Question about Compaq Presario 5000 PC Desktop
It takes my PC a very long time to boot up, what can i do?
My sorry for the information I gave you earlier, I have a desktop, Presario S0000 series (S3500CL) with Pentium 4. I am also wireless.
    Scholar:
    New Friend:
  • 42 Answers
If you have installed any softwares recently it might slow down the pc as many softwares will install a startup file in order to start faster. You can shut these programs from starting up when the pc starts.
I put 2 steps to resolve this in order of simplicity.
Remove icons from the Startup folder
Some programs open with a shortcut icon in the startup folder (Startup icons). Use the following steps to show any startup icons that might be hidden and remove startup icons from the startup folder:
NOTE: Removing items from the Startup folder does not uninstall the software program.
1. Right-click the Start button, and click Explore . The Windows Explorer window displays with Start Menu already selected.
2. Click the plus sign ( + ) next to Programs .
3. Click Startup . The shortcut icons are listed in the right pane of the window.
4. To show any hidden icons, click Tools , click Folder Options , and click the View tab.
5. Click Show hidden files and folders (Windows XP/ME) or Show all files (Windows 98), and click OK .
6. Click an unwanted startup item in the right pane of the window and drag it to a blank area on the Windows desktop. Release the mouse button to drop the icon onto the desktop.
7. Continue dragging unwanted icons until all unwanted startup icons are on the desktop. Click Yes to any window that display asking to confirm the removal of a read-only file.
8. Close Windows Explorer and restart the computer for the changes to take effect. Delete the startup icons that were moved to the desktop after you are satisfied with the way the software programs are working.
If you find that a particular software program should not have been removed from the Startup folder, double-click the startup menu item to open the Startup window. Then drag the icon from the desktop back into the Startup window.
Posted on Jan 13, 2009
  • Ganesan Chandraiah
    Ganesan Chandraiah Jan 13, 2009
    Using Msconfig to troubleshoot software issues
    Msconfig helps Windows control software that automatically loads while Windows is starting. For troubleshooting purposes, use the following steps to prevent all software programs from automatically opening when Windows starts:
    CAUTION: The following steps are used to prevent all startup items from opening, including antivirus software and other software that may provide important functions. Only use these steps for troubleshooting purposes.
    NOTE: If the HP Boot Optimizer is installed on your PC, some applications may not appear in the Msconfig application. In this case, uninstall the Boot Optimizer utility before using the following steps. Go to HP Boot Optimizer Uninstall Steps
    NOTE: Using Msconfig can cause the operating system selection screen to display for three seconds; as a result, three seconds add to the overall startup time. The default setting for HP and Compaq desktop PCs with Windows XP is to not show the startup screen. To prevent the operating selection screen from appearing for three seconds on startup, edit the timeout line in boot.ini and change it to zero.
    1. Click Start , and then click Run.
    2. Type the following into the Open field: Msconfig
    3. Click OK.
    4. In the System Configuration Utility window do one of the following:
      If you are using Windows 98 and ME, select Selective Startup on the General tab, and remove the checkmark next to Load startup group items .
      If you are using Windows 95, remove the checkmarks next to Config.sys and Autoexec.bat.
    NOTE: Many software drivers and antivirus software depend on Config.sys and Autoexec.bat in order to work. If you experience problems after completing these steps, perform the steps again replacing the checkmarks next to Config.sys and Autoexec.bat.
    1. If you are using Windows 98 and ME, click the WIN.INI tab, click the plus sign ( + ) next to the windows folder, and remove the checkmarks next to load= and run= .
    2. If you are using Windows XP, remove the checkmark next to Load Startup Items , click the Services tab, select Hide all Microsoft services , and remove the checkmarks next to all the items in the list.
    3. When finished, click OK .
    4. Restart the computer for the changes to take effect.
    5. After the computer restarts, a message about using Msconfig appears (Windows Me and XP only).
    6. To continue using Msconfig, click OK and then close the System Configuration window (do not restart the computer).
    7. To prevent the pop-up message from appearing again, place a checkmark next to Don't show this message again , and then click OK .
