Question about Kenmore Elite 45986 Front Load Washer
Kenmore 45862 rubber seal shredded - Kenmore Elite 45986 Front Load Washer
2 Suggested Answers
  • 5 Answers
SOURCE: My front load kenmore elite 110.45872 shakes during spin cycle
your basket shaft is broken or the bearing are bad it probably sounds like a freight train when it goes into high spin you need your washer rebuilt but it would be cheaper to buy a new washer. to rebuild the washer it will cost aleast 800 dollars
Posted on Dec 20, 2008
Kenmore front load washer model number 417. It's been smelling after use.
The rubber seal /boot can be replaced If it's really bad but you will need to clean soap dispenser pull it out all the way buy washer magic to clean rubber seal and door also buy afresh put two tables in tub run longest and hottest cycle with extra rinse once cycle finishes than take half bottle of washer magic and pour into soap dispenser run another cycle if still bad do it all again
Apr 23, 2016 | Kenmore Washing Machines
How to remove Control Locked
www.appliancerepair.net/kenmore-washing-machine-repair.html
Jul 27, 2014 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite 3t is banging in the spin cycle and the plastic ring behind the rubber boot is shredding. Any suggestions?
are you using a gel soap if not that may be your problem powder soaps cannot be used in front load machines it damagege the bearings in the back of the tub
Dec 17, 2009 | Kenmore Elite 45986 Front Load Washer
The rubber seal kenmore 3.8 cu ft he3t king size capacity
Our rubber seal was torn and we had a Sears repairman replace it - he said it required a special tool to install it (which he didn't have) but through some long and physical process, he was finally able to get it on.
Jan 26, 2009 | Kenmore Elite 45986 Front Load Washer
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Why is the steam leak out when i press the ''cook'' button?
The rubber seals are not shredded or not damaged in any way, but the only part that I'd look at it in a suspicious was would be that the rubber seals have been used for a decent long period of time.
Nov 16, 2008 | Panasonic SR-PRA18N 10-Cup Rice Cooker
Kenmore Elite Front Load - smell of burning rubber while in use
I've never had a smell problem like this before, but I have had the rubber lining to the door "shred", leaving eraser shavings all over the laundry. This happened with my first HE3t and I complained at SEARS and they just sent out a brand new replacement. About a month or two later, the same thing happened. I had SEARS come out and replace that rubber seal, and haven't had a problem since.
Although I can't answer on the smell, I highly suggest you keep an eye out for shavings on your laundry. Also, with the door open, at the bottom you can pull back the rubber seal slightly and expose the drain to be sure nothing is clogged or getting caught in there.
Oct 10, 2008 | Kenmore Elite 45986 Front Load Washer
Plastic inside door is shredding apart
Hello kwheersink
Welcome,
Make sure you are not using to much detergent.
You should be using HE, or High Efficiency Detergent.
And only the amount that the manual for the washer tells you.
To much and it will slowly destroy your Seal and bearing. Plus any rubber or plastic parts it comes into contact with.
Definitely replace this now!!
How old is the washer?
Let me know how you do and the answers about your detergent habits.
Waiting your response.
Thank You Huuum
Please remember to leave a rating!
Sep 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore - 43142 front load - leaking
Which hose are we talking about? If you're talking about the small rubber hose at the top center of the door seal, HOW is it leaking? Is there a hole in the hose? Is the door seal itself damaged? Let me know a little more so I can give you the proper advice.
Jul 07, 2007 | Kenmore 43142 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
19 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
