Question about Sharp 27C-240 27" TV
Sharp SX-59E9 Television, wont start.
Sorry about the subject line containing a model but I couldn't find my model in your list. The problem is that when you turn on the Television the power light goes green for about 2 seconds then turns red and does nothing at all. Just so you know we lost the remote for this some time ago.
  • 934 Answers
The fact that the TV attempts to power by the green light accordingly, and then goes red, indicates that the x-ray protection circuit is shutting it down to prevent any further or more severe damage. You likely have a problem in the B+ (high voltage) line.. Could be anywhere along across one of several circuits but I'd first suspect the HOT (horizontal output transistor), HV regulator and then maybe vertical. There are several tests that need to be preformed and with the right equipment takes about an howr to complete. This is not something you can do yourself - I would assume you don't have the DMM, ESR and 20mHz scope for starters. But a good reputable shop can have this one back on it's feet in an hour and I would guess for under a hundred dollars... If you're not sure where to find a good reputable shop I would suggest going to NESDA's site and researching from there... http://www.nesda.com/locator/state_search.php Good Luck Bill
Posted on Jun 08, 2007
SOURCE:
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
TV wont start up, blue power icon flashes 3 long and 1 short flash repeatedly
You need to reboot the tv. you've had a signal drop which locks up the tv. call sharp techicon1.png support and they will talk you through a reboot.
Apr 19, 2014 | Sharp Aquos Televison & Video
Colored lines in picture. It looks broken from inside television The tv was dropped on corner of tv stand by husband Can this be repaired? It's a Sharp LC - 20SH6U 20" Liquid Crystal Television
Yes it can be repair if this is under warranty then u can give a replacement for this and if thics not under warranty then u have to go to nearest TV repairing center .
Sep 02, 2011 | Sharp AQUOS LC-20SH6U 20" EDTV-Ready LCD...
I would like to program my Sony remote RMT-D187A to work a Dynex television but I cannot find the code to do so.
The Sony RMT-D187A cannot be programmed for a Dynex television. The brands supported according to Sony are: GoldStar, Hitachi, LG Mitsubushi / MGA, NEC, Panasonic, Philips, Pioneer, RCA, Samsung, Sharp, Sony, and Toshiba. Sorry, but it wont work on your TV.
Information found here: http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMTD187A
May 05, 2011 | Televison & Video
I need the code for a sharp tv with the phillips universal remote
The codes are specific to the model, and Phillips makes several different models. Phillips codes are available here:
http://www.urc.philips.com/
Once you find your remote control in their list, if there is no obvious list of codes, try the Quick Start Guide or the User Manual.
If the guide for your specific remote doesn't have Sharp televisions in the list, try codes 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 2550, and 0813.
If none of these work, please reply with your specific television and remote control models.
May 31, 2010 | Philips Universal PH301S Remote Control
I am trying to find bulk toner for a sharp ar-bc320 I have been only able to find universal toner for other ar sharp models are they compatable?
The AR-C26TxU toner cartridges are only made for the AR-C260, AR-BC260, and AR-BC320. The cartridges are unique for these models in that they are the only ones in Sharp's entire color cartridge line that contain both toner and developer. I'm afraid you're going to be stuck with OEM in this instance, sorry.
Jul 17, 2009 | Sharp Office Equipment & Supplies
Guide Plus on RCA television
My guide quit working also on my RCA 61" big screen and I called the cable company and he said something about the encryption data had changed and I needed to call RCA to find out what to do and the whole time trying to sell me a converter box. It is the cable company's fault or the guide wouldn't have put that message up to start with. We all need to call the FCC!!!
Dec 04, 2008 | Televison & Video
Green line
Sorry, 9 times out of 10 this is a defective LCD Panel....Call Sharp customer service and the may extend your warranty.
Oct 22, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp 27C-240 27" TV Logo
44 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
