Question about Sharp LCC6077UN Aquos 60 inch 1080p LCD HDTV
My aquos 60 inch lcc6077un has very low sound is this a setting problem?
My tv volume must be over half or all the way up to be able to hear dialog and on some movies it is impossible to hear the dialog on some scenes. very frustrates
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
SOURCE: 52 inch aquos sharp tv
Just bought a 52" Aquos TV 27000/1 newest model for 2008 my husband is putting it up and said the non HD channels don't look real good. Is there anything we can do to improve the picture on the non HD channels?
thanks,
Cathy
Posted on Apr 04, 2008
SOURCE: volume issue
I have the same problem. When I adjusted the volume on the cable box, it was solved. Turn up the volume on the cable box, and when you use your remote, it's super loud, even at midway!
Posted on May 20, 2008
  • 54 Answers
SOURCE: I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
Posted on Jan 19, 2009
  • 50 Answers
SOURCE: TV Screen Dims during dark Scenes
Most likely you have the opc feture on. go to the menu under picture setting first option should be to turn on or off the opc. turn it of and should solve the problem.
Posted on Mar 18, 2009
Sharp aqous 60 inch tv sound wont go very loud turn it up to 60 wide open to hear it ok
IF THE SET is hooked to a cable or sat box make sure the volume levels on that is not set too low---most boxes have a vol up and down on them.
Mar 18, 2012 | Televison & Video
The sound on my new 42 LED LCD Visio TV is off. The dialog on every movie that I watch (no matter what channel) is way too low. I have to turn the volume up to 50-60 to hear conversations properly. Then...
There's a setting called TruVolume, or something like that. I'm not at home to look at it right now. Turn that off. If it's off, try turning it on. It worked for **** on my 55", but functions wonderfully on my 32".
Jul 06, 2011 | Televison & Video
I have a sharp 32" bought at Walmarts at the Christmas before last and the low volume is driving me nuts. In my small living room with Volume set at 60 it still is not loud. Is there a trick to get louder...
Unfortunately it seems to be a sharp thing. I have a sharp 46 inch and there are times when I find it difficult to hear. Some channels seem to work fine with the volume right around 20 - 25. Seems to be quite often though that my volume is set over 40 and still struggling to hear. Seems with my tv that there is no difference between it being set on 35 and 60. They sound the same. Surround sound is the way to go if you stick with sharp.
Jul 10, 2010 | Sharp LC-26D6U 26 in. LCD Television
My sharp aquos television sound is very low even on max.
I had this problem with my Charter and the box had a sound button on the actual box, not the remotes. Now I have switched to Direct TV Box and have found while not so low I can't hear it, it is much lower than I know it can be and have to turn it up in the higher numbers or turn on the surround sound to hear it. Anyone know what to do with Direct Box, Direct didn't know.
Sep 05, 2009 | Sharp LC-26D4U 26 in. LCD Television
Have to turn the volume to 80-100 to hear the tv in my bedroom
If it's just playing DVD's that the volume is low some DVD players have their own volume control.
You could look at the back of your tv and see if the dvd or psp is hooked up to a "line in" or a 'variable' input. The Line in is a constant audio source. The variable will be also affected by the volume on the TV.
May 31, 2009 | Televison & Video
High and Low sound volume
Now volume is relative to the person listening,
so based on when you can hear the tv correctly during a normal show,
if you hear normaly we will call that 50%
how much louder does it get on commercials from 50%
there are in the menus different sound fields, have you found out how to change them? Take the tv out of surround mode and see if that helps. Just set it to stereo.
give me a model # and I will tell you where in the menu it is if you cannot find it.
I also need to know, are you running through an amp?
Do you have a cable box, because in those there is also a setting for surround.
it sounds like you have surround set, but no surround speakers.
i'll be here
Charles
Jan 10, 2009 | Televison & Video
Tv volume
try to put it on menu and check if the volume has set up to the higher volume.i think somebody touch yhe settings of your television.
Oct 23, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Volume issue
Very loud it never gonna be. It's a tv with very small speakers, but I have a lot of customers who complain about that and I checked first the signal source. Sometimes the sattelite receiver or cable box give a sound not so good. The best way to check it is to plug something (an antenna or just a 2 inch wire) in the coaxial plug to see if on the tuner is the same sound. I bet is gonna be stronger.
Dec 29, 2007 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LCC6077UN Aquos 60 inch 1080p LCD HDTV Logo
44 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
