Question about Air Tools & Compressors
Blue hawk 18 gauge brad nailer model SGY-NS6 safety switch
Brand new nailer, attach air supply, pull triger, nothing... but I can press the safety with a screwdriver & it shoots just fine. Nothing in the instructions about safety switch(except in the parts diagram). Help!
2 Suggested Answers
  • 10865 Answers
SOURCE: My 18 gauge Dewalt Brad
Hi. Get an aerosol can of a penetrating lubricant called WD-40. Apply a few squirts to the action end of the nailer. let it sit for a couple of hours and then try it again. Repeat if necessary. J.
Posted on Aug 27, 2010
How do I remove a jammed nail in the SHF50?
Hi Al:
Usually nailers are built so that removing jammed nails is an anticipated activity.
WORK SAFE!!!
make sure the air supply is disconnected from the nailer.
Press the safety against a piece of wood and pull the trigger. Nothing should happen but it's just one of my safety phobias.
Now you can have a really close look at the nailer mechanism.
Remove any nails that are still in the magazine.
Some nail guns have a cam or tab that will release the face of the nailing assembly.
Others have a plate secured with cap screws or little bolts. There is often an allen wrench provided with the gun just for the purpose of taking the plate off so that you can remove the jammed nails.
If all else fails, you could check with the place you rented or bought it from.
Patience, curiosity, and safety. Keeping tools working is an adventure!
May 14, 2015 | Senco Shf50 Pneumatic Hardwood Flooring...
Freeman PFN1564 shoots air when you disengage safety and pull trigger
if you mean it only shoots air when you pull trigger and not a nail , disconect from air supply and open side of nail mag. (two screws on side) look for forign object in front towards head end , sometimes the paper that nails are wrapped in gets stuck in there , also there is a small spring metal clip at front of mag is this broken off and is unusually short ?
Sep 22, 2014 | Freeman 15 Gauge 34 Degree Angle Finish...
Air goes to gun but when trigger is pressed nothing happens, after pressing on board. gun is new
Same problem with mine. Right out of the box. Will shoot the first Brad after that nothing. Should have purchased another brand
Jan 18, 2014 | Campbell Hausfeld 2" 18GA Brad Nailer
I put a new o ring rebuild kit in my Bostitch N80 sb framing nailer. I replaced every o-ring (including the trigger valve assembly
If the new trigger valve leaks air when you connect the air supply, most likely defective valve or air is leaking past outer trigger valve orings due to debris in the slot or new orings were cut when the valve was pushed in. If air leaks when you depress safety to fire gun then most likely problem is in the head valve or safety foot is not pushing the firing pin all the way in. Easy test, remove nails and remove the trigger to expose the firing pin. Connect air and very quickly depress the firing pin all the way in. If the gun fires, adjust the safety foot as needed. If the gun does not fire, remove the head and check headvalve orings for good snug fit against the cylinder within the head. The surface were orings make contact must be very smooth and not too deeply worn. If you notice fine scratches remove with fine sandpaper. Reinstall head using plenty of white grease on all the orings within the head and retest. Good luck
Feb 10, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
My frame pro 601 will sometimes shoot one to five times and then when you pull the triger nothing happens air comes out the core valve hole above the trigger when pulled then you can unplug air and tap on...
Senco makes a kit for your nail gun, part number YK0360. If you have any o-rings giving you problems, it's always best to replace all of them. You can get them from online parts stores like eReplacementparts.com or possibly from rental or repair places near you. Make sure you lubricate all the o-rings well when putting the new ones in.
Dec 13, 2012 | Senco & Frame Pro 601 Framing Nailer
When you bump nailer it wont kick out nails
new safeties on nailers have to push set safety than pull trigger no more just hold trigger and bump shoot nails
Oct 06, 2009 | Dewalt Air Tools & Compressors
Piston drives down when hooked up to air...piston does not return up. is this a problem with the triger valve? I am not pulling the triger, just hooking up the air. This gun hasnt been used in 10 years,...
Sounds like the head valve is stuck in the head. Take black head off and see if the valve is spring loaded by pushing down and see if it comes up. This is the usual problem.
Jul 08, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Paslode finish nailer wont fire
CHECK THE SPARK! IF YOU HAVE A JOBSITE RADIO YOU CAN HEAR THE SPARK ON THE AM BAND AND TELL IF THE TOOL IS FIRING!
Nov 02, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
615 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
