Question about Apple iBook G4 Mac Notebook
Screen won't turn on
I have a Apple g4. I got it from a friend. When I first got it everything was fine. Then the battery died. I got a charger and plugged the computer in. When I connect the plug it sounds like there is a disk spinning or maybe some sort of internal fan but I can't get the screen on not even sure if the computer is actually on. The green light is on on the battery but nothing else seems to be working. I noticed that there is a lock symbol on the left side of the computer with a little slot by it. What is that and is there any way that I can fix this?
  • breezygarden Feb 05, 2009
    I have a Mac Notebook G4 and all of a sudden the computer sounds like it is turning on, and it makes a noise like a fan...but the screen won't light up? Can anyone help me
I have a Apple g4. I got it from a friend. When I first got it everything was fine. . I got a charger and plugged the computer in. When I connect the plug it sounds like there is a disk spinning or maybe some sort of internal fan but I can't get the screen on
Posted on Feb 02, 2009
  • 34 Answers
When the computer boots does the screen light up? if it does the first thing you need to try is when you turn the computer on is to option boot. That is done by holding the option key while turning the computer on. after it boots you will see the the hard drive listed on the screen it will be a icon, if there you should be able to boot up. If the computer does not boot and your hard drive is still listed you most likely have a logic board aka mother board issue.
Posted on Jan 26, 2009
Apple computer is locked up
Your hard drive is 10 years old. It needs to be replaced.
Apr 22, 2014 | Apple 661-3345 IBOOK G4 14-INCH EARLY 2004...
Powermac screen developed fine black grid and won't operate properly
Isolate the problem to see if it's the screen or video card by connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without a problem then your original screen is bad and your video card is good. If the Borrowed monitor displays the same problems as your original then your video card inside the computer is bad.
May 29, 2012 | Apple Powermac G4 Quicksilver Logic System...
My ibook g4 won't power up but the power cord works,do i need a new battery?
I found this page at apple support about your problem, it seems to have helped a lot for many people. Apple Support
Mar 28, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
Firebird won't start and charge disappeared
When you hooked the battery charger up to the battery how many amps was it putting into the battery?
Dec 08, 2011 | 1988 Pontiac Firebird
My apple ibook g4 won.t turn on
cheak:
The power from AC
The power from Battery
Have you recently pulled apart your powerbook?
Dec 19, 2010 | Apple iBook G4 Mac Notebook
I took out the battery from my mac lap top held the power button for 10 seconds, I put back the battery in the laptop. However my laptop still won't turn on. What should I do?
You gotta trouble shoot. Take the battery and charge it on a friends computer or go to the Apple store and have them test it. If the battery is good, then your next step is the charger. Do the same thing with it-take it to the Apple store and have them test it or test it on your friends laptop. If the charger is good then the next culprit is the computer. Put a working known good battery in the computer and see if it turns on. If no, take the battery out and just plug in a good working known charger and see if the computer turns on that way. If still nothing, then you have to take the computer in to the Apple dorks and pay their hefty fee and have them fix it.
Nov 10, 2010 | Apple PowerBook G4 Mac Notebook
I am not able to turn it on! Cannot get to powerup
It's either a bad battery, bad charger, bad DC charger/sound board, or loose cable connection underneath the keyboard or maybe a combo of everything. Replace the bad battery and charger are relatively easy fix. Replacing the DC charger/sound board is a bi.ch and requires a little more technical savvy. Making sure all cables are attached securely underneath the keyboard is a relatively painless task of just pressing down on all the power ribbons to make sure their securely seated, but getting the keyboard case open can be a bi.ch.
Jan 28, 2010 | Apple PowerBook G4 Mac Notebook
I have a 17 inch g4 imac with no backlight on the screen
Its either going to be a problem with the lcd or the inverter which is why your getting the very dim screen.
Apr 16, 2009 | Apple iMac G4 20" Mac Desktop
Ibook G4 shuts down by itself
You are having a problem with the logic board/power supply. I had the same issue a while back. I hope it is still under warranty as it is around a 500 - 600 dollar fix. If you take it into apple and they take your computer in for a repair and they mess it up, they will replace it with a newer one, which is what happened to me. So I hope you have similar luck, but other wise you might consider upgrading to a newer model just to avoid the cost if it is still not under a extended apple warranty. Which I bet is the case, being it is a G4 (6-8 years old).
Dec 21, 2008 | Apple iBook G4 Mac Notebook
Apple iBook G4 Mac Notebook Logo
296 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
