Question about Brother HL-2170W Laser Printer
Hi there I have a brother HL-2170 W and have a page in the machine that is jammed. I actually turned the power off in the middle of a print job. What do I do? when I turn the power on the error light blinks BArry
    Problem Solver:
  • 12 Answers
You should be able to solve your issue by following the first 7 steps below for clearing paper jams. After that put your printer back together and see if it starts working. If not, follow the rest of the steps and you should be fine.
  1. Open the front of the printer.
  2. Slowly take out the drum unit and toner cartridge assembly. Some of the jammed paper will be pulled out with the drum unit and toner cartridge assembly.
  3. Set the drum unit and toner cartridge assembly on a piece of disposable paper or cloth in case you accidentally spill or scatter toner.
  4. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes inside the printer.
  5. Close the front cover.
    Note: Do not put the drum unit and toner cartridge assembly back in at this point.
  6. Pull the paper tray completely out of the printer.
  7. Pull the jammed paper down and out of the printer.
  8. Open the back cover (back output tray).
  9. Still looking at the back of the printer, pull the tab toward you to open the fuser cover.
  10. Pull the jammed paper out of the fuser unit.
    HOT SURFACE
    After you have just used the printer, some internal parts of the printer will be extremely hot. Wait for the printer to cool down before you touch the internal parts of the printer.
  11. Close the back cover (back output tray).
  12. On the drum unit you set aside, push down the green lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
    CAUTION
    Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
    To avoid print quality problems, DO NOT touch the roller part of the toner. Try to keep you hands, fingers and everything else away from there.
  13. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the green lock lever will lift automatically.
  14. Open the front cover. Put the drum unit and toner cartridge assembly back in the printer.
  15. Put the paper tray firmly back in the printer.
  16. Close the front cover.
  17. Make sure that the Error LED is now off.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Posted on Jan 29, 2011
How to Cancel Printing in a Brother HL-2135W printer
Start by pulling the paper tray out to stop further pages being printed without jamming the printer up.
Then go onto your print queue on your computer and delete the job that is printing 50 pages.
If it dissapears then put the paper tray back in and it may print out the last page or two that were in the printer buffer.
If it does not dissapear from the print queue then turn the printer off and try to delete the job again.
Once you have ordered the job deleted then you can turn your printer back on and put the paper tray back in and allow it to continue. It should only print out the last page or two and then the job will dissapear
Sep 15, 2014 | Brother Hl-2135w Compact Wireless Mono...
How to Stop Printing while it is Printing ?
Start by pulling the paper tray out. This will cause the printer to finish the page it was on when it was interrupted rather than paper jam somewhere in the machine.
Once you have interrupted the print job this way then you can cancel the print job from the PC and then once that has been done turn the Printer off for a few minutes to clear the memory buffer.
Turn it back on and it should be cleared.
Mar 13, 2014 | Brother HL-2135W Mono Laser Printer Page...
Can't load the HL 2170-W drum/toner assembly
read page 60 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002308/cv_hl2140_usaeng_usr_d.pdf
Apr 21, 2010 | Brother HL-2170W Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Brothers hl 1450.. quit printing in middle of job, paper jam. All lights on, will not resume printing. I have turned on and off, reset computer.. won't budge.
if all of the lights on the printer are flashing it means there is a physical problem with one of the main parts of the machine( power supply, main board, ect.) try unplugging the machine for a few minutes and plugging it back in, if the problem persists you would need to have it checked by a technician
Dec 02, 2009 | Brother HL 1450 Laser Printer
My Brother 5240 laser printer has a red status light when i turn it on. I hit cancel job, and the light turns green. however, when i print a file, the file goes into the print queue for a few seconds then...
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
Nov 25, 2009 | Brother HL-5240 Laser Printer
Hi! the drum light on my Brother HL-2170 laser
1. Open Cover.
2. Press the Clear key to display drum status.
3. Press 1 (hold) on the telephone keypad.
4. When the display shows "ACCEPTED", close the front cover.
PRESTO!
Oct 19, 2009 | Brother HL-2170W Laser Printer
Printing dots on Brother HL 4040CN
do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
Apr 01, 2008 | Brother HL 1440 Laser Printer
Paper jams
The Pickup roller of the printer is not properly aligned, send the printer to repair and see the jam
Sep 29, 2007 | Brother HL-2040 Laser Printer
Brother HL-2170W Laser Printer Logo
222 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
