Question about Vapor T 2200S LadyBug Canister Steam Vacuum
The empty water red light wont quit beeping or blinking canister is full of water it is a daivolo steam canister rug cleaner
2 Suggested Answers
SOURCE: T2100 S Ladybug Canister Steam Cleaner
Visit the Ladybug Ladybug 2200S Vapor Steam Cleaner page and scroll to the bottom. There's a link that says, "Download owners manual."
Posted on Dec 16, 2008
My rainbow was working, now the rug cleaner quit.
Does your power nozzle have a red power light? Your Circuit Breaker PN2E PN2 could be defective. Also check the hose connection to the front of the Rainbow. Be sure that it has both latches secure. This can cause power nozzle to not run.
You can also contact our technical support team at Contact Us
RainVac
Sep 16, 2015 | Rainbow E series Canister Wet/Dry Vacuum
My polti steam cleaner wont work when i click trigger
Check the wand and line for calcium build up especially in the nozzle. Hard water will deposit a lot of calcium in the system, which needs to be cleaned regularly to keep it running freely.
Aug 25, 2014 | Polti Vaporetto 2400 Canister Steam Vacuum
After a short time of using my steam cleaner the red light comes and steam stops.
red light of course means stop, so do. second its a vacuum so my next assumption is its full either it needs to be emptied or cleaned so it can resume its job. I hope this helps.
Jul 13, 2011 | Domena NVT200 Steam Vacuum
Suds not coming out
do you have the dial set to presoak ? Clean? or Rinse?
make sure the container for the soap is full and is popped into place correctly.
also... if the water canister is empty or the dirty water container is full it will stop sucking up the water :)
Mar 29, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Oct 20, 2008 | Vapor T 2200S LadyBug Canister Steam...
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Euro-pro shark steam cleanercs618hd
I am looking for an operator's manual for the Euro-Pro Schar SC-505 Handheld Steam Cleaner.
Any ideas?
May 26, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
Vapor T 2200S LadyBug Canister Steam Vacuum Logo
103 people viewed this question
Top Vapor Vacuums Experts
richie46
ray gallant
Tom Chichester
Are you a Vapor Vacuum Expert? Answer questions, earn points and help others
