Question about Kitchen Ranges
Belling E665, cannot control heat on hob, temperature always at max
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Lack of control on hobs
New temp regulators req'd
Posted on Dec 15, 2008
What can I do about the hobs overheating - when on, they are only on the highest heat and can't be turned down.
THE only solution is to replace the regulators that control the hotplates.
Could prove to be expensive.
Mar 01, 2015 | Belling Ovens
Oven getting to hot
I had the same problem before. I pulled off the oven temperature knob and adjusted a screw to calibrate the temperature. Used a micro screwdriver and a candy making thermometer
Oct 20, 2014 | Belling Freestanding 60cm Electric Ceramic...
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
, push in and turn the control knob to the full on position (large flame symbol). If your hob has an ignition switch on the facia, press it in until your burner lights. • Hold the control knob in for 15 seconds then release. If the burner fails to light within this time, release the control knob and wait one minute before attempting to re-ignite.
or
Push in the control knob and after a couple of seconds press the ignition switch. • Hold the control knob in for 15 seconds then turn to desired heat, If the burner fails to light within this time, release the control knob and wait one minute before attempting to re-ignite.
Feb 03, 2018 | Belling FarmHouse 931 Gas Kitchen Range
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
