Question about Gateway 830GM PC Desktop
Front panel cords
I had to replace the cord on Gatewat830GM and now I cannot get the computer to turn on. Is there a certain order they have to be in in order for it to come on. It was working fine until while I was moving the pc to another location and the side panel slid off and I pulled them loose from the inside trying to steddy the machine. the cords are red,blue and black twisty. I tried to put them back on the little pins with no luck
  • Elma Green
    Elma Green Jun 11, 2007
    Thank you for getting back to me as fast as you did, did not expect that!! I will try the liknks you sent to see if I can get some help with it.
  • pndycedo Sep 27, 2008
    How do I reattach the three twisted pair of wires from the LED power button to the motherboard on a Gateway 830GM computer?
Yes, they have to be in a certain order. I was unable to locate a diagram for the model you listed. Try searching the Gateway site for a wiring diagram: http://support.gateway.com/support/default.asp There is a Gateway forum here, which may be of help: http://www.howtofixcomputers.com/bb/forum17.html You should probably not try random combinations, as you could damage the computer.
Posted on Jun 08, 2007
NEED NEW POWER CORD,CAN I ORDER ONE?
Certainly you can.
You have not told us what you need a power cord for, what kind of appliance or computer, etc.
We have no cords or parts for anything, but with more information, we might be able to tell you where to go for help.
If it is a computer, try a computer store.
God bless your efforts.
Jul 05, 2018 | Power Computers & Internet
My acer aspire zc 606 desktop will not turn on. I have tried unplugging power cord holding power button down for 45 secs. Is there anything else I can do?
First, you should remove the power cord from the PC before opening the side panel. Second, you should avoid static electricity by touching a bare metal part of the case before touching anything else in the computer. It's possible that the power on/off switch on the front panel of your PC is faulty. Inside the case on the motherboard you will find several wires coming from the front panel which connect to pins on the board. one wire is labeled PWR. Unplugging this wire reveals the pins which are very close together. Using a screwdriver to touch both pins at once will power the computer on. Of course, the power cord must be reattached in order for this trick to work so be extremely careful! If the PC is still under warranty then attempting to replace the on/off switch yourself may void the warranty.
The other possibility is that the power supply, or the cpu, or the motherboard itself is faulty. In this case, take it to a computer repair shop.
Jan 31, 2015 | Acer Computers & Internet
How to replace cords to door of dishwasher
Hi, You have to get access to both sides of the dishwasher, remove both sidepanels, Find damaged cord and order relevant part online, order 2 cords to replace both sides. To replace damaged cord ensure to close dishwasher door and unhook spring, replace damaged cords on both sides and connect springs back into place. Install both side panels to dishwasher. Done
Oct 17, 2014 | Belling Dishwashers
My hp pavilion a336n will not turn on. When I plug the power cord in the light on the back of the hard drive will turn on, but when I press the power button nothing happens... any suggestions?
To resolve this issue you may need to open the chassis (the computer cabinet). You can call HP specialized support for help but they charge you for the support. You can call them at 866-211-5207.
OR - Follow the given steps.
Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure: CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
  1. Disconnect everything from the computer, including the power cord.
  2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps. NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
  3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America. Performing this step ensures that the voltage switch is engaged and set correctly for your country/region. Figure 4: Voltage selector switchc00517964.jpg Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
  4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
  5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it. NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
  6. Remove all attached devices except for keyboard, mouse, and monitor.
  7. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
  8. Check the power switch:
    1. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
      • If the button sticks, it should be replaced or serviced.
      • If the power button does not stick and appears to be functioning, continue using these steps.
    2. With the power cord disconnected, remove the case or side panel.
    3. Follow the wires from the power button on the front of the computer to their connection on the motherboard.
    4. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard. Figure 5: Power switch connector on Motherboardc00517968.jpg
    5. Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
  9. Find the defective part:
    1. With the power cord disconnected, remove the case or side panel.
    2. Disconnect all power cable connectors from their connectors on the motherboard and from the back of internal devices (the back of drives). Make sure to label or remember where each cable connects for future reference. Figure 6: Example of common power connectionsc00540428.jpg
    3. Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
      • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
      • If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced.
      • If the LED light is now off, plug the power cable into a different power outlet that is known to be good. If the LED stays off, the power supply should be replaced.
      NOTE: If an electrical storm or power surge has recently occurred, then it is more likely that the power supply, the modem, or motherboard is damaged and requires replacement.
Oct 06, 2009 | HP Computers & Internet
HD 497 cords that connect headphones to computer
If you know how to solder wires then the cord is certainly replaceable. My cat chewed through the cord on my BeyerDynamic headphones, but I was able to order a replacement from them, take the earcups apart, remove the old leads and solder in the new cord lines.
You could try calling the customer service line for Sennheiser and see if they can send you a replacement, or you could just pick up a generic cord from Radio Shack or an electronic parts supplier.
