Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool refrigerator GD5RHAXN frig side lights are out . The water filter lights are out also.
SOURCE: whirlpool side by side water dispenser not working
I had the same problem and it appear the cable set between the freezer door and refrigerator body has some wires broken. The cable is in the bottom right hinge. You can try moving the cable with fingers at the same time you're pushing the water lever.
While this is not going to be a permanent fix, at least it confirm where the problem is.
Posted on Nov 28, 2007
peyton32034
  • 410 Answers
SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
funny you asked this question i just had this same problem this week at a customers home. you need the electronic control board located in the compressor compartment behind the refrig. it is mounted in the white box on the left hand rear corner. the whirlpool part number is 2304095 and it is around 175.00 i'm not sure who a local part supplier around you would be if all else fails you could get thru sears..
Posted on Jan 07, 2008
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
Don't let them tell you that the problem is related to "sulfur" in your water. It's a scam so that they don't have to repair the problem. The actual problem is that they don't use quality parts to build these units anylonger.
Posted on Jun 28, 2008
mikedurland
  • 481 Answers
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
SOURCE: water filter replacement
I have the same problem. I did change the filter located on the bottom front panel of the refrigerator, but the red light is still on and NO ice. I can't figure it out and I know if I call a tech, its a 300.00 bill. Frustrated.
Posted on Oct 25, 2008
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
Water filter for ed0gtqxkq00
I looked up your frig and I did not see a filter. If you want to use one, you can install what is called an inline filter. This is simply a filter you install behind the frig attached to the water line going to the frig.
All you have to is unhook the water line from the frig, attach it to your newly bought inline filter, and install another water line on the other side of the filter and hook that back up to the frig!
So now you have a filter and two water lines :) Just make sure to point the filter the right way, the usually have an arrow on them. The water is supposed to flow through them in a certain direction.
May 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you change the water filter on the whirlpool conquest GS2SHEXMB00
the water filter should be where the water goes into the back of the frig. you will see it also make sure you turn the water off at the main before replacing.. good luck..
Nov 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Light bulb flickers and strange sound
that is just a small problem..try check ur bulb..maybe its loose,tighten it back..then that strange sound maybe came from spark between the bulb and its connection..
Sep 18, 2009 | Whirlpool GS5SHAXN Side by Side...
Where is the water filter located
The water filter should be located in the back right hand corner of frig compartment.Just unscrew and it should drop out. hope this helps
Jul 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My frig is leaking water & bottom tray is full
you need to change the filter on the bottom of the refrigerator, take off the outside cover on bottom of fridge and on the left hand side right above the tray that keeps filling up there is a round filter that unscrews. unscrew it and replace the filter. You can get the filters at Lowes or Home Depot for about 20 bucks, hope this helps.
Jul 12, 2009 | Refrigerators
The external filter was replaced, and water tastes
Check to see if the filter is in backwards. Try purging it too. Just keep running the water for a couple of minutes to see if the taste improves. If it doesn't and the filter isn't on backwards then get a new filter, that one is bad.
Jul 09, 2009 | Whirlpool GC5SHEXNS Side by Side...
I am getting no water to go into my ice maker ,m
Whenever water is run to a refrigerator icemaker there is a filter. Depending on the composition of your water, your filter can get a build of of chemicals that are found naturally in water. Change out the filter. If that doesnt work... work your way backwards.. check the copper pipe that runs from the wall to the frig to ensure it did not get bent or cracked while moving the frig out to clean, etc.. Hope this helps. Good luck
May 02, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
22 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
