Question about Broderbund PrintMaster Platinum 16
Printmaster install set up won't load completely. Windows 7.
    Novelist:
  • 250 Answers
This problem sometimes occurs due to corrupt installation file or due windows errors. WebRepOverall ratingThis site has no rating(not enough votes)
First of all apply following troubleshooting steps to PC:
Fix registry errors
Remove un-necessary programs
Scan PC with Anti-Virus
If installation problem still occurs then use system utility tool Reginout.
Posted on Dec 05, 2012
  • 187 Answers
SOURCE: Just got Windows 7 and trying to install
Windows 7 has a compatibility wizard that you can use to help install it. Go to start, control panel, and then type in troubleshooter in the search box. Under programs, click "run programs for other versions of windows." Follow those instructions. If you need to browse to the setup file on the disc, do so. If that does not work, you can go to Broderbund's web site. They have a compatibility update for Gold 17 on their website. Unfortunately it is for Vista, but it still might help you with the compatibility issue
encore .
Posted on Nov 18, 2009
  • 2340 Answers
SOURCE: will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
Posted on Oct 24, 2010
SOURCE: Can I load Printmaster 16 on Windows 7?
Printmaster 16 will work with Vista and Windows 7, you need to run setup.exe as administrator.
Posted on Dec 12, 2010
fanaudi
  • 1381 Answers
SOURCE: won't install on new lap-top
Hello trishnchr324
This program is no more supported by Windows 7 .
There is a work around and it's the only way : install a virtual version of XP on your machine .
You are welcome back here if you need further advice . Just click on " reply " and post your message .
Best regards ,
fanaudi .
Posted on May 15, 2011
fanaudi
  • 1381 Answers
SOURCE: I've got Printmaster 12. I
Hi dgk_builders
Your product is not compatible with Windows 7 .
Best regards ,
fanaudi .
Posted on May 27, 2011
Testimonial: "I don't know how you know this but I suppose you do. Thanks anyway"
I am running windows 7 and I would like to know how to install an old version of printmaster silver 10 on windows 7
Printmaster 10 may not work with Windows 7. Just uninstall Printmaster 2012 then install Printermaster 10 using the installation CD.
I recommend you go to the Printmaster support site and ask them if version 10 will work with Windows 7 so you do not have to uninstall 2012 version if version 10 will not work with Windows 7.
Oct 15, 2012 | Dell Inspiron 1720 Notebook
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I bought a new computer with windows 7, have older version of printmaster permier 8.0 and it will not install. help
Hi lavernhess
There is no direct solution to this issue since there is no driver running under Windows 7 for your product .
You could install a virtual version of XP on your machine with http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html or via Microsoft's if you are using Integral or Professional .
Otherwise , you will need to purchase a recent version of Printmaster compatible with W 7 , if available .
Best regards ,
fanaudi .
Aug 24, 2011 | The Learning Company PrintMaster Premier...
Won't install on new lap-top with Windows 7 OS. Are there any driver updates for this?
Hello trishnchr324
Best regards ,
fanaudi .
May 15, 2011 | Broderbund PrintMaster Silver 15 for PC
I cannot install PrintMaster Platinum 2011 on my Windows 7 computer. Is there a way to do it? It says it is compatible with windows 7.
Administrator privileges are required to properly install the program on Windows® XP, Windows Vista®, Windows® 7 and Mac OS X for PrintMaster Platinum 2011 .
Using mouse, right click on the "setup" and Run as "Administrator"
Hope it helps.
Apr 28, 2011 | Encore PrintMaster 17 Gold for PC
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Jul 19, 2017 | Broderbund PrintMaster Platinum 16
Will Printmaster Platinum 16 run on windows 7 I
Oct 24, 2010 | Broderbund PrintMaster Platinum 16
Jan 10, 2010 | Broderbund PrintMaster Platinum 16
I have Windows 7 and just installed PrintMaster 2.0 Platinum. I cannot print anything. here is the error message. PrintMaster 2.0 Platinum encountered the following error: java.lang.NumberFormatException:...
I had the same problem. If you are using a french version of Windows, try to switch your regional settings to "English US". It worked for me. Every time we use an English software on a French version of Windows, we have compatibility problem... ;)
Good Luck!
Dec 21, 2009 | Broderbund PrintMaster Platinum
Computers & Internet Logo
57 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
