Question about Video Game Consoles & Games
System update failure for ps3 error code 80029c55
How do I correct error code 8002F310
The error code your getting is saying that your PS3 is failing to update. You can disconnect your system from the internet, turn off automatice updates and try it manually or you can try loading the update through the PS3's safe mode. This link will show you how to get your PS3 into safe mode. https://support.us.playstation.com/app/answers/detail/a_id/1488/kw/Safe
Also, you can download the update onto a flash drive and load it onto your system from there. This link will explain how to do so.
http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm
Nov 04, 2013 | Sony Playstation 3 (PS3) Console
80029C78 error code ps3
Restart the PlayStation 3 system, then update the system by entering Safe Mode and selecting [System Update]
Jul 08, 2012 | Sony Playstation 3 (PS3) Console
I tired a system update and got an error.. 80029c55.. dont know what this means.. do i have to have my ps3 online to get this update?...i cant play call of duty black ops without the update?
That is an error that pertains to trying to update with a USB stick. Try to update online if you can, but if not, try using a different USB flash drive. The PS3 has trouble with certain memory sticks, especially cheap ones, so try a brand name one if you can. If you don't have access to internet or a different USB drive, then try deleting it and recopying it onto the USB drive, and attempt to install the update again.
Apr 06, 2011 | Sony Playstation 3 (PS3) Console
The playstation 3 does not work with certain games saying there is an error on the router (error code: 80710723) How can we open more ports on the router? Thanks for your help
Generally what happens is that progress will stall whilst you are trying to update the firmware or software/games on your PS3, causing it to be corrupted. Your console is then unable to function properly, and you are left trying to "pick up the pieces" as it were. The PS3 error 80710723 is one of these system update errors, and is often experienced by gamers who use wireless connections to update their firmware or games.
So how can you fix PS3 system update error? Here are a few steps you can take to try and fix the 80710723 error code yourself.
  1. In your System Options/Network Settings you need to go and disable a setting called "media server". Doing this has been reported to fix the PS3 system update error in a number of different cases.
  2. If you are using a wireless network connection then switch to a wired connection and attempt to update your console. Wireless connections can have interference, or fail from time to time. Therefore it is better to use a wired Internet connection where possible.
  3. As a last ditch resort you can actually download the update from the Sony website onto your PC, then load that update onto a USB stick and plug it into your PS3 and carry out the update process from there. However, it is best to actually try and fix your connection problems first.
Jan 04, 2011 | Belkin N1 Vision Wireless-N Wireless...
System Update error
Your internet might have been fluctuating during the download/installation of this System Update. If the process was aborted or suspended at all cost for the PS3 while doing a system update, it will cause critical OS failure that will brick the unit. the only to have it fixed is to send it to Sony and have the system flashed.
May 17, 2010 | Sony Playstation 3 (PS3) Console
I've gotten the error code 8002F14E after upgrading my ps3 to the latest version. system update stops at 68% and then this error pops out.
It is because you don't have the blu-ray drive connected that is making this fail. Hook it up again then try to update. If it doesn't update that way try downloading from Sony's site to a USB drive and update that way. If the laser is bad on the drive you may just want to get Sony to repair/ replace it, even if out of warranty as that is still cheaper than buying a new system.
If you cannot get to any menu to tell ps3 where it is to download it.
Then go to System Update but just tell the PS3 to go for an external device instead of looking for it over the internet.
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Error code 80010514
Unfortunately, from what I have read, it looks like you should call Sony. This is a hardware failure code and has nothing to do with firmware. Hopefully the system is still under warranty.
Jun 25, 2009 | Sony Playstation 3 (PS3) Console
Keep gettin error code 80710723 when updating system on ps3
mae your playstation 3 wired then download it. once downloaded then go back to wireless.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
PS3 80 GB - Error Code 8002991
Hi tomdonnatim,
If your PS3 is brand new, you most likely have to update the system's software to a more current version in order to properly play many Blu-Ray discs.
In order to update your PS3 system:
Go to the home menu, move to the "Settings" tab (the 2nd tab from the far left), scroll down to "System Update". It takes about 5 minutes to download and fully download the update, but it should solve the problem.
More information on the system update can be found below:
http://www.us.playstation.com/ps3/about/systemupdate
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
266 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