Jun 18, 2009 | Sennheiser HD 497 Consumer Headphones
Fast green blink
1.Disconnect everything from the computer, including the power cord.
2.With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
4. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
5. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
6. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it.
8. Remove all attached devices except for keyboard, mouse, and monitor.
9. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
10. Check the power switch:
a. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
11. With the power cord disconnected, remove the case or side panel.
  • Follow the wires from the power button on the front of the computer to their connection on the motherboard.
  • Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard.
  • Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
12. Find the defective part:
  • With the power cord disconnected, remove the case or side panel.
  • Disconnect all power cable connectors from their connectors on the motherboard and from the back of internal devices (the back of drives). Make sure to label or remember where each cable connects for future reference.
  • Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
13. If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
14. If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced.
15. If the LED light is now off, plug the power cable into a different power outlet that is known to be good. If the LED stays off, the power supply should be replaced.
Apr 11, 2009 | HP Pavilion a340n (DQ099AABA) PC Desktop
Front panel Ac Switch failing to start computer.
Try these steps.
If Power supply light does not turn on (or no power supply LED)
NOTE: If the Power Supply fan spins when the PC is turned on but the light does not come on, it is possible the LED is defective. If this is the case, use the section Power supply light comes on or flashes .
1. Disconnect everything from the PC, including the power cord.
2. With the power cord disconnected, press the power button on the front of the computer. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
3. Replace the power cord with another power cord, like the one used by the monitor.
Test to see if the computer can turn on. If not, continue using these steps.
4. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
5. With the power cord removed, flip the red voltage selector switch to the opposite position, wait about five seconds, and then switch the red voltage selector switch back to its original location.
This ensures that the voltage switch is engaged and set correctly for your country/region.
6. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
7. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
8. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it.
9. Use a vacuum cleaner to remove the build-up of dust from the power supply fan vent holes. Make sure that the PC is turned off and that the power cord is plugged into a grounded outlet. Only use the end of the vacuum hose near the outside of the fan entrance.
10. If all of the above steps have been tried and the power supply light remains off, use the steps in the next section, use the next section Power supply light comes on or flashes , to reseat the cables and check the power switch connector.
Jan 11, 2009 | Compaq Presario SR1000T (568657) PC...
No power to a SR1420NX.
Power supply light on or flashes Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure: CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
  3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America. Performing this step ensures that the voltage switch is engaged and set correctly for your country/region. Figure 4: Voltage selector switch c00517964.jpg Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
    4. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard. Figure 5: Power switch connector on Motherboard c00517968.jpg
Dec 12, 2008 | HP Compaq Presario SR1420nx...
Front panel cords
1.
If your computer beeps when you start it but does not display anything on your monitor:
a. Disconnect and reconnect your monitor from your computer.
b. Verify that your monitor's power cord is connected and that your monitor is turned on.
c. If possible, connect your monitor to a different computer to make sure that your monitor works properly.
d.If your monitor works but your computer beeps and displays nothing,your video adapter has probably failed. If your computer is underwarranty, contact your computer manufacturer for support. If yourcomputer is not under warranty, and you are comfortable opening yourcomputer's case and replacing internal hardware, purchase and installa compatible replacement video adapter. Otherwise, contact a servicecenter for assistance. While replacing a part is a nuisance and may becostly, your documents, pictures, and e-mail should be safe and will beavailable when your computer is fixed.
2.
Ifyou see an error message that indicates that a keyboard is not presentor a key is stuck, turn off your computer and reconnect your keyboard.If the problem continues, replace your keyboard.
3.
Sometimesyour computer won't start because your computer is not compatible witha hardware accessory. If you have recently added a new hardwareaccessory, turn your computer off, remove the accessory, and restartyour computer.
4.
Removeall hardware accessories except your keyboard, mouse, and monitor. Ifyour computer starts successfully, shut down Windows, turn off yourcomputer, and add one hardware accessory. Then, restart your computer.If your computer fails to start, the hardware accessory you mostrecently added is causing a problem. Remove the hardware and contactthe hardware vendor for support. You can reconnect other hardwareaccessories.
5.
Youmay have a loose connector. Turn off your computer, remove allconnectors from the outside of your computer, and then carefully pushthe connectors back in. Look for stray wires, bent pins, and looselyfitting connectors.
6.
Ifyou are comfortable opening your computer's case, shut down yourcomputer, unplug the power, and open your computer’s case. Remove andreconnect all cables. Remove and reconnect all cards inside yourcomputer, including your computer’s memory chips. Reassemble yourcomputer before attempting to start it again.
7.
If your computer still doesn't start, your motherboard, processor, memory, or graphics card may have developed a problem. Contact technical supportfor further troubleshooting assistance. While failed hardware can befrustrating, your documents, pictures, and e-mail should be safe andwill be there when your computer is fixed.
arrow_px_up.gifTop of page
Sep 27, 2008 | Gateway 830GM PC Desktop
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Gateway 830GM PC Desktop Logo
77 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
