Question about Ruud Central System Air Conditioner
Fan Limit Control for a Trane Mod #: BLU055E936B1
Need a Fan Limit Control for a Trane Furnace Mod#: BLU055E936B1
4 Suggested Answers
james3751
  • 614 Answers
SOURCE: have an older Trane furnace. no 'board' just
If you do not have a fan board you have a fan limit switch. That brings the fan on about 120 and off at 90. It is located in the middle of your heat exchanger. Check across with voltmeter when you turn it on. If you have voltage after it runs for a while its bad. Or just jumper across it and see if afan comes on. They just go bad. Pick one up at HVAC supply house or you can order on line. If you have an electronic thermostat. On the back it has a switch that says gas or el switch to electric and the fan will come on with furnace. Rus but you still need to change fan limit this will just get you thru till you get it.
Posted on Nov 28, 2009
koolbreezes
  • 540 Answers
SOURCE: Price for TRANE BLU055E936B1 gas valve?
ARE YOU SURE ITS THE GAS VALVE ? ARE YOU GETTING YOUR VOLTAGES TO THE PV---28V. PV--MV - 0V & MV-GROUND 28V WHEN CALLED FOR? THEN LOOK ON THE INTERNET OR E-BAY.
Posted on Dec 02, 2009
KLR Monkey
  • 22 Answers
SOURCE: what is the efficiency rating on the Trane model
Chances are you need to replace both the condenser and furnace, then you you should get a varaible speed blower with the new furnace, get at least a 90% gas system with a 16 SEER condenser, save on energy cost as soon as it's installed. Go Get IT
Posted on Feb 01, 2010
Trane XB80, no heating, limit circuit open
Sometimes these can be reset by gently taping them on the floor. Can be caused by not changing your furnace filter.
May 18, 2014 | Trane American Standard Trane American...
What is the efficiency rating on the Trane model BLU055E936B1 upflow furnace and what new furnaces are available to replace this old Trane furnace without having to change the venting system.
Jan 28, 2010 | Ruud Central System Air Conditioner
Trane ac, inside blower does not stop. The heater stops, the Ac compressor stops, but the inside blower does not, this the thermostat set at auto. Regards, Faylbp
Hi, I want you to try a couple of things for me if you will. Go to the thermostat and remove the cover. Now if you have a small bladed screw driver, loosen all the screw on this next section and remove it. Turn off power to the unit, if it is a split system, turn off the indoor unit. Once you remove this section which is the thermostat you will see the subbase and wiring. Take the red wire loose and off of the terminal. You may have a red jumper wire going from RH to RC. Remove the red wire coming into the stat at either point. Give it a minute and see if the fan stops now. If it does, you will need to replace the stat. If not, depending on the age of your unit, if your high limit/fan control tripped, that will be the problem. Some units have a fan control combination high limit that trips causing the fan to run all the time. You need to take a look at your heater section at the front of it to see what kind you have. If it is a combination fan/limit. it will be inserted into the fire box. It is square looking box with a cover on it some with a auto/ manual button on them Sometimes the contats will stick causing the fan to run. They can be removed with power off and cleaned up. They will have a dial with a temperature reading on them which tells the fan to come on when it reaches this set-point and off when it cools down. It may have stuck closed. Check what I have told you with the stat, and this and let me know the age of heater and if it is a split system Trane with a remote condenser and furnace located somewhere else. Get back to me on this.
Shastalaker7
Jan 23, 2010 | Heating & Cooling
Dec 01, 2009 | Ruud Central System Air Conditioner
Have an older Trane furnace. no 'board' just
Nov 28, 2009 | Ruud Central System Air Conditioner
I get 4 blinks it say open limit switch what does that mean
Your induce fan motor senor is out. The little fan motor that take out the heat has a sensor that tells the furnace thats its working. Some time it get stuck. Try blowing and sucking into the tube. you should hear a click
www.fastacservice.com
Oct 16, 2009 | Goodman GMS90703BXA Heater
TRANE 1984 Home A/C Where are How to Clean Coils inside House
the best thing to do it with airhandler shut down at breaker. 1st soften dirt and crud with 409 or different brand. 2nd take a wire brush and clean in up and down motion following the fins on coil.3rd rinse with spray bottle . this is the best you can do without coil removal.
Jul 02, 2009 | Heating & Cooling
Fan on unit will not turn on in cooling mode
Check to see if the green thermostat wire is conneceted to the "G" terminals on the thermostat and on the furnace.
Apr 20, 2009 | Ruud Central System Air Conditioner
Ruud Central System Air Conditioner Logo
111 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
