Question about Peavey 32fx USB 32 Channel Mixer
Trying to get rid of delay
The manual warns that there will be a delay because the signals on board will go through the digital processor. It suggests two ways to get rid of the delay but they certainly do not work. The delay is quite annoying and really throws off the drummers who rely on the monitors.
  • 120 Answers
Is it possible to run all the signals through so they all have the delay?
Posted on Jan 18, 2009
  • rah1379 Jan 18, 2009
    is it possible to run all the signals through so they all have the delay?
Can't find a manual but can still explain. Delays, chorus, flangers, and reverbs are all the same effect except the different names of them will allow you different adjustments. Chorus usually has a width control which controls pitch shifting. Flangers and delays will have a feedback control which simply means, how many times you hear the echo. On reverb units, room size means how long of echo(even though it;s short) you want. Delay is the same with much longer echo, feedback is the same as on flangers except the flangers time is very short meaning the effect is at almost the exact time resulting in feedback causing a metalic sound. I probaly just confused you but good digital delays usually have all the features and will usually do all 4 effects depending on how you set them. If you want delay, set width on 0 and adjust time and feedback. For flanging, adjust width and speed and feedback. Chorusing, adjust time, width, and speed. Reverb, adjust time, set width on 0, and feedback. I see it has a level(mixture, how much effect you hear), and a replay(feedback, how many times you hear it), and a delay knob,(how long the echo will be) The range/mode switch allows for settings of diferent time lengths and INF setting allows for infinite repeat. Hope this helps.
Mar 09, 2013 | Applause MAE148 AcoEle Mandolin Natural...
How to Set up Auxiliaries on a Mixer.
Here are some tips to set up the auxiliaries properly on your mixer:
  • Step1:
Your auxiliaries allow you to send the signal from a channel strip to somewhere else while maintaining the signal on the channel strip. For instance, you can use auxiliaries for monitor mixes for performers in a live environment. You can also use auxiliaries for external effects processors or a number of different situations.
  • Step2:
Set the auxiliaries to pre-fader to allow you to change the level for the auxiliary with the auxiliary knob but not with the channel fader. Most mixers have a "Pre" button that allows you to enable pre-fader mode. If you don't have the button pressed, your auxiliaries are in post-fader mode, which means your channel fader will affect the signal level of the auxiliary output. For monitor mixes, you usually want to use pre-fader so you can control monitor mixes independently from the front of house mix. Some effects processors will be better to run post-fader, though, so don't always rely on pre-fader.
  • Step3:
Send out your auxiliary sends. On the back of your board, you there are the auxiliary outputs. For a monitor mix, you will use these outputs to connect to the inputs of the monitors. When using an effects processor, you will use the auxiliary output to connect to the input of the effects processor.
  • Step4:
Plug in a return if necessary. If you are just doing monitors, you do not need returns to the mixer. When using effects processors though, you need a way to get your effected signal back to your mixer. Take the output of the effects processor and connect that to the return input on the back of the mixer. Now you will have to adjust the return section on your channel strip to get the desired signal.
  • Step5:
Use the auxiliary knob to set the desired level. Once you know if you are running pre- or post-fader, and you have your inputs and outputs all correct, you can start sending signal to your auxiliary output. Turn up the auxiliary knob until either your monitors are set correctly or until you have the desired amount of signal going to your effects processor or other outboard equipment.
on Aug 07, 2008 | Yamaha Mg102c Stereo Mixer
My boss DD-3 makes a strange tapping sound on all modes. tapping sound gets more frequent when i turn the delay time pot to the right. its like a little tap sound getting into the circuit with the guitar...
Check your power source or battery. The sound is probably due to the internal processor recycling due to watchdog timer. If power is OK, then service will be necessary to repair the problem.
Apr 03, 2011 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
Dec 08, 2010 | Behringer Rx 1202fx 12 Channel Line and...
Long delay between singing into mic and hearing voice in speakers
Usually delay is associated with "reverb" not echo. If you are in a large room, the room acoustics can add reverb without the benefit of signal processing.
Reverb NORMALLY passes the inout signal as is and then adds in a delayed version on top.
The delay should be less than the room size delay.
Try turning off all effects as a start. There is some "transport" time if it goes through a digital signal processing.
Apr 30, 2010 | Vocopro Da1000pro Professional Digital...
My boss digital delay works when engaged but no sound when not
sounds like the true bypass line has been damagd. Should be easy enough to fix. Pop open the unit and do a visual inspection first, if nothing is noticeable then do a continuity check with an ohm meter from input to output with the delay efffect off. If you don't read a short in this situation then your problem lays within the signal path and its switched path.
Jan 17, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Boss DD3 - LED switches ON but the signal remains dry.
Have you tried a new battery?
If you have experience with electronics then open it up and start testing all the components with a digital multimeter to find the failed component(s).
Unfortunately the newer DD3's are harder to fix then they once were. There is no place to point you other than just to start testing everything. Hard to say what has failed. The signal into the input of the circuit may simply be shorting to the output. Maybe the switch or switching circuit has a fault.
Here is the schematic as a reference:
Dec 29, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
I need to get step by step direction to set up a behringer cx 340
You will need to carefully read all your manuals and proceed step by step Here is the first one to look at: This crossover goes between the output of your board and the input of whatever power amps you are using. It has sections describing each setup and by what you have said, if you have enough amps you would probably need to run stereo 3 way which is described on pages 9,10 and 11. This would allow you to run a mono sub out setup. The grey areas are the connections and controls you use. Make absolutely sure your cables match the ones in the diagrams and read and heed carefully all the warnings. As far as your E.Q. and your Compressor they are separate topics as they are signal processors and are hooked up in the signal chain of your mixing board. They condition the input signals. Your crossover belongs in the output stage which as mentioned before is from the output of your board to the input of the crossover then from the outputs of your crossover to the inputs of your amplifiers and then on to your speaker systems. Try to find a friendly person on your end who does sound on a regular basis and has experience setting up and troubleshooting connection problems who wouldn't mind trading some advice for whatever help you could offer them. You have some good gear there and although there are people who will give Behringer gear a bad rap, I have never experienced any problems with mine. You absolutely have to understand all your gear inside out and not try to make it do something it is not designed to do. You also have to make sure you understand the differences between balanced and unbalanced cable connections and only use good quality cables designed for each application. If you're good at soldering and understand all the theory and want to do the work you can probably buy in bulk and customize everything to your own purpose. Enjoy your new equipment.
Aug 27, 2009 | Music
Peavey 32fx USB 32 Channel Mixer Logo
96 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
