Question about Sony CDX-RA700 CD Player
I am unable to remove face on radio plate
Need instructions on how to remove face plate.
  • 15,935 Answers
Http://www.docs.sony.com/release/CDXRA700.pdf
Manual
States the following....
Press off, then up arrow button (bottom left corner)
Pull toward you.
Find the info on page 4 of the manual. (link is above)
Posted on Jan 11, 2009
How do i remove the stock radio from my 1993 geo metro 4 door hatchback
here is the online fsm quote
  1. Disconnect the negative battery cable.
  2. Open the glove box. Remove the glove box open panel.
  3. Remove the air conditioning switch connector and heater control unit lever knobs. Pull heater control unit cover plate from instrument panel.
  4. Remove the gearshift control lever upper boot and center console.
  5. Remove the ashtray.
  6. Remove the instrument panel center trim bezel and radio face plate.
  7. Remove the screw from the back of the radio receiver and the screws from the front face of the radio.
  8. Remove the radio.
Sep 30, 2014 | 1993 Geo Metro
HOW TO REMOVE 2004 FORD FOCUS BLAUPUNKT RADIO FACE PLATE
No, you will damage the face plate trying to do that. The dealer has a special tool that is unique to properly remove the unit.
Dec 20, 2013 | Cars & Trucks
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
Jan 17, 2010 | Kenwood KDC-516S CD Player
Face plate is dim and unable to be read
Backlite bulb behind the display is burnt out. Remove radio and figure out which bulb is out. Replace bulb...
Nov 18, 2009 | Aiwa CDC-X407 CD Player
How do i get the dash off to pull the old radio out
I'm not totally sure about the La Sabre, but there should be trim screws that hold the Dash face plate in place. There are three on the top portion of the face plate, and I think three on the bottom . The face plate extends from Light switch on left to radio on right. You may have to tilt the steering wheel column down to remove the face plate from around the steering wheel. From what I remember, the only thing that needs to be unplugged from the face plate is the plug for the rear defroster. Also, there are clips that hold the face plate in place. They just push in and out. Once the face plate is off, you can get to the radio mounting screws.
Aug 16, 2009 | 1993 Buick LeSabre
I need to remove the radio in my 1998 mountaineer
you need specail radio removal tools. they spread 4 spring clips.
  1. Remove the radio chassis.
  2. Insert Radio Removing Tool into the radio face plate and release the radio retaining clips.
  3. Pull outward on Radio Removing Tool to remove the radio chassis from the instrument panel.
Special Tool(s)
Radio Removing Tool
415-001 (T87P-19061-A)
May 12, 2009 | 1998 Mercury Mountaineer
Radio and dash lights
Remove radio from vehicle. remove T15 torx screws on top and sides of radio. Remove knobs and outer bezels around knobs. Face has retainer clips top and bottom. Unsnap the face of radio and remove old bulbs there are five or six in a gm radio.
Jan 12, 2009 | 2001 Chevrolet Blazer
1998 beetle radio buttons
The face plate buttons actually activate small buttons on a printed circuit board behind the face plate. When I removed the radio and then the face plate many small pieces of plastic fell from behind the face plate. These small plastic pieces align the face plate button to the printed circuit board buttons. My Beeetle is almost 10 1/2 years old so I imagine the plastic is just becoming brittle with age. I could not set the radio to FM, so I removed the face plate button and now slide a toothpick in the slot to toggle between FM1 & FM2. Not he best solution, but probably the most inexpensive one. I also made my on tool to remove the radio from a diagram found at: http://www.alientech.net/nbinfo/stereo.html
Jul 02, 2008 | 1998 Volkswagen Beetle
Unable to hear on bluetooth option garmin 550 street pilot
The unit does not need an earpiece. Make sure that you do not have anything plugged into the audio out port on the back of the unit. Also make sure that the volume is turned up. If you hear the normal navigation instructions from the 550 then the volume is OK.
If all else fails, then reset both the 550 and your phone. To reset the 550, use your thumbnail to pry the face plate off. There is a small indentation on the upper side of the face plate where it meets the screen. Once the face plate is removed, depress the reset switch on the front right side of the unit.
May 25, 2008 | Garmin StreetPilot c550 GPS Receiver
Stereo removal 06 cobalt
you must remove all the plastic face plates around the radio then remove the radio itself.be cautious as you could damage the clips that hold the plates in place.
May 14, 2008 | 2006 Chevrolet Cobalt
Sony CDX-RA700 CD Player Logo
272 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
