Question about GE Profile DPXH46EA Electric Dryer
Turning the beep off?
Is it possible to turn off the "beep" on this dryer? I think it's from the moisture alert. Sadly enough - my dog i(big tough pitbull LOL) is so scared of the beeping noise that she actually gets so neurotic so shakes until her teeth chatter. It's the beep and not the dryer.
Help!
Thx,
SKM
  • 45 Answers
1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down. Step2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device. Step3Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels. Step4Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Posted on Jan 11, 2009
Dryer beeps during dry cycle
if the dryer is beeping on it's own most likely you have a bad board part WP8563974
Oct 28, 2017 | Whirlpool Cabrio WED6400SW Electric Dryer
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
The vents have been cleared & I still have a buildup of moisture which won't let the clothes dry.
Most likely tour blower is slipping. It might be tossing out air but not enough. These dryers are notorius for having bad blower wheels.
To get into it kill the power and raise the top using a putty knife to release the top clips then get the front off and inspect the filter housing for lint. Their will be a big ball of lint. Grab the blower wheel and wiggle. If it is loose you will be able to tell.Hear is my crappy phone video:
Mar 27, 2013 | Amana DLE330RAW Electric Dryer
My whirlpool dryer lgr6620pqo doesnt dry clothes enough already replaced cycling thermostsat seemed to work now still not drying enough
Clean/Replace your dryer vent hose; also, make sure it is as taunt and short as possible. Any extra loops or turns prevents proper air flow (moisture) from leaving the dryer and being vented outside.
Also, check your outside dryer vent; sometimes critters make a home in the warm vent.
Hope this helps...
Jan 07, 2012 | Whirlpool Dryers
Have Talkabout 250 and want to turn off the beeping. any ideas
The following instructions are for the T289, which is very similar to the T250. It is possible they will work to turn off your beeps.
Alert Tones
The Alert Tones (beeps) on the Talkabout radios are set at a fixed volume
level and cannot be lowered. However, Alert Tones can be disabled. When
Alert Tones are disabled, the radio will receive messages at the volume
setting you've selected, but you will not hear beeps when you press control
buttons.
Disabling Alert Tones:
1. Hold down the Monitor button while you turn radio on.
2. To re-activate Alert Tones, turn the radio off, then on again while holding
the Monitor button down.
Here is a link to the user guide: http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
Oct 20, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
After choosing dryer cycle by turning the selection knob, I try to start cycle by pressing big Start button. It beeps several fast beeps. Also the drum light just stopped coming on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 20, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer unevenly drys clothes
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
Jun 21, 2010 | Bosch Nexxt 500 Dryer
How do I remove the pulley from the motor of my Hoover 5010D dryer to put onto a new motor?
Take a big tough wrench and put on shaft next to blower wheel. Now place a big tough wrench on the slotted place on the blower wheel. A place for a wrench is located on the blower wheel where the motor shaft goes into the wheel. Now holding one, try turning the other. Make sure you don't have one that has reverse threads. There are some models that do have them. They drive me crazy trying to determine which it is. They are normally real tight. About 1/3rd of the time I end up having to bust the blower to get it off. Although try not to if you don't have to because this is a part that seems to never go bad.
Please rate solution
Aug 28, 2009 | Hoover Dryers
Dryer turns off in 10 minutes.
To check the moisture sensors. Make sure the dyer is plugged in and all controls are set to off. Next to get into the diagnostic mode press more time, less time, more time, less time, all within 5 seconds. Now all indecator lights on the console are lit up with 88 in the " time remaining" display, if the test mode has been entered. Now this how to check the moisture sensors. Open the dryer door. You may hear a beep sound and the software revision number will be displayed on the console. If this happens there is a short in the moisture sensor system and the moisture sensors need to be checked and probably replaced. If this doesn`t happen,locate the moisture sensors on the face of the lintscreen housing and lay a wet cloth or towell across them. You should hear a beep and the software number will be diplayed on the console. If this happens then the moisture sensors have past the test and your problem is even deaper into the electronics and may reqiure a technician to trace this problem down.I hope this has helped you.
Nov 10, 2008 | Whirlpool GEW9200L Electric Dryer
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
GE Profile DPXH46EA Electric Dryer Logo
549 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
