Question about Maxent MX-50X1 50 in. Plasma Television
Volume control problem
Last night my 50 in. Maxent plasma started acting strange. The volume control kept turning itself down as if someone was leaning on the remote (they weren't). Then tonight it was fine for a while and then the same thing started happening again. We tried unplugging everything for a few minutes, but when we tried to turn it back nothing works. Anybody know whats happening here?
  • Shelley Murray Jun 10, 2007
    Thank you so much! We will find a local shop to get it fixed. (And I will definitely mention that we think the TV has "windex syndrome" :)
  • 934 Answers
The MX50X1 uses a series of tac switches for ch+/- vol+/- and power. It would be my first suspect. The vol- tac switch may have become thermal or what we in the industry refer to as the windex syndrome. We see this a lot on direct view TVs usually because the switching board is directly below the screen and every time someone cleans the screen with windex an trace amount of the fluid might drip all the way down to the board and invade one or more of the tac switches. This isn't the only reason a tac switch goes bad or becomes thermal sometimes it just simply fails... Tac switches are cheap (less than $2.00) but the labor to put them in is probably one shop hour. Find a good shop and have them do it - - If you're not sure where to find one goto: http://www.nesda.com/locator/state_search.php and start your research from there... Good Luck Bill PS: Impress the shop you call and tell them you think your TV has developed the windex syndrome. They'll probably think you know a lot more than you do about TV repair. :)
Posted on Jun 08, 2007
There is no power at all. Last night the TV kept switching itself back on after being switched off. Now today nothing.
Unplug the tv for at least a minute and try again. or you may have lost your power supply on the tv, usually just a cap gets fried and can be fixed fairly easily with some soldering experience.
Apr 11, 2013 | Sanyo DP50747 50 in. Plasma TV
The volume will go to high by itself, and then decide to go all the way down, without touching the remote or the tv volume buttones.
The Samsung brand is the most universal remote compatible tv out there, sounds like either a neighbor or even someone in your own home has a Samsung product that will work on your plasma. for example if someone within range has a Samsung dvd or blue ray player the volume up and down button will work on the Samsung tv also.
May 30, 2011 | Samsung 50 in. Plasma TV
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a maxent 26inch LCD TV. Today, I was watching the TV when something very weird happened. The sound went all the way up to maximum and stayed there. I simply cannot turn the volume down...
Wow, that's a bit of an off brand...
It may be hard to find parts for.
If you can find parts, replacing the board with the audio section on it will be the easiest fix.
The cheapest fix is to get a stereo potentiometer, and put it inline with the speaker so that you at least have a manual volume.
If you are capable of running the unit into a stereo, see if the mute button works, the mute usually won't affect the line out, and you can control the audio from your stereo.
Here's a (quick and dirty) schematic of how to put a potentiometer in a speaker line correctly.
The idea is you can control the speaker anywhere from leads shorted (no sound) to leads across tv output (full volume). Choose a potentiometer value around 100 ohms with a linear taper if you can find it. Most pots will be logarithmic..for the most part it won't matter.
Mar 10, 2011 | Maxent MX-50X1 50 in. Plasma Television
Need universal remote control code for maxent 42" plasma tv?
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
246
730
746
Becki Barned
DISH Network Customer Service
May 17, 2010 | Sampo PME-42V3 42 in. Plasma Television
Control Remote Codes
Mike,
Code 246 is the correct code for my Maxent plasma for my dish network remote. Remote is 5.3IR and it was made by EchoStar Technologies Corp. Part #142301. If yours is the same, good luck.
jerry
Nov 05, 2008 | Maxent MX-50X1 50 in. Plasma Television
MAxent plasma will not turn on
open the back and reseat the LVDS cable(looks kinda like a computer data cable)...also check your other circuit board connectors..literally unplug the connectors..and reseat them...Question...is the set working now?...or is it not coming on?
Jan 16, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX-50X3 50 in. HDTV-Ready Plasma
Yes I had this problem. Unplug the power cord for 1 min then plug it back in. The tv will reset and the buttons then work again.
Sep 26, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Maxent 50" plasma problem
We seem to have had the same problem. Green light keeps blinking but will not turn set on or off. I unplugged the set for a few minutes, plugged back in and works fine but will happen from time to time for no reason.
Sep 12, 2007 | Maxent MX-50X1 50 in. Plasma Television
Maxent MX-50X1 50 in. Plasma Television Logo
102 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