    NOTE: Once you have finished troubleshooting an issue, repeat these steps again, replacing the checkmarks, to allow startup programs and service to start with Windows again.
    Please rate me after trying these steps.
Compact presario s0000 need a diagram fir the inside for the bios
BIOS is the app that resides in a CMOS chip that instructs your system how to handle hardware prior to loading OS.
Nov 28, 2012 | Computers & Internet
How do I change the administrative password for my Compaq nc6220
  1. Press the Power button to start the computer.
    NOTE: Pressing F10 opens the BIOS of Compaq Presario desktops 2001 and earlier.Pressing F1 opens the BIOS of the S3000 series, 6400 series, and 2002 models of Presario desktop computers.
  2. Immediately press the F10 or F1 key repeatedly on the keyboard when the logo screen displays.
Oct 24, 2010 | HP Compaq nc6220 Notebook
I hve a compaq presario 5000 desktop. It will
if you can view your desktop and use the menus, go to start/all programs/accessories/system tools/system restore, if you had enabled this option earlier then you can restore the system to an earlier known date when you system worked.
else you can try installing winXP again, try the option to "Update" when the install option comes on.
else start PC, before the WinXp screen comes on press F8 key, use the Safe Mode to start PC, if you can see everything then shut down and restart in normal mode.
Dec 06, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario SR1000 Won't Turn On
The power on buttom might be it. Before doing anything else, check and fix the power ON button. I have a tower that gave me the same trouble. The Power On button somehow was out of place. Once I aligned it, the tower worked again. Good guess..! Good luck
Jun 14, 2009 | Compaq Presario SR1000T (568657) PC...
Winnt_root>\System32\Hal.dll missing or corrupt:
if you have a windows cd you can do a system restore from it or at the boot screen some computers have a system recovery so you can use system restore without a disk, if you can use system restore, restore your computer to a earlier time and that should solve your problem
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
I have presario v3070tu wan't audio and wifi driver for suse linux...from where to download?
Hello there
I understand that you need Linux drivers for your Notebook Compaq Presario v3070tu.
I am sorry to that HP do not have Linux drivers for your product.
For more information please click here.
This is what HP gave in that link
Don't see your operating system?
If your operating system is not listed, HP does not currently have software or driver downloads available for your product for that operating system, or they are not available in the language you have chosen. To look for a driver in another language, change the software/driver language by clicking the "Change your software/driver language:" link on this page to see what drivers are available for your operating system.--------------------------------------------------------------------------------------------------------------------------------------------
Thank you
Good bye and Take care
Raviteja
Feb 21, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Hp compaq presario v3000 is not loding the OS, show an error
  • as you boot the computer, start tapping the F8 keys
  • From the boot menu, select Safe Mode
If this seems to work, you can try restoring the computer to an earlier point from Start > All Programs > Accessories > System Tools > System Restore.
If Safe Mode also fails to load, you would have to check your disk for errors or you may have to install XP all over again.
Please get back, if you need any further help.
Jan 09, 2009 | HP Compaq Presario SR1920NX PC Desktop
COMPAQ pRESARIO s0000 PC
open the side panel and reset the cmos, you can do this easily by removing the battery from the motherboard for 10 mins, make sure that the power cord is removed from the back of the pc first, after this time put the battery back in and see if the machine will power up, if it works you'll have to set the date and time again
let me know how you get on
good luck
Nov 16, 2008 | Computers & Internet
Compaq Presario S0000/8000 Series hard drive won't turn on. Green light on back is blinking. Power strip is working, modem, monitor and speakers getting power and working?
is the power supply working have u recently installed a new hard drive or cd rom need to make sure that the wires are securly plugged into the drive and into the board and are plugged in to the drive correctly if this is all ok you may have to get a new drive
Aug 14, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
516 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
