Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
My saeco primea touch plus cappucino grinds coffebeans, but no co
Hi. My only one month old saeco primea touch plus cappucino machine, suddenly dont works. The grinder works, but no coffee comes out. Instead it says prime the machine, but although i accept that, it doesn't change anything. I have cleaned everything thouroghly and tried the different cleaning programs. Any suggestions ?
At the extreme top left of the brew group, above the last filter (mentioned in another response), there is a spring loaded tip that I assume is pushed open by the pressure of the brewed coffee, before the coffee streams to the dispenser nozzles. When I dis-assembled this (2 philips screws) the tip seemed very sticky (slightly jammed?). I pushed the ip several times against a hard surface and freed it up. Re-assembled everything (plus cleaned the last fliter). Works fine again.
Posted on Jul 25, 2009
  • 3 Answers
I had a similar problem and another posting on this site mentioned that if you remove the brew group - look at the top of the assembly and underneath the head piece you will see a metal disk with small holes in it. These holes can get blocked and stop water from flowing through. You can try brushing with a fine haired brush while washing with water or any other means to remove the blocked holes without damaging the disk. The disk can be removed and inspected by removing the Phillips head screw in the centre if you can find a very small srewdriver to suite - but this may void warranty.
Posted on May 10, 2009
  • 2,039 Answers
Prime the machine they give a little pump in the kit remoe water tank fill pump insert it in the hole apply pressure it should prime itself try opening the side valve to vent the machine let me now pierre
Posted on Jan 11, 2009
Hi, I have the Saeco Primea Cappucino Touch Plus , and it syddenly gives the error code 5 - Call assistance. I have just changed the primea Water Filter - same way as always ! What can I do ?
Need to prime the machine. The new water filter is causing the air lock in the system.Remove the filter and startup the machine it should prime by itself, when it's ready,fit the filter back and press hot water until the water flows steady. Hope it helps.
Sep 05, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea new machine - slow dripping
look in manuel how to ajust the coffee grinder its grind the coffee to fine when you ajust the leveler of coffee move it only when the grinder work do a few ajustment it will be fine pierre
Dec 25, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Flow
Check your grinder to see if the grinds may be too fine. Increase the grinder size and see if the coffee speed is increased.
If not, Contact saeco usa for support at 800-933-7876.
Out of warranty repairs can be completed by Cerini Coffee located in New York.
www.CeriniCoffee.com
Replacement parts for your saeco espresso machine located at http://cerinicoffee.com/Saeco_replacement_parts.asp.
Nov 23, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
We have cracked our plastic water tank reservoir on our Saeco Cappucino/Espresso Maker and need to replace it.
You can special order the water tank by visiting our website http://cerinicoffee.com/Saeco_replacement_parts.asp
If the item is not listed please contact us.
Cerini Coffee Services
Authorized Saeco Service Center
Nov 10, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Milk temperature setting
Hot Milk:
steam pressure time 6
puls width 1
puls period 15
Milk Foam:
puls width 1
puls period 15
Hope this will help you.
/Mirran
Aug 28, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino brewing very slowly
Try to descale the machine.
Try to adjust the grinder little.
/Mirran
Aug 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker fill water tank
The Primea do not have a float, it have a magnet and inside the machine there are a printed circuit card, this send a signal to the powerboard.
Jun 20, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
483 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
