Question about Samsung Televison & Video
Comcast tv stuck on "enter a 4 digit numeric pin and press select"?
Screen says: "ENTER A 4-DIGIT NUMERIC PIN AND PRESS SELECT > - - - - CANCEL" I have never selected any type of pin and the screen is unresponsive? Help?
3 Suggested Answers
gopakumarg43
  • 74459 Answers
SOURCE: parental control pin enter four digit
Hello
What is the model number of your Sony TV? Without it, how can I post a solution before you? Please provide it by Fixya. OK.
Posted on May 11, 2011
ingman3
  • 5 Answers
SOURCE: White screen with enter a 4 digit control pin and press select??? picture on both sides of white re fine!
It appears to be your parental control feature, or lock function. Try the codes 3001 or 1234 to reset the lock feature.
Press: Menu>Features>Parental Control(Child Lock)>Select,
then enter the code.
Posted on Nov 03, 2012
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
My harley wont start
Key fob MUST be present near bike!
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
TO ENTER NEW PIN:
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
Aug 10, 2014 | 2011 Harley Davidson FLSTC Heritage...
How do you access trouble codes on 2003 harley davidson deuce?
With the newer HD Security Systems using proximity FOBs where the key FOB needs to be close to the bike to start, this is now more important then ever. If the battery in your FOB dies and you have not set your Harley Alram Override PIN Code, you will not be starting your bike. It is just as important for those with oler Harley Davidsons with the push button alarm FOB. It you set your alarm and the battery dies before you return to your bike, again you will not be starting the bike.
If you haven't set the PIN over ride for your HD security alarm system...do it now! Here's how you do it...
(To view how to deactivate the security system with the manual PIN code, see below.
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
May 20, 2014 | 2003 Harley Davidson FXSTDI Softail Deuce
Asking for pin number
How do you change/reset the pin code of Child Lock/Parental Control settings?
  1. In disc mode, press SYSTEM MENU.
  2. Press 060414114420_12548.gif to select Preference.
  3. Press OK to confirm.
  4. Press 060414114406_12547.gif to highlight PASSWORD, then press 060414114432_12549.gif to select CHANGE.
  5. Use the numeric keypad (0-9) to enter your old six-digit password.
    • When doing this for the first time, key in 136900.
    • If you forget your old six-digit password, key in 136900.
  6. Enter the new six-digit password.
  7. Enter the new six-digit password a second time to confirm. The new six-digit password will now take effect.
  8. Press OK to confirm.
Apr 13, 2013 | Philips DVP3020 DVD Player
Nov 02, 2012 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Need parental level 4 digit password for magnavox MWD 2205 DVD player
EASY PROCESS LOL
Instructions
    • 1 Press the "Stop" button on the remote if you are currently watching a movie.
    • 2 Press the "Setup" button. A menu will appear on the TV screen.
    • 3 Tap the "Left" and "Right" arrow buttons until "Custom" is selected. Press "OK."
    • 4 Select "Parental." Press "OK."
    • 5 Enter your four-digit PIN number. If you forget or do not know your code, enter "4737" to override the security. Press "OK."
    • 6 Tap the "Up" or "Down" buttons until "Parental Level" is selected. Press "OK."
    • 7 Select "All." Press "OK."
    • 8 Press "Setup" to exit the menu. The MWD7006 is now unlocked.
Sep 21, 2012 | Philips Magnavox DVD/VCR Dual Player
Changing forwading Fax ID address from fax Canon JX200
This information appears at the top of each document you send.
1 Press [Menu].
2 Use [{] or [}] to scroll through the menus and select <DATA REGISTRATION>, then press [Start/Copy] twice. The LCD displays <DATE & TIME>.
3 Use [{] or [}] to select <UNIT TELEPHONE #>, then press [Start/Copy].
4 Enter your fax number (up to 20 digits) using the numeric buttons, then press [Start/Copy] twice (see page 9).
You can enter a space to make your number easier to read.
5 Enter your name (up to 24 letters) using the numeric buttons, then press [Start/Copy] (see page 9).
6 Press [Stop].
Registration ends and the fax returns to standby mode.
Nov 19, 2011 | Office Equipment & Supplies
I need to reset to the old factory settings. How do i do?? Kind regards, Kerstin
1. Press the d.menu button to display the DTV menu. 2. Press the up or down button to select "System", then press the enter button. 3. Press the up or down button to select "Reset", then press the enter button. 4. The "Enter PIN" screen will appear. 5. Enter your current 4-digit PIN code by using the numeric buttons (0~9). 6. Press the exit button to exit.
Manual - http://downloadcenter.samsung.com/content/UM/200603/20060325173246984_BN68-01007A-00Eng-0302.pdf
May 06, 2011 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
To unclok child lock tv samsung
Press Menu,press the up-down button to select set-up,press Enter button,press the up-down button to select v-chip,then press the enter button,press the number of buttons to enter your 4-digit pin,the v-chip menu is displayed, press the up-down button to select Parental Guidelines,then press the enter button, press the up-down button to what you want to do, press the exit button to exit. hope this helps..
Mar 25, 2010 | Samsung TXR3079 TV
How to delete jobs from the disk in the memory of printer
To delete a private job please do the following on the printer's control panel.
1. Press MENU to enter MENUS. RETRIEVE JOB is highlighted.
2. Press to select RETRIEVE JOB.
3. Press to highlight your USER NAME.
4. Press to select your USER NAME.
5. Press to highlight a JOB NAME.
6. Press to select the JOB NAME.
7. Press to highlight DELETE.
8. Press to select DELETE.
9. Press or to select the first digit of the PIN.
10. Press to select the digit. The number changes to an asterisk.
11. Repeat steps 9 and 10 for the remaining three digits of the PIN.
12. Press when finished entering PIN.
13. Press to delete the job.
Let me know if this helps you. Good Luck!
Sep 29, 2009 | HP LaserJet 5550 Printer
Televison & Video Logo
541 people viewed this question
Henry  Thomas
Henry Thomas
