Question about Soyo Computers & Internet
24" DOA Soyo Monitor
I have a 24" soyo monitor that I purchased 15 months ago- I have not opened the box until today... and it is DOA. If Soyo does not agree to replace or repair it, what is the most econcomic way to repair it. Are you familar with the cause of the doa?
  • 1 more comment
  • j_louie Jan 12, 2009
    When I hook up power, I get the blue led light in front. However, after connecting a signal to it, the screen is still black. The monitor also does not respond to pressing any of the control buttons (on the right hand side).
  • j_louie Jan 13, 2009
    my graphics cards supports 2048 x 15xx resolution...
    Jonathan
  • Dick
    Dick May 11, 2010
    When you say DOA, you mean when you plug the power in and turn on the monitor (without hooking up anything but the power) you get no indicator light anywhere and no message on the screen that says no signal?
    Novelist:
    Champion:
  • 233 Answers
What size monitor were you using before? If you were using a smaller monitor and everything was fine maybe this new monitor is out of range for the graphics card. I've found that not all graphics cards, especially older ones, will not run a monitor as large as 24 inches. If you can, connect this new 24 inch monitor to a computer with a more powerful graphics card. If it works then you will know that the problem is with your computer. Also connect your old monitor and go into control panel and see what range and resolution your graphics card will support. You may need a more powerful card to run the new monitor.
Posted on Jan 12, 2009
No power to soyo 24"monitor,
If it will not turn on at all, it's toast. The monitors can be fixed, but it does take some specialized knowledge.
Jun 06, 2011 | Soyo Computers & Internet
My Soyo DYLM24D6 monitor screen goes black on reboot, can hear Windows XP Pro loading music but cannot even see the start-up screen from motherboard BIOS. I'm trying to find SOYO website but keep getting...
I would not be surprised if it does have bad caps in the power supply section.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Aug 06, 2010 | Soyo DYLM24D6 LCD Monitor
No screen after 5 minutes
The picture board on your monitor is bad, since it goes off after few minutes and the power led or button is on, it means the picture board of your monitor has developed fault.
I would advice you replace the picture board on the monitor, this should cost you between $65 - $85.
Take care.
Jul 06, 2010 | Soyo DYLM2286 Monitor
Computer 19" LCD Monitor with TFT 1280 x 1024 8ms DVI Connector Integrated Speakers - DYLM1967 ...: After a thunderstorm, my Soyo monitor would not tu...
If it uses AC adapter, then check the DC voltage at the DC plug to see if you get any voltage, if it use Direct power cord then it may have blown fuse inside the monitor, then you will need to open up the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | Soyo TFT 19" LCD Monitor
I need drivers for my Soyo MONITOR, DYLM017B Model:VT17n71.. Windows 7 is tellin me its out of range
I've spent a bit of time researching this problem for you and have come up with the following, hope it helps.
SOYO has quoted "All SOYO monitors are Plug and Play monitors. They do not require drivers to work". Recently SOYO went bankrupt so their website is now unavailable for any form of support.
What i would recommend to you would be to temporarily connect a CRT monitor (one of those big bulky monitors) to your computer, as these have a larger resolution and refresh rate capability.
Once you can see Windows 7, change the display settings to the minimum settings for your monitor (as a safe bet i'd set them to 800x600, 60Hz until you connect the LCD). Then connect your flat panel monitor again and set the display settings to an optimal level for you.
Again, i very much doubt that you will need a driver for this brand of monitor, and will be hard pressed to find one.
All the best, and i wish you luck :)
May 10, 2010 | Soyo DYLM1788 Monitor
I do drawings in Autocad and Photoshop on my 24" soyo topaz s
to adjust the setting on your monitor follow this steps:
right click on the desktop-properties-click Settings Tab-here you find the Screen Resolution then you can adjust it how you want then click Apply and you're done.
Dec 15, 2009 | Soyo MT-NI-DYLM2058 Monitor
I have a soyo computer monitor, flat, 19
packldr, If your certain that the monitor is not going into sleep mode, you will need to find out where the possible bad solder joint might be. This type of symptom could be a "intermittant thermal fracture" of a solder joint on an internal printed circuit board inside your monitor. Your monitor works fine until the internal temperature rises enough to cause "thermal expansion" to cause a OPEN connection on some critical component on a "switch-mode-power-supply" or "cold-cathode-fluorescent-tube" power supply circuit. (INVERTER ckt) If you visit youtube, check for videos that deal with "LCD monitor repair" and "bad capacitors", "LCD disassembly" just so you know what you are dealing with. Please let me know if this was helpful to you. I'm louie12fix on fixya or lmistyrel@aol.com Bye for now.
Oct 01, 2009 | Soyo Computers & Internet
Soyo monitor: Out of Range
Out of range indicates that you have attempted to use a resolution the the monitor is incapable of handling.
Lower your resolution and try again until you can get it to do what you wish then try to do each monitors resolution individually.
Aug 24, 2009 | Soyo Computers & Internet
Soyo monitors
your monitor doesnt have drivers for it.. and doesnt need drivers for that matter. It sounds like you dont have the right drivers installed for your graphics card. here is a link to the drivers you need.
http://www.nvidia.com/object/winxp_169.21_whql.html
hop this helps, good luck.
Jan 22, 2008 | Soyo Dymond DYLM017A 17" LCD Monitor
Computers & Internet Logo
280 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
