Question about Harman Kardon AVR 130 Receiver
Harmon kardon 745 displays "unlock" no sound for tv or movies
everything seems to work hdmi1/hdmi2 etc ... however there is no sound in any function
appreciate any help
  • 1 more comment
  • Anonymous Jan 13, 2009
    dvd/cd no sound with this function will play through tv also radio plays
  • Anonymous Feb 08, 2009
    avr 635 doing the same thing
  • COCKERkulet Apr 20, 2009
    i cannot unlock the receiver from DVD
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Posted on Mar 01, 2009
    New Friend:
No sound to Tv ears from Harmon Kardon
Posted on May 27, 2013
How to I unlock a Harmon Karmon Avr 130?
Posted on Sep 12, 2010
Can't keep the HDMI2 setting for watching streaming channels - TV automatically reverts to HDMI1
That's because you have connected another device in HDMI1, the TV detects it as power on, and then change HDMI2 to HDMI1.
Try to power off the device in hdmi1, or you can even try to change HDMI2 to HDMI1 port ;)
Jan 15, 2018 | Televison & Video
Why can't my TV find a digital signal when connected to my digital ready aerial? Tuning for digital stations finds none. Does this TV require a set top box? If not how can I make it find and play n
hey, when connect any aerial in the back of the TV make sure you have a look for the name of the connection you use ( Skart,ext1,ext2,usb,hdmi1, hdmi2 etc.) so you can do a search on that extension. if you connect something on Hdmi1 and search on hdmi2 you won't find anything. you have to search on Hdmi1. PS: good luck.
Jan 24, 2015 | Televison & Video
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
Dec 31, 2009 | Toshiba 32AV502R LCD TV
How to view pictures on my lg tv using the usb connection
you need a usb memory stick with your movie etc in divx or mpeg format obviously plugged into usb port. You then need to select your input device by pressing AV button on remote control a few times and it'll go through TV,SCART, AV,DVB-T,HDMI1,HDMI2,EXT,USB
Nov 01, 2009 | LG 42LC2D 42 in. LCD HDTV
Can't change from HDMI2 back to HDMI1
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
Apr 29, 2017 | Vizio Televison & Video
Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Nov 27, 2008 | Samsung HT-Z310T Theater System
No picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Dec 06, 2007 | Panasonic TH-42PX60U Television
Harman Kardon AVR 130 Receiver Logo
3,489 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
