Question about HP PSC 1610 All-In-One InkJet Printer
Says to check color cartridge
Printer says check color cartridge...not sure what check means. I took it out and looked at it and put it back in to no avail. It is not indicating low on ink.
    Problem Solver:
  • 5 Answers
The cartridge could be faulty. Try replacing it with a new colour cartridge. Are you using generics?
Brian
Posted on Jan 20, 2009
Says cartridge error 50C, see manual but i can't fix it
The error basically seems to mean that one or both of the cartridges is defective. It had me take out one cartridge and see if the error happens again.
I had both cartridges in and I got the error message2.gif. I took out the color cartridge and the error message went away. I put the color one back in and I got the error message again.
I replaced the cartridge and everything works fine.
Nov 09, 2009 | Dell A940 All-In-One InkJet Printer
The ink warning light flashes, and won't go off, even after I've put a new cartridge in. I've unplugged the printer, turned it off and on, plugged the cable back in, and it won't go off.
A blinking orange light means an empty or incorrectly installed ink cartridge. Ensure that the cartridge is not empty or dried out. Also be sure you installed the number 45 black and number 78 tri color cartridges. The 41 tri-color, for example, looks the same but would generate an error. Also, check that the panel in the back, or duplexer if you have one, is seated firmly in the printer as this can generate odd errors.
Oct 01, 2009 | HP DeskJet 970cxi InkJet Printer
Check Printer Light Keeps Flashing on C3180 PhotoSmart
No, you do not need 3 cartridges or anything like that. Some cartridges have chips. Yours do not. If the light keeps blinking it means that one of the electrical contacts on the cartridge has blown and now the printer doesn't recognize it. Try printing something, you will get a message "problem with color cartridge" or "color cartridge missing". That means that the printer doesn't recognize it. I suggest you buy a new one. Or, if you have an old one, try putting it in and see if the light still blinks.
Jun 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
I PUT BOTH CARTRIDGE IN BLACK AND COLOR ITS TELLING ME THAT THE COLOR ONE IS EMPTY AND IT NOT WHAT CAN I DO I BOTH THEM AT BJS TWO OF 17 BLACK ONE OF 27 COLOR . I TURNED THE COMPUTER OFF AND STILL SAYING...
Took off both cartridge and check if the cover has taken.Then try to put it back, make sure you put it properly(look at the sign where to put the color and black) and then restart the computer. If nothing change, change the cartridge. Thank you
Nov 11, 2008 | Lexmark Office Equipment & Supplies
HP PSC 750xi - Incorrect color printer cartridge installed error
I had this same problem and by a luck I fixed it. Not sure if the method to the madness had anything to do with it, but I'll put it down in the order that I did everything. 1. reset to factory defaults 2. pulled all cartridges out. it prompted me to put color in first, then black. message was still blinking so i took out color and put it back in again. 3. i did the partial reset by holding down cancel and left arrow while i unplugged/replugged the printer. 4. no the printer started displaying "remove and check color cartridge" (or something to that degree) 5. i took out color cartridge, cleaned the contacts with water on towel, and replaced cartridge. 6. same message still being displayed, but it allowed me to print a maintenance report. so i then cleaned cartridges and aligned cartridges through standard menu. 7. msg still being displayed, so i turned off/on printer again. this time it came back up with no message at all. 8. printer now works
hope this helps and works for ya'll too!
Sep 29, 2008 | HP PSC 750 All-In-One InkJet Printer
New Ink Cartridge not working
first check the new cartridge tmake sure you took off the thin clear tape on the bottom of the cartridge. if you did then the cart. is falty and go back to store and exchange. please rate me. thanks
Sep 21, 2008 | HP DeskJet 810c InkJet Printer
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
After changing cartridge, printer will not print, z645?
First... check to make sure you removed the yellow tab from the new print cartridge
put the ink cartridge back into the printer
click Start
click Control Panel
open Printers and Faxes
click (or double click to open) your printer icon
click on Printer menu
click on cancel all documents
Then try printing again.
If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
My Hp does not recognize my color cartridge?
Sometimes the color bleeds over. Did you wipe down the contacts and clean the heads? Also, most of the cartridges have low ink sensors in the. Even if you have them refilled, they will still show as low ink. The only solution is to buy the new ones.... $$$$$$.
Dec 12, 2007 | Dell 922 All-In-One InkJet Printer
Color Cartridge
If a Cartridge looks OKAY, it doesn't mean it is OK. You can not say it is ok. Turn out from the printer and install a new one then continue.
Sep 19, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
24 people viewed this question
Ben Johnson
