Plug unit in (2004 stainless steel and black) ...the compressor clicks on but it seems like nothing is happening....then after 30 seconds the compressor clicks off....Is the compressor gone and is it worth fixing?
SOURCE: Whirlpool Gold Conquest side by
sounds as if you have an ice buildup restricting the fan from moving airflow to the freezer. Inside the freezer take apart the lower shelf and see if this area is full of ice, if so clean it and defrost it.
Posted on Jun 12, 2008
SOURCE: bar fridge
There is a PTC relay on the compressor you need to replace it. Small black square looking device take the wire retainer clip off and pry off the relay. Get the wires going to relay noted and then get the model number and make of your unit. Go to a parts house for appliances and get a new one. About 25 bucks for that little dude but it is a needed for your compressor. Could get a 3 in 1 relay they are a lot cheaper and easy to install. let me know how it goes ken
Posted on Jan 12, 2009
SOURCE: bar fridge
Chances are, the compressor has locked up. You can try skeeter140's suggestion, but I doubt it will do any good.
Pull the relay off the compressor and shake it. If it rattles, then it's probably good. If it doesn't, go buy a new one as suggested.
Repair is not usually recommended.
Posted on Jan 15, 2009
SOURCE: I have ge refrirator model
As the compressor ir running fine this problem is because the refrigerant may be evaporated little which may cause short cycling of the refrigerator.Please fill the system with some more gas and this problem you wont be having.
Thank You
Posted on Sep 03, 2010
SOURCE: I have sylvania se80106-2 bar fridge. compressor
If the compressor is running and there is no cooling then the gas (feron) may have leaked out. The only way out is to get the gas refilled.
Posted on Nov 17, 2010
Nov 03, 2012 | Maytag MFF2557HES Stainless Steel French...
May 29, 2012 | GE Monogram ZDOD240PSS Stainless Steel...
Dec 13, 2011 | Maytag 26 cu. ft. Wide-By-Side...
Jul 28, 2011 | Samsung RFG299AARS Stainless Steel (285 cu...
Jun 21, 2010 | Electrolux E23CS75DSS Stainless Steel
Dec 15, 2009 | Refrigerators
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
Oct 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Jun 22, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
Jun 07, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
Apr 22, 2018 | Refrigerators
402 people viewed this question
I have a new (still in the box) Haier Bar Fridge, 3.3 cu in. Thermostat turns on, compressor is working, but not cooling after 5-6 hrs. Have tried several times. If fridge has been tipped on its side, is this the problem? Can I do something before I take it back. Need help!
It's probably just low on refridgerant.
If it has a condensor coil, that could be dirty/clogged causing over heating and the compressor will cut off on internal overload.
If not coil, then it's low on refridgerant.
Is it worth fixing?
Well, a typical charge for installing an acces port for the guages, and recharging the unit would run you $175 to $250. If they tech has to vacume the system because it has lost ALL refridgerant and not just some, then add $75 to that.
To perform a leak check, and repair the leak, add a minimum of $125 to it.
So, it really depends on how much it would cost you to replace it. If you can replace it for $200 to $400. then I would replace it.
If it's a commercial unit and a new one would run $1,000 or more, I'd repair it.
