power adapter should not be buzzing - it should be very quiet.
Sep 12, 2005 | HP Jornada 548 Pocket PC
LG CHOCOLATE VX8500 Cellular Phone Logo
108 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
